Need holding Clamps
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by mlong219, Apr 10, 2017.
  1. Apr 10, 2017 at 8:17 AM
    mlong219
    mlong219 [OP] New Member
    Hi All,
    Any idea where I can purchase rail mounts to hold my shovels and weed trimmers like the following on my rail system in my 2010 CrewMax?
  2. Apr 10, 2017 at 8:42 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Krezz, Law323, gosolo and 1 other person like this.
  3. Apr 11, 2017 at 5:22 PM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    Any idea how those relentless pieces mount to the factory rails?
  4. Apr 11, 2017 at 5:27 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You would just need to find the correct size T-slots. Not sure if the factory is the same size as unistrut.
    Krezz likes this.
  5. Apr 11, 2017 at 5:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Actually looks like it comes with it.
  6. Apr 11, 2017 at 6:23 PM
    PMG
    PMG New Member
    Where can these t-slots be purchased?
  7. Apr 11, 2017 at 6:57 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Any hardware store. I like these, you just insert and twist in place.
    PMG[QUOTED] likes this.
  8. Apr 11, 2017 at 8:51 PM
    PMG
    PMG New Member
    Thanks. I've been walking up and down the aisles at Lowe's and never seen these. Maybe I'll go to home Depot tomorrow, don't know if I have enough time..
  9. Apr 11, 2017 at 8:53 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    They're in electrical section with the unistrut rails. Are you buying it for the factory rails? Not sure what size you need for them.
  10. Apr 11, 2017 at 9:17 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Use your chevy repair kit (duct tape and tie wire)
    831Tun and Law323 like this.
  11. Apr 12, 2017 at 8:13 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    4x innovations sells a kit. They are a vendor on Tacoma World. I am wanting to do this too, I'll probably fabricate my own.
  12. Apr 12, 2017 at 8:14 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
  13. Apr 12, 2017 at 8:52 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just 4 bolts through the bed. (This may void Linex warranty though) Used rubber furniture feet so the can wouldn't rattle when it's empty. And a couple of washers underneath to level it.
    http://www.4wheelparts.com/Exterior...798.aspx?t_c=3&t_s=188&t_pt=8401&t_pn=S/B2798
  14. Apr 12, 2017 at 9:23 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    That would almost double as a VW repair kit except you'd need to include a rubber band.
    gosolo[QUOTED] likes this.
  15. Apr 12, 2017 at 9:37 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    9/16
    OP, If you were local to Chandler/Phoenix - I have some spares.
    T-Rex266 likes this.
  16. Apr 12, 2017 at 10:49 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  17. Apr 12, 2017 at 6:30 PM
    PMG
    PMG New Member
    Yes, in hindsight I should have used Unistrut vs buying oem rails; the undercover tonneau renders then useless anyway..
    Do these come in various sizes? I thought the Unistrut rails were the same size as the factory rails....?
  18. Apr 12, 2017 at 6:38 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I know of 3 sizes of unistrut;
    shallow (5/8), standard and deep. It's also available in various grades of st st.
    Not the same as factory rails but close.
    joonbug likes this.
  19. Apr 12, 2017 at 6:41 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Not sure about the factory but the unistrut is 1 5/8" rail width with different heights. I think there might be some difference because I remember reading about Brian @csuviper having to use a washer to make the factory tie downs work on the unistrut. I used the lower profile rails.
    PMG[QUOTED] and gosolo like this.
  20. Apr 12, 2017 at 10:17 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  21. Apr 12, 2017 at 10:18 PM
    csuviper
    Broomfield, CO
