Searching / slipping trans on 2021 Tundra.
Discussion in '2.5 Gen Tundras (2014-2021)' started by eagleguy, Apr 1, 2021.
  1. Apr 1, 2021 at 4:43 PM
    eagleguy
    eagleguy [OP] New Member
    I have noticed that the trans in my Tundra with 300 miles searches and feels like its delayed or slipping when going down hill and given gas into a turn. I had similar issues with my 17 Tacoma. Is this common?
  2. Apr 1, 2021 at 4:53 PM
    Txexplorer23
    Txexplorer23 New Member
    2020 Tundra Crewmax Platinum 4x4
    Transmissions don’t slip going down hills. Give it a little time and it will get use to your driving habits.
    Marshal likes this.
  3. Apr 1, 2021 at 4:59 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    A slipping trans feels like a slipping clutch. When you give it throttle the engine rpm will increase with an unequal increase in vehicle speed. Worse under heavy load.
    Do you mean a delay in throttle response or shifting? Every new car I have driven is like that.
  4. Apr 1, 2021 at 6:00 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I notice when mine is cold its a little slow to shift. There's a particular corner that I hit every morning going to work.
    Two turns out of the neighborhood and then down a steep hill to a light at the end. When I make a left turn at that light coming off the incline it takes the trans an extra beat to shift to second and its sort of sloppy/clunky. That's the only time I notice it doing anything weird. Once its fully warmed up and any other situations its fine.
    Oey12 likes this.
  5. Apr 1, 2021 at 7:15 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    Mine feels like a slip every day leaving work making a right turn and going down a hill. Only time it does it. A guy I work with has a Sequoia that does the exact same thing... must be normal. Don’t think trans temp has anything to do with it; when I leave my house in the morning, no “slipping” whatsoever.
  6. Apr 2, 2021 at 5:26 AM
    Kung
    KG, VA
    It's the computer learning, IMHO. Literally the ONLY time it might do it is if I've crept along slowly for a while, and then suddenly seek to give it a bit of gas (e.g., when I'm dropping off/picking up the rugrat @ school). It went away completely during recent service @ the dealership that required disconnecting the battery for a few hours.
  7. Apr 2, 2021 at 5:38 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It's the programmed shift logic.
  8. Apr 2, 2021 at 6:07 AM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    I also have this randomly when accelerating at slow speed on level ground after going down my sloped driveway. I just let off the gas and wait a few seconds and accelerate again and it's fine.
    Wynnded likes this.
