2019 supercharger/tune
Discussion in 'Performance and Tuning' started by Mhenders1069, Apr 4, 2021.
  1. Apr 4, 2021 at 6:56 AM
    Mhenders1069
    Mhenders1069 [OP] New Member
    Mn
    2019 tundra Trd on king suspension
    4.88 Nitro Gears. King coil overs and rears with remote resi and a pedal commander throttle control. AFE cold air intake. RSI Smartcap and GFC supernate 50.
    Hi y’all! I’m beginning to consider a supercharger and I a bit confused about the tuning game. I’m regearwd to 4.88 in my 2019 and just know I want to maybe do this... can someone give me a super elementary lesson/recommendation on what tune/ sc kit to do with that has done this? It seems like 2019+ tuning is not a thing yet? Am I misunderstood? I’m in Minnesota too so we have more moisture in our air if that matters.
  2. Apr 4, 2021 at 7:19 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    The 2020s and 2021 are the only ones currently without tuning support.
    Magnuson (based on the TRD S/C) offers their kits up to 2019s, they use OV Tune for the 2019s and were using HP Tuners for their earlier models:
    https://www.magnusonsuperchargers.com/product-p/01-19-57-109-bl.htm
    Harrop's stage 1 doesn't require a tune for its Stage 1 offering:
    https://harrop-usa.com/tvs2650-tundra-lc200-lx-570-supercharger-kit/
    Whipple also has offering up to 2019s:
    https://whipplesuperchargers.com/index.php?dispatch=products.view&product_id=537
    sunnysideTRD and MTRock like this.
  3. Apr 4, 2021 at 7:24 AM
    Mhenders1069
    Mn
    I forgot to mention I’m flex fuel engine but have never out flex fuel in it
  4. Apr 4, 2021 at 7:28 AM
    Saltyhero13
  5. Apr 4, 2021 at 7:30 AM
    Mhenders1069
    Mn
    Yes I’m sure. It was a dealer owned loaner before. I didn’t choose it. That’s what I was finding but just wasn’t sure . I’ll give them a call. Thanks
  6. Apr 5, 2021 at 1:24 PM
    Mhenders1069
    Mn
  7. Apr 5, 2021 at 1:36 PM
    Saltyhero13
    I recommend emailing Magnuson if you haven't done so already, they got back to me within a day.
  8. Apr 5, 2021 at 1:38 PM
    Mhenders1069
    Mn
    Yeah I called them and they told me to call lcepreformance who also said they’d call maginssem .... ‍♂️ Waiting on some return calls but thought I’d ask on here too.
    apparently lce performance is Toyota specialist?
    Saltyhero13[QUOTED] likes this.
  9. May 11, 2021 at 11:04 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Give Keith Carty of Dirty Deeds Industries a call at 760-877-4234. He is the master of Tundras and he can get you everything you need on a SC.
    GODZILLA likes this.
  10. Jul 8, 2021 at 5:01 AM
    Mhenders1069
    Mn
    So if I’m not running flex fuel in my flex fuel engine, do I need to have a supercharger with a flex fuel tune? I’ve never run anything but regular 85/87 in the engine. I know that changes with the sc, but just thought I’d check.
  11. Jul 8, 2021 at 6:05 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yes, and I think that one of the reasons is that the fuel injectors in the FFV trucks are a different size (flow) and you need a tune to properly control them. There may be other additional reasons, I'm not certain as I don't normally read much about the FFV specific item....
  12. Jul 9, 2021 at 7:34 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    The reason you don't have to replace the fuel pump or injectors on an flex-fuel truck is due to the fact that the injectors are already considered high flow (because you need to inject more E85 vs. gasoline) and the pump is higher capacity. When you supercharge an FFV truck, unless you do fueling modifications past the stock kit, you can no longer run E85. The tune provided will take advantage of the larger injectors/force the fuel pump into "high" mode to ensure uniform AFRs.
    Saltyhero13 and Wynnded like this.
