2013- Front Hub Assembly
Discussion in '2nd Gen Tundras (2007-2013)' started by Jeffro22, Apr 4, 2021.
  1. Apr 4, 2021 at 4:35 PM
    Jeffro22
    Jeffro22 [OP] New Member
    2013 platinum crewmax 4x4
    Any input on front wheel hub assembly. I have 250K on my truck and chasing some front end issues. Need to replace calipers and was thinking of doing wheel hubs also . Seems to be some mixed reviews on aftermarket hub assembly's. Dorman and TRQ are the 2 i was looking at
  2. Apr 5, 2021 at 6:38 AM
    Jeffro22
    looks like a timken/koyo bearing pressed to original hub is the way to go
  3. Apr 5, 2021 at 6:45 AM
    koditten
    Kirk
    Midland of the Mitten
    I used Amazon for mine. 100k so far and no issues.
  4. Apr 5, 2021 at 8:47 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    There's a guy on eBay who has pressed Koyo hubs for a reasonable price, I would do that if I had to do it again. (Which I probably will since I didn't realize I had gotten Dormans until after I put them on)
  5. Apr 6, 2021 at 4:54 AM
    Jeffro22
    I have seen those. Was a little hesitant to buy in case they were fakes. Had a couple bad experiences with counterfeit parts from eBay
  6. Apr 6, 2021 at 12:33 PM
    audiowize
    Paul B.
    I don't think the market for Tundra front hubs is substantial enough to motivate the counterfeiters to do their thing.
  7. Apr 6, 2021 at 12:44 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    @ViktorG spells it out on a vid. Check him out on YouTube or on here.
    Silverghost and ViktorG like this.
  8. Apr 6, 2021 at 2:31 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    I use Koyo bearings (they are the OEM supplier for Toyota Tundra) and the original hub.
    https://www.youtube.com/watch?v=rJ3gL6PIy2c&t
  9. Apr 6, 2021 at 3:34 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Now THAT was some valuable training...priceless!
    Watching a craftsman work is a beautiful thing. Thank you, Viktor.
    ViktorG[QUOTED] likes this.
  10. Apr 11, 2021 at 4:41 AM
    Jeffro22
    I plan to do both sides. I bought one complete assembly (koyo) and then one koyo bearing . Will swap out the complete assembly first on one side first to save time, since i don't have a press. this way i can have all parts on hand to get truck put back together.
    My plan is to go ahead and use the old hub and get it pressed off and on to the Koyo bearing to make a second assembly and have it complete and ready to install prior to disassembling the other side
    ViktorG likes this.
  11. Apr 11, 2021 at 8:24 AM
    audiowize
    Paul B.
    I need to get a piece of large diameter steel tubing like you have. This seems like a better solution than the bag of 7/16" bolts I have that bend every time I use my bearing separator.
  12. Apr 11, 2021 at 8:42 AM
    Jeffro22
    watched the video a couple time's now. thanks for that! Will let you know how it goes
    07 Tundie and ViktorG[QUOTED] like this.
  13. Apr 11, 2021 at 8:53 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Nice video! Good knowledge. Nice to see a real Yota master believes in the product. Runs 2 inch spacers and a lift! Strong truck
  14. Apr 11, 2021 at 10:58 AM
    ViktorG
    Viktor
    Calgary, Canada
    Sounds good. BTW, you don't need to unbolt the sway bar to do the bearing like I did, only if you are replacing a strut.
    Silverghost likes this.
  15. Apr 13, 2021 at 4:55 AM
    Jeffro22
    FYI-I ordered a timken bearing off Amazon b/c it appeared from the pics it was a koyo and was on sale for $66
    it just showed up and the timken is in fact a koyo bearing
    koditten and ViktorG like this.
  16. Apr 17, 2021 at 8:41 AM
    Jeffro22
    Viktor- Do you use any lube/grease on any new parts or axle splines for reassembly?
    ViktorG likes this.
  17. Apr 17, 2021 at 9:45 AM
    ViktorG
    Viktor
    Calgary, Canada
    Yeah, I grease the axle splines and the lip of the cap that covers the hub nut. And grease the seal lips of course.
  18. Apr 23, 2021 at 4:18 AM
    Jeffro22
    thanks for all the help. I got my passenger side bearing and brake caliper swapped out. I had a little issue getting my bearing separated from the axle. I used the method you mentioned but used some nuts instead of a ball bearing which worked for the most part but wasn't abele to get it off all the way before i ran out thread to keep "pressing" When I tried to re tighten the bolts so I could put a larger nut behind the heads i stripped out my threads a little bit. Luckily i was able to get a tap and clean out the first couple threads enough to get the new assembly started.
    Not sure if this side was the original bearing (i think it is) but truck has 260k on it and I think the bearing assembly I pulled was actually still good assembly. it appears to be tight and spins freely and doesn't make any noise
  19. Apr 30, 2021 at 11:20 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    Whatever you do, don’t buy assemblies from Marion B2B. He sells 4Runner assemblies (not sure if he does Tundras [i don’t even know if they’re the same]) and is a complete shit seller. Save yourself the hassle if you see that name come up.
  20. Jun 24, 2021 at 6:53 AM
    Jeffro22
    Hey Viktor- do you have a part number for the seal that you install between the hub and the new bearing? I need to get one . (i tired pulling up diagram on toyotas dealers parts site, but diagram is terrible and I cant see anything)
    i dont have press so planning to take my old assembly and the new bearing to shop to get dissembled and pressed back together. was thinking of buying a new hub to simplify but it looks like i still would need to re-use the 4 mounting bolts off the old assembly. hopefully i can find someone that knows what they are doing
    ViktorG likes this.
  21. Jun 24, 2021 at 7:11 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    ViktorG likes this.
  22. Jun 24, 2021 at 9:59 AM
    audiowize
    Paul B.
  23. Jun 24, 2021 at 10:18 AM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    If I remember correctly I used blue pit hub assemblys on my '12 CM.
  24. Jun 26, 2021 at 5:45 AM
    ViktorG
    Viktor
    Calgary, Canada
    I’m pretty sure all the part numbers are shown in the video. I’m on vacation right now and don’t have access to the parts department
    Jeffro22[QUOTED][OP] likes this.
  25. Jun 26, 2021 at 8:52 AM
    Jeffro22
    Got it. Found that in your video.
    Part# Genuine Toyota Bearing Seal 90312-A0002
    Thanks!
  26. Oct 16, 2023 at 7:32 PM
    okeechobeebill
    okeechobeebill New Member
    Want to post an update on the koyo eBay bearings. I purchased them due to this post. 6 months of use and I had 2 studs shear off. When I removed my wheel 2 more studs were loose. I tried to source replacement studs but the studs they use are smaller than oem. It’s Chinese crap unfortunately. Seller was unhelpful when contacted. Kyoautoparts was the sellers business on eBay.
    Tundrathuda and Skew12 like this.
  27. Oct 17, 2023 at 4:52 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  28. Mar 9, 2024 at 3:59 PM
    Tridom
    Tridom New Member
    Dominick
    Hampton Roads, VA
    2012 Tundra SR5 4.6L V8
    I just figured out I need to replace my right front wheel bearing. From these posts I'm guessing it's best to get the bearing and hub assembly since I have no way to press them.
    But, every video I watch to do this has a different grease cap over the axle nut than what I have. Mine seems to just be a cap recessed into the hub. I can't for the life of me get it out and I'm afraid of damaging it because I can't seem to find anywhere to buy a new one.
    Anyone seen this?
    Help?
    ViktorG likes this.
  29. Mar 9, 2024 at 7:35 PM
    ViktorG
    Viktor
    Calgary, Canada
    I would guess maybe your truck is a 2WD?
  30. Mar 10, 2024 at 6:31 AM
    Tridom
    Tridom New Member
    Dominick
    Hampton Roads, VA
    Yes it is.
