  1. Apr 3, 2021 at 7:26 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    lol... [/furiously digging through trash]
    NUDRAT, CodyP, Voss and 2 others like this.
  2. Apr 3, 2021 at 7:36 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  3. Apr 3, 2021 at 7:37 AM
    Artisan crafted hahah
    I think that would follow along the lines of a hoopty trix
    Glock 40 likes this.
  4. Apr 3, 2021 at 7:38 AM
    Tundra2[QUOTED] likes this.
  5. Apr 3, 2021 at 7:39 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  6. Apr 3, 2021 at 7:40 AM
    You’ve got it aimed perfect it seems
    NUDRAT and Tundra2[QUOTED] like this.
  7. Apr 3, 2021 at 7:41 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I’ve been figuring ways to form this hose. I think slipping a few copper fittings (long 90°, and a couple 45°’s) over the outside of the 3/8” hose to achieve close form and then using a heat gun or some flame to meld the form into memory. Remove fittings and viola!
    des2mtn likes this.
  8. Apr 3, 2021 at 7:43 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It took me quite a few tries tweaking it.
    When I first got it I didn't understand that it was a beam/spot. It beams straight out but goes up and down. When I started lighting up the monkeys in the tree tops I thought something was wrong.
    I tweaked it a lot, and finally aimed it using a hill. Aiming that on a building just wasn't working out for me. :crazy:
    NUDRAT and FrenchToasty[QUOTED] like this.
  9. Apr 3, 2021 at 7:43 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I like this idea. Probably wouldn't be able to remove the fittings though. The bends are pretty abrupt.
  10. Apr 3, 2021 at 7:45 AM
    Fred
    Hand Protectors
    A little loving lube and some finesse works. The copper fittings don’t need to be on that tight. Just enough to get the bends close.
  11. Apr 3, 2021 at 7:45 AM
    Good idea, you could also go from the other side, pre bend a copper tube(same as ID of rubber) then insert into tube, then put the tube in oven or heat gun, then you know it’s not kinked inside, let it cool and remove “stint”
  12. Apr 3, 2021 at 7:47 AM
    Fred
    Hand Protectors
    Yeah good one. Lots of work bending a full length pipe without special bending tools. The fittings are cheap and you can return them when finished! Keeping things Low Dolla.
  13. Apr 3, 2021 at 7:48 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I need to figure out that damned relay box that keeps kicking my tired, cold ass.
    May take the ole girl out to one of my electrician buddies. My brain is fubar'd after work usually.
  14. Apr 3, 2021 at 7:52 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Better idea, this might be worth a try. Still... bending a copper tube of any diameter can be difficult without kinking. Maybe a solid copper wire that is 3/8" dia? Even braided copper wire might work... like battery cable.
  15. Apr 3, 2021 at 7:54 AM
    Fred
    Hand Protectors
    Nice one. I’d step it down in size smaller so you can slip it out.
  16. Apr 3, 2021 at 7:54 AM
    I bet you could find something on the curb side!
  17. Apr 3, 2021 at 7:57 AM
    Fred
    Hand Protectors
    Get some 1/4” or 5/16” braided cable and form the bends. Go to town with heat and then quench it in the Colorado Snow Drifts or an ice bath tub.
  18. Apr 3, 2021 at 8:02 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I don't think braided cable is rigid enough to do the job.
    This is some of the pin stock I use for knife making... might be the ticket. Comes in different diameters so can be downsized. https://www.makermaterialsupply.com...rod-copper-brass-stainless-steel-1pc-or-5-pcs
  19. Apr 3, 2021 at 8:07 AM
    Fred
    Hand Protectors
    Looks doable. Getter dun and report back. Maybe order a smaller diameter rod ‘just in case’ your 3/8” one doesn’t slip out the way you think it will once the bends are achieved.
  20. Apr 3, 2021 at 8:09 AM
    Fred
    Hand Protectors
    French Toasty idea about slow baking might be the best idea along with your rods. 300° for 3 hours. Throw some cookies in while you watch. Win win!
  21. Apr 3, 2021 at 8:11 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    This will be a back burner project unless my current fix fails. I'll add the pin stock next time I order knife making supplies, it's on the list. If I do it, I'll definitely post a pictorial. :thumbsup:
  22. Apr 3, 2021 at 8:12 AM
    I’d give the cookies to the neighbors you don’t like, I bet they have a interesting flavor....
  23. Apr 3, 2021 at 8:12 AM
    Fred
    Hand Protectors
    Make two and I’ll buy one for shipping!:rofl:
    Glock 40[QUOTED] likes this.
  24. Apr 3, 2021 at 8:14 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I'll give you 50% off dealership pricing! :spending:
  25. Apr 3, 2021 at 8:16 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I'll eat em... still can't smell or taste from the woo flu 5 months ago. They'll be delicious to me.
  26. Apr 3, 2021 at 8:17 AM
    Sounds like you and the hand jockey got a deal then!
  27. Apr 3, 2021 at 8:23 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    He'll get a cookie.
    And like it.
  28. Apr 3, 2021 at 8:24 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    ... and I'll send him a refrigerator magnet.
  29. Apr 3, 2021 at 8:29 AM
    Fred
    Hand Protectors
    Well I’ll do a little test run on some Tubing today with some removed old extra hoses from the TB Job.
    Going to drop my Spare Tire and Oil the last parts of the frame back there in the hard to reach areas. I found a Long Handle Paint Brush on the side of the road and used that last time for the middle frame areas between the front/back wheels and rear axle. She looks better than Showroom underneath right now with basic Grease and Oil (under $20 for full frame). Need to touch up BBQ Shpray the Muffler Tip due to drippings.
  30. Apr 3, 2021 at 8:33 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    DEW IT!
