DSP amp
Discussion in 'Audio & Video' started by crewmaxlmt, Mar 31, 2021.
  1. Mar 31, 2021 at 2:38 PM
    crewmaxlmt
    crewmaxlmt [OP] How dare you!
    scott
    2020 Crewmax Limited
    Is there a point to running a DSP amp if you already have to run a DSR on the JBL system? The only benefit that I can see is being able to control a downstream amp that is hooked into the outputs.
  2. Mar 31, 2021 at 2:45 PM
    Elduder
    Elduder New Member
    It depends on the units used, whether the software for the amp is better than the DSR1, lots of variables.
    However, each additional unit added to the system increases the probability of increased noise floor, aka the static hiss.
    Saltyhero13 likes this.
  3. Mar 31, 2021 at 2:51 PM
    crewmaxlmt
    scott
    That's what I thought. Thank you for clarifying.
    Elduder likes this.
