  1. Apr 2, 2021 at 6:58 PM
    jatatum36
    jatatum36 New Member
    Jimmy
    Hi, @WestexSBK! Congrats, It appears you have the 20" Factory rims and tires on your new ride. Does it have a good highway ride and handle?
    Jimmy
  2. Apr 2, 2021 at 7:02 PM
    Lagerstout82
    Lagerstout82 New Member
    2021 Tundra SR5 TRD Sport
    I drove mine and reached 5600mi.
    pvn.beluga and French Avocado like this.
  3. Apr 2, 2021 at 7:14 PM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    The truck drives like a dream! That rear sway bar is a must in my opinion. I intend to go with 18” wheels and larger tires soon but I’m loving the stock setup so far
    AggiePhil and jatatum36[QUOTED] like this.
  4. Apr 2, 2021 at 8:27 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    Some preventative stuff today
    Total Chaos bed stiffeners:
    Total Chaos cam tab gussets:
    Icon shock boots:
    and Coach Builder 0-2" lift carrier bearing spacers:
  5. Apr 2, 2021 at 9:17 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    This is fantastic. Love stuff like this. Great work!
    zach_attack4[QUOTED] likes this.
  6. Apr 2, 2021 at 9:25 PM
    Deathstar1520
    Deathstar1520 New Member
    BRENNAN
    2017 CM SR5 TRD 4X4
    6 inch lift, 35 inch tires and 20 inch wheels, and amp power steps
    dpast88, Wallygator, Ostrich and 13 others like this.
  7. Apr 2, 2021 at 10:59 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Tied em into footwell lights, they even come on when I get close to truck with key in my pocket
    Courtesy LED Puddle Lights under a 2020 Toyota Tundra
    https://youtu.be/HtOwDpCO4CM
    Yea, I’m gonna see what I can do!...if not I won’t push it since I have em under the truck
  8. Apr 2, 2021 at 11:49 PM
    Seffagus
    Seffagus New Member
    Seth
    Colorado Springs
    2021 Lunar Rock TRD PRO
    Center console safe Blind spot monitor ReadyLift TRD Pro plus 4 BF Goodrich 35X12.5 KO2
    Those are some fog lights I found on Amazon. Wouldn’t recommend them. They were far too bright to be auxiliary lights so I had to add some tint on the lenses
  9. Apr 3, 2021 at 12:09 AM
    Vin63
    Vin63 New Member
    2022 Tundra SR5 DC
    Installed my 6 way switch panel. So far just grill LEDs and my ditch lights until my light bar comes in... someone give me ideas for the other 3 :D
    168363633_251116953401516_5449262522921231361_n.jpg 168387595_485298472620380_9207048955418586347_n.jpg 168135031_126946352733911_5851463602691505558_n.jpg
    Wallygator, GAknight, CappyKD and 3 others like this.
  10. Apr 3, 2021 at 12:35 AM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
  11. Apr 3, 2021 at 7:29 AM
    CappyKD
    CappyKD Older, grayer member.
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    OnBoard air, Bed Mounted 12v and USB ports, Fridge, Winch power cutoff, Winch in, Winch out controls.
  12. Apr 3, 2021 at 8:24 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    If I don’t hit the 5K milage in a year, I still change the oil. I’ve heard condensation occurs in the engine.
    I thought I was a low milage person at 5-6 K miles per year with the Tundra. Vehicle milage dropped after retirement. (We have 2 other cars. Our high milage car is a BMW X3 diesel. The low milage is a M235 vert).
  13. Apr 3, 2021 at 8:40 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Got my ARB Weekender Recovery kit today! Everything looks rock solid! Now just waiting on the Agency6 hitch receiver.
  14. Apr 3, 2021 at 9:42 AM
    FLdub
    FLdub New Member
    24 Limited 4x4 Nightshade
    I did not. I actually bought this new in box from a local guy that no longer needed it. Same old boring latch but im ok with that. haha
    CorsoTundra[QUOTED] likes this.
  15. Apr 3, 2021 at 9:47 AM
    FLdub
    FLdub New Member
    Man I want the Leitner rack, love how modular it is.
  16. Apr 3, 2021 at 10:40 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Installed Rigid backup lights connected to the cargo light switch.
    B5305D9F-66BA-4936-9A51-42700C7C9219.jpg 101A42FA-FB1F-4A12-A277-ACA5A925A5C8.jpg A18B14F7-3EEA-4655-8D16-3CA0644144C3.jpg
    sf319, WFD473, stuckinohio and 20 others like this.
  17. Apr 3, 2021 at 11:06 AM
    Hongkongwongdonf
    Hongkongwongdonf New Member
    Will
    Gastonia, NC
    2017 tundra limited
    5% tint. Black rhino arsenal 20x9.5 295/55/20 KO2.
    Not what I've done today but my father just bought a 2021 1794 and absolutely loves it. Also it's so weird how much has changed since 2017 the brakes seem so much more touchy. Also does anyone know if the head unit is different ?
    Wallygator, Jpd0144, Fotnot and 6 others like this.
  18. Apr 3, 2021 at 11:28 AM
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    Added decked + Yakima overhaul HD + CVT Denali.
    Im heavy now.
    44809CD9-A6AA-4F54-A639-1594B289DB7D.jpg DD6EDE28-F926-401D-8F05-224CC19FF9B7.jpg
    My suspension guru has given me 2 choices. Icon RXT stage 2 but my current icon stage 5 kit I believe goes up to 2”. W this option I would need to upgrade to a longer shock. If I did that I would get kings.
    option 2 is to do icon RXT stage 1 and air bags w cradles and keep my current icon shocks.
    Plan to keep decked in full time. The tent and columns will come off when not in use.
    We like to get to the farthest camp spots down the forest roads. Would like to keep my clearance and articulation.
    which begs this question. I know I need a sway bar. It would help with all our Arizona windy roads. I carry a cordless impact. Does anyone undo and zip tie there’s on the regular. Is it annoying?
    thank you.
    WFD473, saybng, Wallygator and 7 others like this.
  19. Apr 3, 2021 at 12:10 PM
    18" TRD Off Road Wheels
    Not sure how much the head unit would change for the android auto/Apple caraway that was added to 2020+ model years. I know they removed the CD player.
  20. Apr 3, 2021 at 12:17 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Got the drawer system mostly done today. Next up is to build and mount the drawer itself when my slides come in and also carpet the outside. Also has a top hatch at the back and another on the side for more storage.
    520E3A90-B1B6-4706-9931-2651B2CAF707.jpg 0416E975-DA27-4278-880D-F4C01F5FF71E.jpg
  21. Apr 3, 2021 at 12:38 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    Swapped out the leaking third brake light on my canopy. Piece of junk was only 3 years old. 731870A0-93AD-41FA-B580-823FD6661318.jpg B8ED232A-5BE7-462C-B472-575440E4150C.jpg
  22. Apr 3, 2021 at 12:58 PM
    I went into town for some errands, put $80 worth of fuel in it, and hosed off the mud and grime at a car wash. Nothing like the reflection or detailing thread, but still pretty.
    One on the sunny side; one on the shaded side. Love the Cavalry Blue!
  23. Apr 3, 2021 at 1:18 PM
    Black
    2014 Tundra Limited CrewMax
  24. Apr 3, 2021 at 2:19 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Nice work, scribing the plywood.
    Jmor6766 likes this.
  25. Apr 3, 2021 at 2:51 PM
    WestexSBK
    Painted my tow hooks and got a lifetime alignment at Firestone
    31AADE11-2FCD-450C-8AC2-3EC03ACDD014.jpg F7474403-4548-420A-B41C-609D00FFA3B7.jpg
    sf319, GarTX526, Wallygator and 10 others like this.
  26. Apr 3, 2021 at 3:32 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Face ON!
    dpast88, ElNopal, LyonKing and 20 others like this.
  27. Apr 3, 2021 at 3:50 PM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    2014 White Tundra TRD SR5 4.6L
    Removed the bug guard that came on my truck
    Looks better without... except someone-maybe the used dealer tried to remove it before or installed to cover this?
    this was all discovered while in plasti dip mode. Trying out rear bumper caps for now and tempted to do grill- both temporary while I spend money on more important mods first. Looks good I think but I’ll see if it holds up.
  28. Apr 3, 2021 at 4:01 PM
    Tao Zero
    Tao Zero New Member
    2021 Black Tundra Platinum
    Send that too me and I can anodize it for you, I'll make it look real nice :)
    WFD473 and SpooledReel[QUOTED] like this.
  29. Apr 3, 2021 at 4:21 PM
    lonedrake
    lonedrake New Member
    Minnesota
    2020 TRD sport
    A month or so ago I ordered a Loncky leather steering wheel cover from Amazon. It came with a couple of small rips in it at the bottom corners. So I sent them a message with pics and asked how I would proceed. They responded that there was no need to worry as the rips would be covered by the plastic trim. I was skeptical, but it did seem that it would be close. So I installed it. As u can see by the pics it did not work out. Cut it out and send it back for a refund.
    My advice is to stay away from Loncky.87A94BCF-62A0-423C-8769-90D14CA1275A.jpg28F90A2A-1A34-45F5-899D-9ED148FC2BAA.jpg
    3xYOTA likes this.
  30. Apr 3, 2021 at 4:26 PM
    lonedrake
    Minnesota
    2020 TRD sport
    I decided to by a leather cover from Redlinegoods. I put it on today. Total time was approximately 3 hours. Much better quality. I did take the wheel off. You actually don’t need a puller to take it off. Just pull it back and forth and it should pop right out. I did use contact cement as I went along. I am very happy with the results.A197D099-F1A4-4ED4-9723-0813F954D802.jpg707B402E-2FD2-4B04-B045-945F1F27F42E.jpg
