6112 or toytec
Discussion in 'Suspension' started by TOMMYBOY1, Apr 4, 2021.
  1. Apr 4, 2021 at 7:03 PM
    TOMMYBOY1
    TOMMYBOY1 [OP] New Member
    Tom
    2023 Toyota Tundra Trd Sport Crewmax
    Ok read Tons of material on here . My dilemma is I want 3 inches of lift up front , I just was able to buy a pair of 6112 ‘s , but still need 1/2 inch lift to get close to or at 3 inches . I can use the 6112 with CB 1/4 inch shim for another 1/2 inch lift ( I don’t get the Tundra lean) currently I have the bilstein 5100 at top setting now with stock coils . A little harsh and want a better ride with the 6112 . My other option is toytec Aluma which is adjustable from 2 -3 inches . They come with 700 lb spring . Thinking it still be harsher ride then the 6112. Either way I plan on getting adjustable UCA’s
    So since I have the 6112 and shims already , Should I just go with that setup ?? Or sell it and go with toytec??? Either way I need about 3 inches to get level and don’t want to totally sacrifice the ride !!
  2. Apr 4, 2021 at 7:15 PM
    I'm on Toytec Alumas and the ride is just fine.
  3. Apr 4, 2021 at 7:23 PM
    I have the Aluma’s on my 4R. Ride is amazing @Toytec Lifts
  4. Apr 4, 2021 at 7:36 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I bought 6112’s, but can’t personally comment on the ride. They are still sitting in the box in my garage, waiting to be installed. :facepalm:
    Something about fixing broken trucks all day at work makes me not want to work on my truck in my off time. Number 1 reason I own Toyotas in the first place.
    Edit. I’m pretty sure you’ll be nose-high with a full three inches up front and a bed full of air.
    BravoDeltaRomeo likes this.
  5. Apr 4, 2021 at 8:07 PM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    Toytec Alumas here. Ride is awesome.
  6. Apr 4, 2021 at 8:22 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My 6112/5160s are stiff as fu(k..
    I'd opt for the Toytec Alumas since others seem happy with them....
    I'd also recommend Toytec shackles if you need a rear lift..
    Very happy with mine...
    Tundra14Platinum likes this.
