Radiator Overflow
Discussion in 'General Tundra Discussion' started by Rex Kramer, Mar 8, 2020.
  1. Mar 30, 2020 at 5:45 PM
    Rex Kramer
    Rex Kramer [OP] Vinyl Spinner
    Georgia
    That foam strip was missing when I purchased the truck... I'm sure it served a purpose, but what was that purpose?
  2. Mar 30, 2020 at 6:16 PM
    15whtrd
    15whtrd Mr. Blonde
    It helps to keep the air directed through the radiator instead of up and over.And probably for a little isolation between it and the support.
  3. Mar 30, 2020 at 6:20 PM
    Rex Kramer
    Georgia
    Makes sense... I can't find it in any parts diagram though, so I would have to use weather stripping of some kind.
    15whtrd[QUOTED] likes this.
  4. Mar 30, 2020 at 6:39 PM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Just for kicks I'd put some weatherstripping foam in there and see if that does impact the engine temperature underway at load.
  5. Mar 31, 2021 at 6:19 AM
    C_Rent17
    C_Rent17 New Member
    Colin
    2001 Limited 2WD Tundra V8
    Curious where you ordered the TRD cap from?
