Third Brake light/ Cargo light
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Mar 26, 2021.
  1. Mar 26, 2021 at 5:34 PM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Hello Brothers,
    I pulled out the lens on my 3rd brake light.
    Both of the cargo lights have melted the plastic.
    I’m needing a new lens kit. Several companies sell aftermarket
    lights. Has anyone bought new Toyota, or some other brand?
  2. Mar 26, 2021 at 5:40 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Clean up the crusty burnt plastic inside and then install some Aluminum Tape (HVAC) from big box. Next step is buy some Zevo Sylvanias at autozoned. Total cost about $40 and you get the feeling of saving the planet by reusing your shtuff.
    N84434, Jack McCarthy and KarmaKannon like this.
  3. Mar 26, 2021 at 6:10 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I installed a brand new OEM high mount because mine was melted also. It's on my build thread I think. Cost was about $110 when I bought it. I can't find the part number currently, but they are all the same IIRC.
    Others have installed aftermarket, and had water leak problems.
  4. Mar 26, 2021 at 6:56 PM
    Cummins3500
    Logan
    Does the seal come apart when you pull the lense?
    I finally got around to ordering some diode dynamics to go in there. I just gotta pull the camper top since it’s that time of year
    Tundra2 likes this.
  5. Mar 26, 2021 at 7:00 PM
    so_juanderful
    so_juanderful New Member
    Honolulu, HI
    2017 Cement Tundra TRD Pro
    I got the light smoked lens from Klearz. They also have clear and dark smoked.
    316KS_Runner likes this.
  6. Mar 26, 2021 at 7:03 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The red/white lens seal. No, not normally. It may come out with the lens but you can just put it back in the seal groove.
    The actual light housing seal does get destroyed when you pull the whole assembly out.
    Cummins3500[QUOTED] likes this.
  7. Mar 26, 2021 at 7:22 PM
    Cummins3500
    Logan
    @Tundra2
    Appreciate the info :thumbsup: hoping mine is too smoked up at this point
    Tundra2 likes this.
  8. Mar 26, 2021 at 8:40 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    I bought a new seal and a Amazon chee-zee light fixture. Will see where this goes.
    Good thing is new seal is only sticky on one side.
  9. Mar 26, 2021 at 8:42 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It should be sticky on both sides to provide a "seal" from the light, and cab.
  10. Mar 26, 2021 at 8:43 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Unless the seal is already attached to the light. Pics?
  11. Mar 26, 2021 at 9:10 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    Just ordered it, not here yet.
    Tundra2 likes this.
  12. Apr 2, 2021 at 6:02 AM
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
    What taillights are those?
  13. Apr 2, 2021 at 3:09 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Doing this currently... Burned lens vs replacement. Bulb size too!
    Which Bulb Style should I buy for this application?
  14. Apr 2, 2021 at 3:32 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    UPDATE:
    I plugged this in and it worked great. Went for a ride to Walmart.
    Got home and grabbed my broomstick. I wanted to see it when really dark.
    there are 13 brake LED light bulbs, the center 3 are now burned out.
    So much for a good deal, hello Amazon returns
    Here is the led version. Available on Amazon.BA34B7DF-ED91-41F6-A41B-1C63FF280EB5.jpg
    it’s a little bit too “Chromey” to me. I might spray the perimeter black to tone it down. I’m sure the cargo light will be much brighter. Also the Third brake light
    Should be brighter. That’s never a bad thing.
    N84434 and Tundra2 like this.
  15. Apr 2, 2021 at 3:42 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Let's see some pics of it installed when you get there.
  16. Apr 2, 2021 at 3:55 PM
    pinot911
    pinot911 02 AC Flatbed
    Portland
  17. Apr 2, 2021 at 4:03 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    I like yours much better. I paid like 12 dollars for mine. Wish these were a 25 dollar part.
  18. Apr 3, 2021 at 5:29 AM
    so_juanderful
    Honolulu, HI
    Recon
  19. Apr 3, 2021 at 5:54 AM
    Gfgneo
    Gfgneo New Member
    California
    Nice are those the the regular smoked? I was thinking of getting the regular smoked recon light but not sure if i should get the light or dark smoke klearz 3rd break light
  20. Apr 3, 2021 at 8:36 AM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    Non 1st Gen Talk in the 1st gen section...:fistbump:
  21. Apr 3, 2021 at 2:55 PM
    so_juanderful
    Honolulu, HI
    Regular smoked Recons, and light smoked Klearz
  22. Apr 3, 2021 at 9:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I would highly doubt it. Their high mount stop light has no need in bed "cargo lights" without a bed..........
  23. Apr 11, 2021 at 9:54 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    Ok,
    Got the chrome one on the way back to Amazon. I bought a smoked version of the LED
    third light. If you have the Phantom Grey color, this is the bomb. Color looks great,
    The LED lights are bright. Both the cargo lights and red stop lights are effective.
    I bought the smoked lens assembly at Amazon. I would recommend it.
    I have the original factory lens . For 10 dollars it’s for sale.
  24. Jul 31, 2025 at 8:44 PM
    Halsted
    Halsted New Member
    2004 Tundra 4WD V6 AC Manual
    My brake light is burnt out so I thought I’d do the cargo lights too because they’ve been burnt out since I bought it. Unfortunately the plastic is completely melted on the two sides that house the cargo lights. I can’t get the bulbs out. It’s a bit recessed so hard to get your fingers in there, and they’re glass so I don’t want to break them in my hands so I don’t want to squeeze harder. Is there a trick?
    Any advice? Am I hosed? Do I need a new housing?
    This is the best thread I could find.
  25. Aug 1, 2025 at 2:08 AM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    I had to use long needle nose pliers. Broke the glass. Pulled out the base. Get new bulbs first
    Halsted likes this.
  26. Aug 1, 2025 at 3:51 AM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I picked this up about a week ago, I didn't feel it was worth trying to rehab the 20 year old plastic.
    Edit: I have noticed the cargo light is nice and bright but it doesn't shoot towards the bed, it's almost shooting straight back which defeats the cargo lights purpose
  27. Aug 1, 2025 at 5:08 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Was just about to order that but it sounds like it doesn't work for purpose.
    Any other options found?
    There seem to be only two aftermarket led styles marketed heavily. This one and the cheaper one up in the thread that seems to have less bulbs and also gets bad reviews with failing bulbs.
  28. Aug 1, 2025 at 5:12 AM
    ToyotaDude
    ToyotaDude Member
    Link to this please? Does it illuminate the bed in the dark?
  29. Aug 1, 2025 at 5:23 AM
    Hooptytrix
    Dirty South
    There really isn't many options. My OEM unit was so yellow, faded and dried out that the light wasn't doing shit. I'll take a better look at how much light hits the bed tonight but from what I saw on day 1 it was almost non-existent. But at least it looks better than the crusty one :D
  30. Aug 1, 2025 at 7:19 AM
    I bought a replacement lens for my Access Cab. It was $14 for a brand new replacement OEM lens part direct from Toyota. My 2006 used the following parts:
    81570-0C010 => 3rd brake light complete assembly, including new foam gasket (But the part is $$$ so should be bought during a national sale!)
    81572-0C010 => 3rd brake light RUBBER lens gasket (This seals the outer lens to the inner light assembly, it is NOT the foam gasket to seal the light assembly to the cab!)
    81571-0C010 => 3rd brake light lens cover (Lens cover only, this is what you'd need)
    Of course, check compatibility before pulling the trigger on a part number I'm giving. And note: You CANNOT buy a replacement foam gasket from Toyota, the only way to get one is to order online - you can buy cheap replacement on scAmazon, and note: aftermarket replacement 3rd brake lights are notorious for leaking water into the cab!!
    I looked it up, and it looks like the lens' MSRP is almost $29, but my local dealer has it on pickup for $18.52, and that's not even from the cheapest participating dealer near me, so it's probably a good comparison.
    Halsted and Hooptytrix[QUOTED] like this.
