Rear sway bar on 6” lift
Discussion in 'Suspension' started by Bull, Mar 28, 2021.
  1. Mar 28, 2021 at 6:01 AM
    Bull
    Bull [OP] New Member
    Hello, I would like to install the TRD rear sway bar on my 2020 SR5 4x4 tundra. The truck has a 6” lift kit on it. I’m concern if I will need the sway bar links to be longer since the truck has lifted.
    Any recommendations? Also would like to know best deal on sway bar out there.
    Prostar 190 likes this.
  2. Mar 29, 2021 at 1:45 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    This topic has come up before. If I remember correctly, YES, you can install the TRD rear sway bar with the OEM links on your 6" lifted Tundra, but your articulation will be limited, if you do that sort of off-roading. I'm sure others will chime in, but I'm pretty confident about the OEM length links. Sorry, can't help you find a better deal on the sway bar itself.
    GNTundra likes this.
  3. Mar 29, 2021 at 2:11 AM
    GNTundra
    Gino
    2013 White
    6" lift here and TRD swaybar
  4. Mar 29, 2021 at 3:42 AM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    Did you have the sway bar before the lift, or did you add it after? Just curious if it was a later addition, and if you noted any real improvement. I just added a 6-inch lift to mine, and had been considering whether or not the sway bar might give me a benefit.
  5. Mar 29, 2021 at 4:00 AM
    I have a 6" lift and put a Hellwig sway bar with there extended links for lifted trucks. PXL_20201014_221941856.MP~2.jpg
    jeremyd likes this.
  6. Mar 29, 2021 at 1:11 PM
    hotchops777
    hotchops777 New Member
    Matthew
    EAST TEXAS
    2011 5.7 Silver Sky DC
    6" Procomp Stage 2 lift Black Rhino Sierra 20x10 0 offset on 325x65x20 Nitto Ridge Grapplers Smitty Built M1 front grill
    @Prostar 190 Sweet looking rig man!
    I have a DC silver sky w/ 6inch lift and am looking to put a hellwig on my rear. Can you tell me how much of a difference it added and what setting did you go with?
  7. Mar 29, 2021 at 3:11 PM
    Thanks
    The truck handles night and day different to me and wished I had done it sooner. When I first installed it I put it on the farthest hole out and was happy with the outcome so I've never changed it.
    hotchops777[QUOTED] likes this.
