New Guy here
Discussion in 'New Member Introductions' started by Rw429, Apr 1, 2021.
  1. Apr 1, 2021 at 6:12 AM
    Rw429
    Rw429 [OP] New Member
    Rob
    2017 Black Toyota Tundra SR5 Crewmax TRD Off Road
    Hi Everyone, just joined the site and hail from the DMV area, specifically Moco MD. I am a first time Tundra Owner of a 2017 Crewmax TRD off road. No mods yet but debating on adding the TRD dual exhaust any recommendations? I am a little OCD about my truck mechanically and listen or look for anything out of place as I used to own a Ford F-150 and was in the shop quite often which leads me here. Has anyone else heard a slight intermittent “chirp” from the engine bay ( passenger side) at cold start up? It only seems to occur in the winter or after a heavy rain, but even then not all the time. I assume belt but wanted to know if anyone else had or currently has a similar experience. Look forward to chatting with all of you. Thanks!
    YardBird likes this.
  2. Apr 1, 2021 at 6:12 AM
  3. Apr 1, 2021 at 6:12 AM
    Welcome from NY.
  4. Apr 1, 2021 at 6:21 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  5. Apr 1, 2021 at 6:29 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Hello NFG
    Rw429[OP] likes this.
  6. Apr 1, 2021 at 6:33 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  7. Apr 1, 2021 at 6:34 AM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    Hello from SOMD
  8. Apr 1, 2021 at 8:15 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  9. Apr 1, 2021 at 10:54 AM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Mine makes noise after rain when cold that sounds like what your describing. Only lasts a few seconds. And in Phoenix, rain and cold don't happen often. By the way, welcome from Phoenix
  10. Apr 1, 2021 at 3:53 PM
    Rw429
    Rob
    Thanks I appreciate it. Yeah so weird just does it once in a while. Either when very cold out here in MD or after heavy rains and only after sitting overnight. Did you ever get it looked at? I am assuming it may be the drive belt or tensioner but pretty sure it would do it all the time if so.
  11. Apr 2, 2021 at 12:49 PM
    AZ Red Nek
    Chuck
    It happens so seldom that it is impossible to tell what it is, or, when it is going to do it. It doesn't last long enough to get out of the truck, pop the hood and take a look. So I'm going to except it as one of life's little mysteries.
