Has anyone put a non-Warn winch in a SDHQ semi-hidden?
Discussion in '2.5 Gen Tundras (2014-2021)' started by divinguy, May 29, 2020.
  1. May 29, 2020 at 7:35 PM
    divinguy
    divinguy [OP] New Member
    P@t
    2017 Tundra CrewMax Platinum
    Bull bar w/integrated light bar. NFAB Podium Running boards Vision Fury Wheels Front window Tint Dual DVD Players Century Canopy w/integrated lock, and Thule Crossbars
    Hey everyone,
    I'm just wondering if anyone has put a non Warn winch in a SDHQ semi-hidden winch set up. I had thought that it was not exclusive to Warn, but talking to someone today, they seemed to think it was exclusively for Warn brand winches.
    I'm a novice, so I have no clue as to whether that is correct or not.
    Thanks in advance for any tips/information!
  2. May 29, 2020 at 8:28 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Per SDHQ web site: Will fit Smittybilt x20 series winches with slight modifications
    Black Wolf and divinguy[OP] like this.
  3. May 29, 2020 at 8:34 PM
    divinguy
    P@t
    Oh cool! Thanks. Any opinion on SmittyBuilt vs. Warn?
  4. May 29, 2020 at 8:37 PM
    GiantsFanDan
    I've been using a SmittyBuilt and no issues. Never had a Warn so can't compare.
    divinguy[QUOTED][OP] likes this.
  5. May 29, 2020 at 9:35 PM
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    I running a badlands 9000lbs with mine.
    Nativeimages and divinguy[OP] like this.
  6. May 29, 2020 at 9:39 PM
    divinguy
    P@t
    Nice. Did you do the install yourself, or have it done?
    Nativeimages likes this.
  7. May 30, 2020 at 7:41 AM
    MaxYota
    Murf
    MS Gulfcoast
    Installed myself. It took a long minute though. The mount itself is easy to install but how to configure the Badlands control box was a time eater. You will have to cut out a little of the bumper webbing to get to the clutch handle in order to free spool.
  8. May 30, 2020 at 10:05 AM
    divinguy
    P@t
    Did you have to cut with a torch?
  9. May 30, 2020 at 12:09 PM
    MaxYota
    Murf
    MS Gulfcoast
    No the little strip on the bumper.
    7B1251D1-ADF0-4475-A631-520EB5C6356C.jpg 78F4E795-A057-411B-B297-1EED802EF440.jpg
  10. Jun 1, 2020 at 1:07 AM
    divinguy
    P@t
    That looks awesome. Thanks for sharing. :thumbsup:
    I'm thinking I may try to fit the Smittybilt.
  11. Jun 1, 2020 at 1:54 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’ve got a smittybilt in a victory blitz front winch bumper. You can put the control box wherever you like. You just need to get longer cables. The cables it comes with allow you to put control box on top or side of which.
    divinguy[OP] likes this.
  12. Jun 5, 2020 at 2:33 PM
    divinguy
    P@t
    Welp, I decided to go with the SmittyBilt in the SDHQ housing. If'n anyone is interested, I'll put some pictures up when it is done.
    don3032, NIOSH, 300BLK and 1 other person like this.
  13. Jan 6, 2021 at 4:34 PM
    greggm
    greggm New Member
    Gregg
    Los Gatos, CA
    2019 CM TRD 4x4
    Bringing this back to life, I've got the SDHQ mount on the way and plan to put my Harbor Freight Badlands APEX 12,000lb winch in (on?) it when it gets here...
    don3032, pearlpower, 300BLK and 2 others like this.
  14. Mar 11, 2021 at 8:49 AM
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    I have a Warn semi hidden coming my way and will be installing a Badlands 12k in it, or at least hope to. Will post up the end result in a few weeks.
    don3032 likes this.
  15. Mar 11, 2021 at 9:14 AM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    Ever get it installed. I am really leaning towards this same route.
  16. Apr 3, 2021 at 6:49 PM
    greggm
    greggm New Member
    Gregg
    Los Gatos, CA
    2019 CM TRD 4x4
    Hey all, I am almost finished installing the HF Badlands Apex winch in the SDHQ hidden bumper mount. It does work, HOWEVER the template for the fairlead is not correct (ask me how I know) :monocle: It ends up being about 2" too high, the Apex fairlead needs to just about line up lower with the bottom straight line on the bumper cover. I ended up making a cover to hide my booboo, you can see it in the 2nd photo.
    Also, you do need to cut a few trim pieces to clearance the clutch handle, both on the inside of the bumper face and to remove a section of the lattice plastic so you can reach in and use it. I ended up with the controller on the passenger side inside the grill, I kind of rested it on some rubber trim and then lashed it to the support with some metal tape stuff, not too slick but functional, this does mean I cannot access the corded plug and will have to rely on the wireless controller. The lines provided by HF were just the right length to reach in this configuration. If you want to have it inside the engine bay, you will likely need longer cables...
    A few more loose ends to tidy up tomorrow but she passed the smoke test today so I'm very happy with the result. :yes:
    pearlpower and Nativeimages like this.
  17. Apr 4, 2021 at 4:16 PM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Hate me..just go with the
    Warn winch. Why mess with the best..2019 tundra sdhq hidden bumper an
    Warn winch
