The Firetruck build
Discussion in '2.5 Gen Builds (2014-2021)' started by pearlpower, Mar 18, 2021.
  1. Mar 18, 2021 at 6:08 AM
    pearlpower
    pearlpower [OP] New Member
    2014 CrewMax in Radiant Red
    Deleted
    Ely010606, Rica25, RRR1C0 and 4 others like this.
  2. Mar 18, 2021 at 6:15 AM
    Kung
    KG, VA
    So evidently I'm dumb - I didn't even know there was a bright red Tundra color. Looks sexy as hell! Mind sharing some of your mods (especially the lift)?
    Rica25 and pearlpower[OP] like this.
  3. Mar 18, 2021 at 6:44 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    I can't tell if it's Inferno or barcelona red. I'm leaning Inferno.
  4. Mar 18, 2021 at 8:08 PM
    Elduder
    Elduder New Member
    Radiant Red, only ran for 1 or 2 years on the 3rd gen I think.
    Black Wolf likes this.
  5. Mar 26, 2021 at 4:46 PM
    rustytoys
    rustytoys New Member
    So there is no safety Cotterpin anymore on the JBA ball joint nut, or is the angle of the pic hiding it?!
  6. Mar 26, 2021 at 4:51 PM
    Elduder
    Elduder New Member
    Nylock nut, essentially does the same thing, just dont reuse nylock nuts.
    rustytoys[QUOTED] likes this.
  7. Mar 26, 2021 at 5:01 PM
    rustytoys
    Interesting, guess thats better than nothing - but no way I'd bet my life on a piece of nylon plastic personally... My tubular UCA's re-used the factory nut & cotter pin, had no idea JBA did this. Thanks for the info.
  8. Mar 26, 2021 at 5:09 PM
    Elduder
    Elduder New Member
    Theyre both mechanical locks. You do bet your life on it though, so to speak, at least assuming youve been on a plane. Nylocs are used for fasteners on airplanes.
  9. Mar 26, 2021 at 7:55 PM
    rustytoys
    In my experience anything of importance on aircraft is generally wired; however, keep in mind they also receive regular inspections too - unlike automobiles.
  10. Mar 26, 2021 at 8:21 PM
    Elduder
    Elduder New Member
    Seats, inner doors used nyloc on paneling and mount points.
  11. Mar 27, 2021 at 7:23 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
  12. Mar 27, 2021 at 9:32 AM
    SnowB0und
    SnowB0und New Member
    2013 SR5
    What did the MOOG lowers get you? We’re yours worn out?
  13. Mar 27, 2021 at 12:50 PM
    rustytoys
    I understand this, but its just not a fair comparison - as you are talking about aircraft which are constantly inspected by highly trained mechanics, who have to prove on paper that they ordered a new nyloc nut during a maintenance cycle.
    It just doesn't seem like a smart move to use a Nyloc on an automotive upper control arm, in which down the road some kid will buy the truck - and maybe he will change the struts - you really think he is going to know and/or special order a new Nyloc spec'd to that ball joint? Its not going to happen, it will be re-used and any future owner will be risking their lives driving the truck.
    I realize the odds of a Nyloc nut falling off on the freeway are likely very low, but why take the chance? What is the upside? As I said, my control arms (which I don't even like all that much) were able to use the factory Toyota nut which is secured with a cotter pin - so why can't other manufacturers do that too?
    I also looked into Nyloc nut use on aircraft and found this fascinating article (for anyone who is really bored...)
    https://code7700.com/case_study_eurocopter_as350-b2_n37sh.htm
    This aircraft used Nyloc nuts, but it was designed as a redundancy - so the Nyloc's used Cotter Pins too; this helicopter company apparently re-used their Nyloc's (against Eurocopter spec) resulting in them being useless - and then a mechanic most likely forgot to put a cotter pin through the used-Nyloc - this resulted in the helicopter crashing and killing all five people. A simple cotter pin would have prevented this according to the helicopter manufacturer:
    "Eurocopter stated that even if the bolt and nut were improperly torqued or the nut [Nyloc] was degraded, the split pin should have prevented the loss of the nut."
    Elduder[QUOTED] likes this.
  14. Mar 27, 2021 at 3:16 PM
    Elduder
    Elduder New Member
    Good stuff, thanks.
    I suppose if anyone is concerned or has time there are 195 pages of Tacoma dudes running these with pretty much no major issues. Could search or ask about the nyloc nuts there. I searched but found no issues with the ball joint nut nyloc nut mentioned.
    https://www.tacomaworld.com/threads...pension-mega-thread-bs-thread.364484/page-192
  15. Mar 27, 2021 at 5:20 PM
    rustytoys
    Yes, but the risk is really several years down the road - that second and third owner who choose to change the strut and who re-use the Nyloc nut out of ignorance; a cotter pin nut makes things black & white for the less skilled. JBA is still fairly a new company, give it a decade and lets see how all these Taco's running around with used-Nyloc's are doing...
  16. Mar 27, 2021 at 6:53 PM
    Elduder
    Elduder New Member
    Agreed, but by that statement, any assumption that they would fail is equally as valid as the argument that they wont, so long as we discount that they haven't failed yet. Lest you can provide evidence otherwise. At present there are people running JBAs on their Tacomas for 6 years now, so far it hasnt been an issue.
    Also, JBA has been around for about 17 years now.
  17. Mar 28, 2021 at 6:55 AM
    rochmpr
    rochmpr New Member
    Krister
    Walnut Grove, CA
    2020 CrewMax
    Lifted, sliders, 35 X 12.5's, Evo Corse and more stuff coming
    Many other name brand, well known companies use a nylock nut on the UCA to spindle bolt. This is very common in this industry. I would hope that people regularly do a visual inspection of their vehicle, I know I do. I also do all the work on it so I also know what to look for and what items to have excess stock on hand, i.e. extra nylock nuts.
    rustytoys likes this.
