Please don’t kill me... 35’s on my stock wheels?
Discussion in 'Wheels & Tires' started by offshore2005, Mar 31, 2021.
  1. Mar 31, 2021 at 6:01 AM
    offshore2005
    offshore2005 [OP] New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    Wanting to step it up in tire size but I like my wheels. It is possible to keep them and run 35’s?? What will be needed to make this happen?? Currently I just have 5100's with 295/55/20 Cooper STT Pro's. Wanting to run 35” in the same tire. Is it even worth it or not?
    JDimaggio4x2 likes this.
  2. Mar 31, 2021 at 6:07 AM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    I am able to run 285/75/18 (narrow 35’s) on a stock Bilstein TRD PRO suspension no modding except removal of front mud flap) Unsure if this will help you or not.
  3. Mar 31, 2021 at 6:23 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    You're probably going to rub on your UCA. Also on the fender liners and body mount. Possibly elsewhere too.
    You can use wheel spacers to avoid the UCA rubbing, but that will increase rubbing on the other two areas.
    If you're comfortable trimming and adding wheel spacers you can make it work for street use. Offroad or with extreme suspension flex you are probably going to still have contact in the top of the wheel wells... the kind that slices tires up. The solution here would be more lift.
    BravoDeltaRomeo likes this.
  4. Mar 31, 2021 at 6:24 AM
    Kanobi13
    Kanobi13 New Member
    Offset on wheels?
  5. Mar 31, 2021 at 6:34 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Running a ~2.5" inch lift should give him the clearance he needs, correct? Alongside running a skinny tire (11-11.5") right?
  6. Mar 31, 2021 at 6:37 AM
    Backslider
    Tooele, UT
    35s are 35x12.5 xwheel diameter.
    If he's not running actual 35s it might work, though I bet he still runs on pinch welds when flexing.
    I run 295/70r18 with a 3.5" loft and had to do a good amount of trimming, including the pinch weld and BMC, and of course mud flaps and front fender liner...
  7. Mar 31, 2021 at 6:45 AM
    offshore2005
    TEXAS
    How can I find this?? I have tried to find info on the web but can’t.
  8. Mar 31, 2021 at 6:46 AM
    offshore2005
    TEXAS
    I was thinking a 3-1 lift but just wanted to know if I could keep the stock wheels. Guess I will need to figure out the offset.
  9. Mar 31, 2021 at 6:55 AM
    joseph_womack
    Joe
    Louisiana
    You can always just get spacers
  10. Mar 31, 2021 at 6:59 AM
    offshore2005
    TEXAS
    No I will never run spacers. I had them on my last truck and had studs twist off over time more than once.
  11. Mar 31, 2021 at 7:03 AM
    Backslider
    Tooele, UT
    I hope this doesn't sound disrespectful, but if you use a quality spacer and install them properly this won't happen again.
    joseph_womack likes this.
  12. Mar 31, 2021 at 7:06 AM
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    It's on the inside of the wheel. Those T-Force wheels are 20x9 +50mm offset
  13. Mar 31, 2021 at 7:10 AM
    offshore2005
    TEXAS
    It’s all good. They were in a Ford F-1shitty
    They were a very good quality and installed to spec. Another reason I will not run them, no company will rotate and balance the tires.
    YotaBro and joseph_womack like this.
  14. Mar 31, 2021 at 7:11 AM
    offshore2005
    TEXAS
    Well dang now I feel stupid. I will look when I go home for lunch. Thanks!!
  15. Mar 31, 2021 at 7:24 AM
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    I’ve run spacers for years without any issues. Also, Toyota rotates my tires on every service visit with no questions at all.
