Power Window Fuse
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020cementsr5, Apr 4, 2021.
  1. Apr 4, 2021 at 9:55 AM
    2020cementsr5
    2020cementsr5 [OP] New Member
    I was working on installing the Auto Loc power windows modules, and while testing the voltage of each wire I heard a tick sound. Afterwards the switch (on the front passenger side only) stopped working. All other switches, including the front passenger found on the drivers side still work.
    It seems quite obvious I blew a fuse, but I am wondering which one and where it is. The one in driver side footwell is one fuse for all power windows, so I don’t think it’s that one cus all windows still work. Is there a fuse for just the singular switch on the passenger front side? If so where is it?
    Thanks in advance!
  2. Apr 4, 2021 at 10:06 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    You could hit the wiring diagrams linked in my signature and do some digging into the power window circuit. From my recollection, there’s only one fuse for the door windows. Perhaps you cooked the switch itself?
    1lowlife likes this.
  3. Apr 4, 2021 at 10:11 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Maybe see if one of the rear door switches will fit that front door connector and see if it works.
    Then you'd know if the switch is fried..
    Although it may be a different connector.
    My 2014 the front pass door has separate plugs for the windows and the door locks..
  4. Apr 4, 2021 at 10:50 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Do you have auto-up windows or not?
    The RH front window gets it's power from this fuse (20A "Door R/R) through the non-auto-up passenger switch. If it is being triggered by the main (driver's) switch, then it looks like it is getting power from the 30A "Power" fuse.
    The 30A "Power" fuse powers the rear cab power window switch/relay coil, the rear passenger door window switch, and sends power to the master control switch (which appears to be for powering any window triggered by that switch).
    The 20A "Door R/L" fuse powers the rear drivers door window switch.
    And there is another 20A "Door" fuse that powers the front drivers door window switch specific to the front window motor.
    So...following that logic, I would check the Door R/R fuse and see if it is popped.
    bulldog93 likes this.
  5. Apr 4, 2021 at 10:53 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I just went outside and checked it out.
    You can use the rear door switch in the front door and see if your front switch is bad.
    They have the same plug and the rear worked in the front..
    nv8973lf_f8509bebfcbeb00b4e3c6b94d08c0f5bd6d86345.jpg zqbbqk5x_c04a879a20ea372c5fe3a87d137a29b5a9cd45e0.jpg
    If your switch is bad, I THINK this is the part number, but please verify.
    84810-06030
    2006-2020 Toyota Window Switch 84810-06030 | Sparks Parts
    You can find them for $20 on eBay.
    Front Window Switch, Right - 84810-06030 (Genuine) - Toyota Tundra/Yaris, 07- | eBay
  6. Nov 9, 2022 at 7:42 AM
    Whittle
    Whittle New Member
    2021 Magnetic Gray Tundra TRD Pro
    I have this exact same problem where the passenger side window won’t work when controlled from passenger side but does work from the drivers side. I’ve checked all the fuses I can find and don’t see any issues and I tried replacing both the passenger side as well as the drivers side switches and that didn’t make an impact.
    Anyone out there with a suggestions?
  7. Nov 17, 2022 at 2:03 PM
    Whittle
    Whittle New Member
    Alright, I got a fuse checker and although no fuses were blown I did find that no power was reaching 2 of my fuses which I assume is the root of my issues with the window.
    Those fuses are the 10A “Tail” and the 5A “Panel” as listed on the fuse box cover by the parking brake.
    Does anyone have any clue why they couldn’t be receiving any power at all? The smartest electrical guy on here that I’ve seen is @RainMan_PNW or is there anyone else who could help on this one?
  8. Nov 17, 2022 at 3:48 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I’m not where I can pull up the diagrams right now. You’d have to chase those fuses back to where they source in the main power box under the hood and be sure nothing’s popped in there.
    And I assume you’re checking with the ignition on? Tail may not get power without headlights on (would need to check the EWD). And if Panel is backlight illumination, it may also only get power off headlights are on.
  9. Nov 17, 2022 at 3:50 PM
    Whittle
    Whittle New Member
    I did the check with both the power on as well as off. I didn’t think to activate the lights to see what difference that makes so I’ll give that a try and then report back. More to follow and thanks for the suggestion!
  10. Nov 17, 2022 at 5:31 PM
    The AutoLoc system is junk. That's why I got rid of mine. You also lose the window lock function with it.
  11. Aug 20, 2023 at 6:12 AM
    jabawaki
    jabawaki New Member
    2021 Cement CrewMax SR5 4WD
    Did anyone ever figure this out? I’m having the exact same problem. Passenger window works from the driver switch but not from the passenger switch. Not sure it it’s a fuse or the switch itself that popped.
  12. Aug 20, 2023 at 6:16 AM
    2020cementsr5
    It was a blown fuse. I brought it to the dealer since it was still under warranty and they replaced it and it worked
  13. Aug 20, 2023 at 6:20 AM
    jabawaki
    jabawaki New Member
    Thanks! Was hoping to replace it myself but I guess I’ll try the dealer if I can’t find the fuse location. I’m still under warranty as well.
    Did you end up ditching the autoloc?
  14. Aug 20, 2023 at 6:48 AM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    Where the hell is the passenger window fuse? I've been looking through all of them
  15. Jun 20, 2024 at 8:01 AM
    TundraChamp
    TundraChamp New Member
    2006 Double Cab Limited Tundra
    Hey @RainMan_PNW Do you know where the location of that "power" 30amp relay/fuse is located? I am 99% sure that is what I need to replace but Im not 100% sure on its location.
  16. Jun 20, 2024 at 8:31 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I’m not where I can check the diagrams, and don’t know off the top of my head.
