2006 DC Dash Lights
Discussion in '1st Gen Tundras (2000-2006)' started by 2006Tundra, Mar 28, 2021.
  1. Mar 28, 2021 at 5:10 PM
    2006Tundra
    2006Tundra [OP] Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Hey, Guys.
    Today I got started with changing out my dash lights on my 06 DC. I took everything apart and it looks the factory LED diodes are soldered onto the electronic board.
    Has anyone with a 06 DC changed out the lights behind the dash? I've looking around to try to see more of the inside without risking damage but all I see are LED diodes, no lamps.
  2. Mar 28, 2021 at 5:21 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    05/06 are LED soldered directly onto the board.
    You can change them if you have soldering skills. If you just want white you can wet sand the 'green' off the back of the gauge face.
  3. Mar 28, 2021 at 5:25 PM
    2006Tundra
    Lou
    Long Beach, CA
    How did you peal the back off? I didn't want to pull the gauge arms off because I was afraid of breaking them.
    Do you have a link to the post of the pictures?
  4. Mar 28, 2021 at 6:16 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Slide a fork behind the needles and slide/pull them straight up.
    I'd recommend taking a picture before hand, for reference when you install the needles for the correct positioning.
    When reinstalling put them on a few mm and then rotate them to the correct position, then push them down. Putting the fork behind them when pushing down will keep them from going too far.
  5. Mar 28, 2021 at 6:21 PM
    2006Tundra
    Lou
    Long Beach, CA
    One more question, What grit sand paper do you recommend?
  6. Mar 28, 2021 at 6:22 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    I used 600, others have used 400.
    2006Tundra[OP] likes this.
  7. Mar 29, 2021 at 10:26 AM
    2006Tundra
    Lou
    Long Beach, CA
    @assassin10000
    Is the green part paint? I wonder if using paint thinner would work.
  8. Mar 29, 2021 at 1:03 PM
    Professional Hand Model
    Fred
    Hand Protectors
  9. Mar 29, 2021 at 2:36 PM
    2006Tundra
    Lou
    Long Beach, CA
    Hahaha, well, I didn't use paint thinner. I used 600 grit sand paper to wet sand. It came out very nice, can't wait to see how it looks at night.
  10. Mar 29, 2021 at 2:41 PM
    Fred
    Hand Protectors
    You’ll be stoked.
  11. Mar 29, 2021 at 3:46 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Pics?
  12. Mar 29, 2021 at 3:53 PM
    2006Tundra
    Lou
    Long Beach, CA
    I'll post some when it gets dark but I'm pretty sure its going to look like post #2
    KarmaKannon[QUOTED] likes this.
  13. Mar 29, 2021 at 4:12 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Would not recommend. You don't want to remove the other coatings or damage the plastic face.
  14. Mar 30, 2021 at 11:23 AM
    2006Tundra
    Lou
    Long Beach, CA
    @assassin10000
    Hey, so I took pictures of my needles before taking them off. When I went to put them back on they have been off. I've been adjusting them and I think I go them pretty accurate. Did you run into this issue after install?
  15. Mar 30, 2021 at 11:40 AM
    Used to be a problem when doing gauge faces on the old Cheby's in the 90's. You would have to warm the truck up and take a picture or mark where the gauges were. Then after removing the needles, warm the truck back up and replace where they went. Otherwise they are resting on the needle stops and not truly in the correct position. No needles stops on these, but having the vehicle in a predictable phase of operation may make it easier to get the needles where they go. Maybe someone else can send a shot of their same model in a warmed up state and you can use that as a reference.
  16. Mar 30, 2021 at 12:17 PM
    2006Tundra
    Lou
    Long Beach, CA
    Interesting. Well, my truck just got dropped off at the body shop to be painted. Once I get it back, I'm going to confirm again. I'm pretty confident they're in the right place after some adjusting.
  17. Mar 30, 2021 at 8:30 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    I think I had to redo just one. The voltage gauge was a bit off.
    No big deal. Can be redone an infinite amount of times... or until it breaks lol.
  18. Mar 30, 2021 at 8:52 PM
    KarmaKannon
    Utah
    Some junk
    I just took a picture and out mine back where if looked like they went. I think only pulled a couple off because it was an exploratory mission. My gas gauge now reads about 63/64ths when it's full. I'm alright with that. Better than the other way.
  19. Mar 31, 2021 at 12:05 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    [​IMG] this is what i did for mine.. ive been happy. in person the whites a wee bit warm. but it looks good enough for me.
  20. Mar 29, 2023 at 9:30 AM
    Ilyatkachev26
    Ilyatkachev26 New Member
    Ilya
    2006 tundra double cab
    33inch wheels
    Can somebody post a YouTube video of
    This process ? Looking to do mine
  21. Mar 29, 2023 at 9:44 AM
    You just need to get the gauge cluster out, and disassemble to the point the face comes off. Then wet sand away the green coating. Careful with needle reinstall. It'll look like this, taken from TS, when you sand away the back of the lens - and this person went overboard, sanding away everything. Dan was more selective.
  22. Mar 29, 2023 at 9:47 AM
    Oh, and some other details from @Tundradrenalin's post over there:
    Remove the odometer bezel.
    Remove the needles.
    Remove the odometer screen.
    Sand the green areas off with some 400-800 grit sandpaper or 00 steel wool.
    Test with a flashlight as you go.
    If you want, you can change the color of the screen with color film. Or blackout portions with dark window tint (like I did for the km/h).
    Reassemble your dash in reverse order.
    FYI, the rpm, mph, battery and temp gages will not read correctly if you replace the needles incorrectly. It may be easier to replace those needles while engine is at idle.
    I have a ScangaugeII that I used for replacing the needles accurately. Most others that try this without the Scangauge do it differently. They take pictures of the gauges at normal operating temps and then replace them as so afterward. Replace the needles with the engine running. And take the pics with the engine running! lol. I didn't do that at first and regretted it later with panic. But with the SGII I figured it out.
    This video shows the trick to removing the cluster, with regard to the clip related to the bezel:
    KNABORES likes this.
  23. Mar 29, 2023 at 10:28 AM
    Oh, and I guess I should drop this PDF here too, since it shows the general process.
    G_unit3000 likes this.
  24. Nov 27, 2023 at 11:42 AM
    PsyGuy
    PsyGuy New Member
    I’m looking to change the color to Orange. Has anyone used a paint of some kind? Seems like the majority of the posts I’ve found reference sanding and sticking with the white look.
  25. Nov 27, 2023 at 12:07 PM
    You really have two options I can think of which would be most effective:
    • Remove/re-solder new orange LEDs on the OEM board, and hope you don't eff something up, but you'll probably need to follow sanding approach in reply #21 to get the full effect, so you're not mixing orange and green
    • Follow the sanding approach shown in reply #21, then creatively cut some orange lighting gels typically used with stage lighting to secure over the sanded area
    I would never attempt to paint/dye the front of the gauge cluster, and if you tried to die the sanded area, I'd be worried about it running/bleeding into areas you don't want orange.
    Edit: Here's what I mean about stage lighting gels: https://www.amazon.com/theatrical-gel-sheets/s?k=theatrical+gel+sheets
    PsyGuy[QUOTED] likes this.
  26. Nov 27, 2023 at 1:48 PM
    OverSquareEng
    OverSquareEng New Member
    2006 Sequoia Limited 4WD
    An amber laminx might do the trick.
    https://lamin-x.com/one-8-x-8-universal-film-cover.html
    PsyGuy[QUOTED] and shifty` like this.
  27. Nov 27, 2023 at 2:08 PM
    OverSquareEng
    Ahhh that's what a gel is. Thought it was a paint on thing...
  28. Nov 27, 2023 at 2:10 PM
    Nah, basically just a tinted sheet. What you posted may be the same thing but with adhesive.
    We used gels for stage stuff bitd. Need to change the color of a stage light? Pull the cover, slide in the gel sheet color you want to, reinstall cover. Easy peasy. Nowadays everything is multicolor LED, so you just push a button and *POOF*
