  1. Mar 30, 2021 at 10:49 AM
    speedtre
    speedtre New Member
    Inland Northwest
  2. Mar 30, 2021 at 12:41 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Spent some dinero today.
    T100 Brake Booster and master cylinder, Bosche ESI6-32N brake fluid, Powerstop GX460 14WA front brake calipers (Not OEM because red=faster), Akebono brake pads, oem GX460 anti-squeal brake pad shims, and black zinc coated drilled and slotted rotors.
    I found a local machine shop that is willing to do the machining on the caliper ears to make them a direct bolt on.
    I'll be sure to take pics once I'm putting on the parts!
    theblurry1, oscardog86, Voss and 5 others like this.
  3. Mar 30, 2021 at 12:46 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Nice! Maybe start a dedicated thread? as you seem to be doing yours from ground up with the BB and MC modifications. Could be a good place to refer back to for future reference.
  4. Mar 30, 2021 at 12:55 PM
    speedtre
    speedtre New Member
    Inland Northwest
  5. Mar 30, 2021 at 1:03 PM
    Thrussn
    Gabe
    NM
    Alright. I've never made one before, but I'll do my best lol
  6. Mar 30, 2021 at 1:16 PM
    Fred
    Hand Protectors
    Yeah! The good, the bad and the ugly... we want it all. :rofl:
    Seriously, your thread will clear up lots of uncertainty and give an idea of total cost from scratch. Seems like you’ve gotten some quality new parts and maybe used as well?
    Tundra2, speedtre and Darkness like this.
  7. Mar 30, 2021 at 1:30 PM
    Would just like to see the successful install of a T100 master. Yours with ABS? Love to hear the change in pedal effort.
  8. Mar 30, 2021 at 1:48 PM
    Thrussn
    Gabe
    NM
    All new parts on my end. The cheapest I went was on the brake booster and MC. I bought them as remans that were from companies that seemed to have really good reviews. I'll be sure to put a thread together and you can all witness my eternal struggle (or lack thereof).
  9. Mar 30, 2021 at 1:50 PM
    Fred
    Hand Protectors
    You will succeed! Even if it costs an arm and a leg and tons of headache inducing time. :rofl:
    Tundra2, speedtre and Thrussn[QUOTED] like this.
  10. Mar 30, 2021 at 1:52 PM
    Thrussn
    Gabe
    NM
    That's 100% my style with any mod that takes more than 30 minutes to do lol
  11. Mar 30, 2021 at 1:57 PM
    Fred
    Hand Protectors
    Drained about a quarter of a quart out of the Transmission as I slightly over filled her a few weeks back. I’ve always slightly under filled and then added as needed to just above top tick. Did some quick Hand Jives with the Drain Plug Drain Off with success. Got some on me now I thing I might have the Black Lung.
    CodyP, Tundra2, Darkness and 2 others like this.
  12. Mar 30, 2021 at 2:38 PM
    speedtre
    speedtre New Member
    Inland Northwest
    :thumbsup:
    MS22, Tundra2, Darkness and 4 others like this.
  13. Mar 30, 2021 at 2:47 PM
    Fred
    Hand Protectors
    You’re more dead to me than your dead mother! Just glad she didn’t live to see you as a Mermaid.
    Merman!
  14. Mar 30, 2021 at 5:09 PM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    Just measured, the house is 24' 11" wide and my truck is 19' 3/8". Good eye. Haha
  15. Mar 30, 2021 at 5:25 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    OEM Denso spark plugs x8
    found oil on plug threads during change
    Diff drain and fill 80w90 valvoline. RWD
  16. Mar 30, 2021 at 6:02 PM
    taranovich92
    taranovich92 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Nitto TerraGrappler G3 285/70/17, Apple CarPlay, CB radio, Randy Ellis Design front bar, Hella 500 rally lights, Mini LED projector headlights, Trailrunner Customs fogs, SkidRow Offroad skid plate, 333 Fab steering rack clamp.
    came with the TRD Sport package, atleast mine did haha .
    NUDRAT and Voss[QUOTED] like this.
  17. Mar 30, 2021 at 6:19 PM
    I originally bought the lift mate for my mom(the high lift was passed down, maybe from grandpa that I never met?) for leveling her trailer when she gets to a spot, I don’t know if the trailer wasn’t hooked up, but it felt super sketchy and it seemed like a lot of weight for the high lift. My floor jack has been acting up and one piston won’t return, royal pain, so I tried the setup on the truck, it actually wasn’t to bad!
    D7ECE77B-3B0C-4C04-867A-BE8664C66FAC.jpg Made in Indiana!
  18. Mar 30, 2021 at 6:43 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I got one of these setups after watching someone use it to pop a dug-in tire out of the sand. Fits pretty well around the wheel spokes but still a little scary.
    oscardog86 likes this.
  19. Mar 30, 2021 at 7:04 PM
    It fits my spokes perfect to have the pad land on the rim-ish area.
    It definitely needs more accessories or roadside finds to actually change a tire or prop up the control arm, but like you said I bet it would work great getting a tire out on top of the sand.
    Seems the sketchy part is if the jack or the vehicle move; as long as you can keep those things stable, it’s a great tool.
  20. Mar 30, 2021 at 8:51 PM
    Where do you buy a lift system like this? It couldn't be cheap, but definitely cool that you can work outside with it.
    MS22, artsr2002, NUDRAT and 2 others like this.
  21. Mar 30, 2021 at 11:05 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Blacked out the grill
    theblurry1, MS22, fighthedude and 7 others like this.
  22. Mar 30, 2021 at 11:48 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    We just bought a 4 set of those for work. Steri Koni
    Flexible to lift things like water tenders and fire engines that have a variety of axle spread where a normal lift couldn’t spread wide enough. And moveable to keep the floor clear when not needed
  23. Mar 31, 2021 at 3:28 AM
    06tacomadc
    06tacomadc New Member
    Motor City
    Tundra
    Nice rig! What lift and wheels and tires are you running?
    jerryallday[QUOTED] likes this.
  24. Mar 31, 2021 at 6:09 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Thank you.
    6112 in the front, 5100s in the rear with icon add a leaf and Camburg UCA. About 2.5 inch lift. Ko2 tires 285 on 17 method 305 nv with the updated center caps.
    Also: there was heavy trimming done to fit the 285’s and I rub on the frame at full lock to the left only. Wheel spacers arrived today so that should help.
    Darkness and Voss like this.
  25. Mar 31, 2021 at 6:15 AM
    06tacomadc
    Motor City
    Tundra
    Did you reuse your trd coils? I’ll be interested to hear about spacers, 1.25”?
    By the way how does it ride?
  26. Mar 31, 2021 at 6:38 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Oh, you can also try putting Tuco’s bed back there to establish the area as his spot...
    Darkness[QUOTED] likes this.
  27. Mar 31, 2021 at 6:41 AM
    Fred
    Hand Protectors
    Or bury a treat in one of the storage holes. :rofl:
    Darkness and Voss[QUOTED] like this.
  28. Mar 31, 2021 at 8:33 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    no, I didn’t reuse the old coils, 6112s come with new coils. I think it rides great, a little stiff but def not as bouncy compared to the stock15 year old shocks. I do have some body roll, and driving on windy days is not so fun.
    I order extended sway bar end links, that should arrive in the next 2 weeks to help with some body roll. Current links are smoked.
  29. Mar 31, 2021 at 8:55 AM
    Is it just grabbing the wheel? How does it do that without damaging the wheel?
  30. Mar 31, 2021 at 8:58 AM
    It has two rubber coated hooks, and then a flat rubber pad that is supposed to rest at the top of the rim
