  1. Apr 1, 2021 at 3:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Trans-follicle.
    NUDRAT, FirstGenVol, Voss and 4 others like this.
  2. Apr 1, 2021 at 3:23 PM
    Lookin sharp, watch out moms!!!!
    NUDRAT, oscardog86, CodyP and 8 others like this.
  3. Apr 1, 2021 at 3:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Dating scene locally for fellas my age is learn how to be a step-dad, or be a cub.
    oscardog86, Thrussn, speedtre and 5 others like this.
  4. Apr 1, 2021 at 3:24 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Craig likes his hair short is the work gossip.
  5. Apr 1, 2021 at 3:27 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I've had a rumble in the front end of my sequoia for a while and finally tracked it down to a bad CV Axle. It's the driver's sides and so I'm thinking of replacing the needle bearing with the ECGS bushing while I'm at it. Two questions, the rumble is the same in 2wd and 4wd so I thought that meant my needle bearing was fine. Would you recommend I replace it anyway?
    Second question, ECGS sells a tool to install the bushing in https://eastcoastgearsupply.com/i-23994071-t7-5-t7-5-clamshell-bushing-installer-tool.html
    I've seen lots of videos where they use other things to punch it in. Is the tool worth it? (I could always add it to the loaner set @FrenchToasty offers when I'm done)
  6. Apr 1, 2021 at 3:27 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Craig no longer speaks to me after I intervened in one of his schemes.
    Legally, I can't discuss it further.
  7. Apr 1, 2021 at 3:30 PM
    Fred
    Hand Protectors
    We understand.
  8. Apr 1, 2021 at 3:32 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  9. Apr 1, 2021 at 4:09 PM
    So I have both the removal and insertion(proper?) tool/s for the bearing itself and the new seal.
    Yes the noise is supposed to go away in 4wd because it’s putting a load on the bearing and not letting it flop around.
    I replaced mine and it was probably fine, but it’s not that difficult of a job if your already in there. Oem seals and oem half shafts are your friend!
  10. Apr 1, 2021 at 4:32 PM
    rock climber
    Thanks!
    CVJ is about 6 miles away so I'm really lucky there.
  11. Apr 1, 2021 at 6:40 PM
    @Darkness those remflex gaskets are no fucking joke!!!! I got chub looking at the chub! Easily two quarters stacked; thick.
    image.jpg Well two pennies at least!
    easily 3-4 times thicker than OEM.
    Got lots of good torque runs from inside out, left the motor mount so I didn’t mess with alignment of the straight pipes.
    Started up and purred like a minx!!! Took it for a test run..........I had to have been loosing a crap ton of back pressure from my leaks, the front end lifts up so much more aggressively(#noswaybars)
    I was screwing around with a ice machine in between prepping the heads and waiting for the brown van to show up, 3 hours total, not bad!!
    I’m pumped to get some tick free miles out of the truck!!!
  12. Apr 1, 2021 at 7:08 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Remflex makes fantastic gaskets! I have them for every connection exhaust side of my truck possible. Even the header gasket where it mounts to the cylinder head.
  13. Apr 1, 2021 at 7:13 PM
    Thrussn
    Gabe
    NM
    Did a quick wash and wax after work today. I'm glad she still shines up!
    It's been 2 months since I had the camper shell painted so I figured it's time for me to put some wax on. This desert sun is no joke. I see vehicles less than 3 years old with peeling and oxidized clear coats.
    NUDRAT, RUSTYNUTS, hammeron and 10 others like this.
  14. Apr 1, 2021 at 7:23 PM
    The night before I installed my headers I ran into a random thread “don’t use oem gaskets with aftermarket headers” I was like yeah this is the first time reading this.....
    the remflex 1 3/4 gaskets fit perfect on the “1 5/8” JBA tube, I think their raised port widens the flange surface to 1 3/4 so it a great mate!
  15. Apr 1, 2021 at 8:07 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats awesome @FrenchToasty but hopefully you don't have to swap the driver side gasket for a while. At least if you do its an upgrade.
    I looked at my truck a bit more and the loop on the suicide door has. Shiny spot on top. Now I'm starting to wonder if the latch just needs adjustment after all.
  16. Apr 1, 2021 at 8:17 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Your truck looks nice! :thumbsup:
  17. Apr 1, 2021 at 9:16 PM
    Thrussn
    Gabe
    NM
    Thanks!
  18. Apr 1, 2021 at 9:42 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Finally put my Hid and Projectors in. Long time in the making, but definitely worth the result. Thanks to @SouthPaw for building them and as always Thanks @Darkness for the help with the randoms questions.
    1Silverback, 912, NUDRAT and 12 others like this.
  19. Apr 1, 2021 at 10:34 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Those are throwing pretty far! Nice.
    MS22 and jImmegart[QUOTED] like this.
  20. Apr 1, 2021 at 10:40 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Fixed :D
    MS22[QUOTED] and oscardog86 like this.
  21. Apr 1, 2021 at 10:59 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Just remember. 2 doors are better than 4 #RCLB
    MNtundra, RUSTYNUTS, Darkness and 5 others like this.
  22. Apr 2, 2021 at 4:36 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Looks good!
    MNtundra and jImmegart[QUOTED] like this.
  23. Apr 2, 2021 at 6:09 AM
    Fred
    Hand Protectors
    Never heard of this Remflex (looks beefy). I thought everyone around here was chubbing out on the Percy Gaskets?
    Now you know you want to tear back into that drivers side again and redo it.
    Stoked on this feedback.
  24. Apr 2, 2021 at 6:16 AM
    Fred
    Hand Protectors
    Good on ya for having that Denso Filter in there. Makes a big difference. I bought an STP (suppose to be quality) last time a few years ago before getting into the truck really good. The weight and feel of Denso is far superior.
  25. Apr 2, 2021 at 6:24 AM
    So Percy doesn’t make one for the vvti, they do for your motor.
    i will do the driver side one day, just not soon, maybe find something else to do in there while I’m doing the driver side. I think a lot of it was the flange modifications made. Even a guy at work just now was like dude it sounds totally different now, in a good way.
  26. Apr 2, 2021 at 6:24 AM
    Fred
    Hand Protectors
    Is this a New Line of Projectors coming from Southpaw? These are the best pics I’ve seen of his Projectors (assuming low beam in your one shot).
    Which harness did you use and how much was your total setup?
    speedtre and Pearl-snap like this.
  27. Apr 2, 2021 at 6:28 AM
    Fred
    Hand Protectors
    Nice. I might do this Remflex Gasket whenever I feel up to some self torture of Headers. :rofl:
  28. Apr 2, 2021 at 6:33 AM
    Pearl-snap
    Pearl-snap New Member
    The yellow fog lights look great. Are these available via a vendor or did you mod the lens covers?
    jImmegart[QUOTED] likes this.
  29. Apr 2, 2021 at 6:38 AM
    My hands will be fully healed in a week or so.......
    Worst one I did, was a piece of hot slag dropped down between my fingers as I was doing a two finger yoga pose; it burnt both fingers perfectly where it landed.
    I’m really glad I did the fancy Vband clamps for ease of removal of everything.
  30. Apr 2, 2021 at 9:36 AM
    Fred
    Hand Protectors
    Thats my look when I see someone Mangling something. :rofl:
    NUDRAT, NWPirate and speedtre[QUOTED] like this.
