Falcon shocks are coming!
Discussion in 'Suspension' started by mac10tuna, Nov 10, 2018.
  1. Mar 29, 2021 at 1:03 PM
    #331
    Blkdmax
    Blkdmax New Member
    Tennessee
    2021 Cement CrewMax 4x4
    Lol I think 3 years actually
  2. Mar 29, 2021 at 1:32 PM
    #332
    Black
    2014 Tundra Limited CrewMax
    I got right at 2 1/4” I started at 37” and am now at 39 1/4”.
    I used 3k mile TRD take off springs. I am guessing if I used my 80k limited springs I may not have gained as much.
    I used the level setting.
    TeraFlex used non TRD springs for their R&D.
    And yes the warranty is a 3 year warranty.
    I sent them an email this morning letting them know how happy I am with these shocks. Also asked if I could get a couple of the raised emblems they put on the rear shock reservoirs. I think they would look slick on my rear door replacing the Limited badge. But think the flat stickers they provide would look silly.
    I also suggested they highly look into providing a fully built coilover as it appears that would be folks biggest reservation to buying these here on the forums and FB. I am
    guessing it is likely the same across platforms.
    The ease of install for the DIYer is greatly diminished having to assemble them oneself.
    The Tundra springs are awfully stout and a wall compressor is pretty much a must for these springs.
    I am very happy with them and had time to snag a set of springs off FB fortunately.
    But had the Dobinson IMS been available in November when I ordered these I would have been hard pressed to get the Falcons simply because they don’t have the option to come assembled.
    Though reading in the Dobinson thread it sounds like some folks are getting a lot more height than advertised. Which is problematic so while certainly don’t regret my purchase I can’t say it would have been the same.
  3. Mar 29, 2021 at 1:41 PM
    #333
    18" TRD Off Road Wheels
    Pretty dead on, right here. Honestly, if these were pre-assembled I would have ordered them a year ago. I don't have a garage, and I am no mechanic, so the lack of a full coil assembly is a huge barrier for me.
  4. Mar 29, 2021 at 1:46 PM
    #334
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    https://teraflex.com/file/attachments/5e0e07b3b28dfc00790cd443.pdf
    GODZILLA[QUOTED] likes this.
  5. Mar 29, 2021 at 3:51 PM
    #335
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    Hmm, it looks like there is some conflicting information.
    https://teraflex.com/policies
    EDIT: Nevermind, I read the wrong section. They are 3 years as posted by @John175.
  6. Mar 29, 2021 at 5:50 PM
    #336
    French Avocado
    Utah / Wyo
    Is there a difference in the OEM springs on the TRDs, Platinum, Sport and Pro models - and even DC or CrewMax? Seems like Toyota lists a number of different versions of the coils. I may be reconsidering my thought of using my platinum coil springs.
  7. Mar 29, 2021 at 5:53 PM
    #337
    I can't spead for the PROs, so not counting those, all the others are shock tuning as I understand it. The Trucks above are all the same in the front end, to a large degree, so having the same springs up front would make sense. This is purely my brain's logic, so I could be wrong, but I think the springs are the same.
  8. Mar 29, 2021 at 6:06 PM
    #338
    French Avocado
    Utah / Wyo
    Has anyone approached TeraFlex about a group buy on Falcons? I may try calling them and seeing if we can put together a group buy that will tantalize Adam enough to buy with us.
    AggiePhil and LarryDangerfield like this.
  9. Mar 29, 2021 at 6:15 PM
    #339
    Black
    Yes. The TRD springs are slightly stiffer than the non TRD models.
    There is a difference as well between regular, double, and CrewMax.
    Of course the TRD Pro springs are very much different since they utilize Bilstein or Fox setups dependent upon year.
    When I spoke with TeraFlex about it they said they R&D’d with non TRD springs but likely one would never be able to tell a difference if one used TRD springs.
    They ride great using TRD springs since that is what I have.
    RobertD likes this.
  10. Mar 30, 2021 at 5:03 AM
    #340
    Blkdmax
    Blkdmax New Member
    Tennessee
    Anyone know what valving the falcons have? Linear, progressive, digressive? I can’t seem to find that info anywhere.
    Icon and 6112s have digressive and ride pretty rough on the road. Hoping to avoid that again with the new truck.
  11. Mar 30, 2021 at 5:09 AM
    #341
    Black
    Technically none of the above.
    It is Volume Optimized Dampening.
    Uses numerous different things other shocks don’t do get the best all around ride.
    Digressive liner valving, with progressive bump stops, and Zone Rate Tuning.
    Ride on the road is far more comfortable than the Fox and Bilsteins I have had.
    SR5BRAH and Blkdmax like this.
  12. Mar 30, 2021 at 6:21 PM
    #342
    French Avocado
    Utah / Wyo
    Kudos @Black - Now that is really sexy talk -
    I read the words that seem to make sense and I have no idea what is says, except they work differently and the ride is better. "Digressive linear valving" really cinched it for me.
  13. Mar 30, 2021 at 6:58 PM
    #343
    Black
    I paraphrased. You can read all the technical mumbo jumbo here.
    https://www.falconshocks.com/falcon-performance-shocks-philosoph
    I can just tell you that I am super impressed with how this truck rides now so whatever they did they did it right!
  14. Mar 30, 2021 at 8:14 PM
    #344
    French Avocado
    Utah / Wyo
    @Black I am impressed with your knowledge and understanding. You have me convinced. Because I am here in Utah and close to TeraFlex, I am going to see if we can do a group buy on the Tundra Falcon Sport Tow/Haul kit.
    hooter, Blkdmax, Elduder and 2 others like this.
  15. Mar 30, 2021 at 9:33 PM
    #345
    If they do a good deal I'll have to do it..... son of a bitch. :annoyed:
  16. Mar 31, 2021 at 4:38 PM
    #346
    hooter
    hooter New Member
    2019 SR5 TRD Off Road Crewmax
    I’d be in for a set if there was a group buy.
    GODZILLA likes this.
  17. Mar 31, 2021 at 4:39 PM
    #347
    French Avocado
    Utah / Wyo
    TeraFlex will not do a direct group buy because they do not want to compete with their distributors.
    HOWEVER, I am talking to a distributor that is very interested in doing this group buy and perhaps others. Stay tuned. (Adam start saving)
  18. Mar 31, 2021 at 4:40 PM
    #348
    French Avocado
    Utah / Wyo
    Okay friends - just out of curiosity how many would buy if we obtained a good deal on a group buy?
  19. Mar 31, 2021 at 5:14 PM
    #349
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
    Most likely yes. Definitely without a doubt if they come pre-assembled tho.
  20. Mar 31, 2021 at 5:17 PM
    #350
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    At the moment I already spent too much on my truck so it would have to be a very good deal for me to jump in. Like 25% off kind of deal.
  21. Mar 31, 2021 at 6:46 PM
    #351
    Utah isn't a far drive, so if they are close enough I can save shipping and get a good deal... yeah, I'd have to do it. These are the suspension I want, so a deal would force my hand.
  22. Mar 31, 2021 at 6:52 PM
    #352
    French Avocado
    Utah / Wyo
    More news tomorrow - where are you in Wyoming?
  23. Mar 31, 2021 at 6:58 PM
    #353
    That's privileged information. :p
    When I said it's not far I just meant I have friends in SLC so visiting there happens anyway.
  24. Mar 31, 2021 at 7:03 PM
    #354
    French Avocado
    Utah / Wyo
    I have many ties to Wyoming and travel there often.
  25. Mar 31, 2021 at 7:11 PM
    #355
    K9Lonzo
    K9Lonzo New Member
    Kris
    2019 Silver Sky Platinum
    I’m about to pull the trigger on a set of Falcon tow/hauls based off of the reviews, so I’d definitely be in for a group buy. Greatly appreciate you looking into that I think there are a lot of people that would be interested.
  26. Mar 31, 2021 at 7:12 PM
    #356
    I think there might be more response to a new thread with title being about a group buy. I know that lots looked at this thread, but don't necessarily come back to it.
    LarryDangerfield likes this.
  27. Mar 31, 2021 at 7:18 PM
    #357
    French Avocado
    Utah / Wyo
    If I get it set up then I will do a new thread to make sure we get the participation needed for the maximum discount.
    Saltyhero13, GODZILLA and Pbed85 like this.
  28. Apr 1, 2021 at 6:27 PM
    #358
    French Avocado
    Utah / Wyo
  29. Apr 2, 2021 at 3:55 AM
    #359
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Saltyhero13 and GODZILLA like this.
  30. Apr 6, 2021 at 6:40 PM
    #360
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Anyone run these at stock height yet? I am very tempted by the group by.
