Looking to tow travel trailer or 5th wheel unlikely BUT looking for some feedback
Discussion in '2.5 Gen Tundras (2014-2021)' started by JB1950, Mar 19, 2021.
  1. Mar 19, 2021 at 11:39 AM
    JB1950
    JB1950 [OP] New Member
    2015 - 2017 Tundra - looking to buy
    Tundra 5.7L 2WD with FULL TOWING PKG - concern. Ready to buy 2017 to 2017 Tundra however need to be sure this truck can pull cross-country a travel Trailer approx 7500GVWR fully loaded. Looking for Tundra owner that has hauled suck a Travel Trlr. Appreciate any advise I can get before I buy Tundra. I'm long time owner of Toyota cars etc think they are the most reliable vehicles ....
    Own 2016 Tundra w/DBL cab "TRD 4x4 5.7L Off Road pkg" with 65inch truck bed per the sticker on truck GVWR= 7100lbs our truck has the full towing package plus 38gal gas tank. Per the travel trailer magazine states the tow rating for this unit can pull up to 9,900 lbs.
    Also interested in boondocking so would like to hear from anyone using SOLAR (solar unit an solar panels etc).
    Appreciate any feed back ....
    JimB
    Thanks AzureNightmare - I've done some basic homework 5100 lbs is what the truck sticker states. However I'm going load up my Tundra with full 38gal of gas and verify with my wife and I in the truck while getting weighed. Just to see what I really have as weight for starters. I guess that will give me some idea but will pay special attention to weight-dist hitch an tow-hitch once i get to that point. As far as a travel trailer - good idea to factor in weight of dual propane tanks and multiple batteries beside the our own stuff we'll be adding. Looking a travel trailer with dry wt of 5413lbs. Obviously probably after we add our own things on RV it will go up considerable in wt.
    Appreciate your thoughts...
  2. Mar 19, 2021 at 11:49 AM
    18" TRD Off Road Wheels
    You need to look at your payload, because you'll max that way before you hit your tow rating.
    Sticker on your driver door will have your payload rating, and there will likely be a yellow sticker that further reduces it for accessories added by the dealership. Anything you've added to the truck then needs to be deducted, and then what's left is how much weight you have for passengers, gear, weight of your hitch, and the trailer tongue weight.
    Don't ask a trailer dealer if your truck can pull it. They have no idea and want to upsell you as much as possible.
    Don't go off advertised weights and ratings. They are always skewed to be as appealing as possible. All the trucks will advertise the highest rating possible on the truck even though 99.9% of the trucks sold aren't going to have those numbers. Same for trailers. The tongue weights listed are going to be dry weights. Add the propane tanks, batteries, and anything else in the trailer and that number goes up.
  3. Mar 19, 2021 at 2:47 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    For full timing in an RV, get a 3/4 or 1 ton.
    jordoncloutier likes this.
  4. Mar 19, 2021 at 3:27 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    https://www.tundras.com/forums/towing-hauling.53/
    Read a few threads about it in the subforum above. Short answer based off what I've seen is your taking a significant risk to your family as well as others when hauling in a setup like this.
    Cpl_Punishment likes this.
  5. Mar 19, 2021 at 3:28 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    It "may" work, but won't be safe for you or anyone else on the road
    Cpl_Punishment and 1UP like this.
  6. Mar 19, 2021 at 3:45 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    There are several <28' 5th wheels I'd totally be comfortable towing with my 2019 but I would NOT choose this truck for a full time rig. You will be disappointed.
  7. Mar 19, 2021 at 4:37 PM
    DVCER
    DVCER New Member
    Phil
    Grand junction, CO
    21 SR5/TRD
    First aid kit/fire extinguisher
    Bad idea. Good truck but not for that.
  8. Mar 20, 2021 at 3:11 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Jim - you definitely need a 3/4 truck and preferably a diesel. The Tundra can tow a fair bit but once you get into 5th wheels, the Tundra is not a safe choice.
    Plus, you will be in the right lane chugging up steep inclines as there are many great places to see that are not at sea level.
    You will be able to enjoy your retirement with the right tow rig.
  9. Mar 21, 2021 at 6:58 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    A small bumper pull travel trailer is the best choice for the Tundra (or any halfton, really).
    GODZILLA, Crunch527 and JLS in WA like this.
  10. Mar 21, 2021 at 7:34 AM
    sportrider
    sportrider New Member
    Stephen
    2017 White Crewmax Limited
    I agree 5th wheel is not the way to go. Find a nice pull behind TT and you will be much happier. Or upgrade to a 3/4 ton. Your bed length is also larger than 65". The crewmax has the shortest at 67". You have either the 79" or 97". Never hurts to find a Cat scale to see exactly what your weight numbers are either. Good luck in your search, and happy retirement!
  11. Mar 25, 2021 at 9:26 PM
    HONEYBADGER
    HONEYBADGER New Member
    Fox Coils Camburk Kinetik Uppers Stealth Customs Cooper AT3
    I wouldnt try a 5th wheel with these trucks...get a diesel
  12. Mar 25, 2021 at 11:20 PM
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    I know a guy who tows a 5th wheel with a Nissan Frontier. The trailer is the Escape 5.0TA. The trailer is a 2 piece fiberglass shell like a boat and never leaks. 3500 lbs. I think they are the best camping trailers on the planet. Based on the Trilliums of the 1970's, they should last 75 years, I have a 2020 Escape 19'.
    2019 Escape 5.0 TA Fifth Wheel Tour (236) - YouTube
    Bigboitundra likes this.
  13. Mar 26, 2021 at 5:45 AM
    DUDE! Those are sweet! Any of those trailers would be great for a Tundra. I've never heard of them before, so thanks for clueing me in. :eek::thumbsup:
  14. Mar 26, 2021 at 11:33 AM
    Doug2000
    Doug2000 New Member
    I have owned 7 trailers now, 2 tent trailers, 2 big box trailers too big to tow that sat at the lake, and 3 Fibreglass trailers. I had a 1977 Trillium, still highly sought after and a 2007 Escape 17B. Before we bought our current trailer we looked around and nothing matched the quality of Escape.
    Pros of the Fibreglass trailers, their light and aerodynamic? Really easy to tow. There is no sway at all. Towing my 2007 Escape 17B behind my 4Runner, I would forget about it. There is only caulking around the vents and a few brackets, they virtually never leak. Many owners report little to no depreciation, some making money on their trailer over a 5 year period. I made money on my Trillium and 2007 Escape when I sold it. I got hosed on the leaky Forest River bad. Another, Fibreglass is infinitely repairable.
    The cons, their small, but I spend most of my time outside when I camp and setup a dining tent. Other con, their factory direct from BC which is good if your in the States. Rough numbers, a new Escape is $35k CAD, which converts to about $26K US. Absolutely nothing compares for the price is the US market. If one goes up for sale used, they are usually listed on the Escapeforum.org and sell within days which is a pro I guess. The con, the wait list right now is 18 months for new.
    Many people say a RV is not an investment, an Escape is.
    Other brands, Casita, Oliver, Scamp, Boler, Trillium, Burro, and UHaul made them in the 80’s as rentals.
    GODZILLA[QUOTED] likes this.
  15. Mar 26, 2021 at 11:38 AM
    Doug2000
    Doug2000 New Member
    The Fibreglass trailers and Toyota’s
    Bigboitundra and GODZILLA like this.
  16. Mar 26, 2021 at 11:41 AM
    Doug2000
    Doug2000 New Member
    I_Am_Thee_Walrus and GODZILLA like this.
  17. Mar 26, 2021 at 8:55 PM
    The Patriot 1776
    '16 TSS CM 4x4
    Yeah, people aren’t full timing in those. I couldn’t full time in anything less than 35’.
  18. Mar 26, 2021 at 9:23 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
  19. Mar 27, 2021 at 5:06 AM
    Doug2000
    Doug2000 New Member
    Yes people are full timing in these. I agree, I would need a little more room. There some that full time in the 17B I had, middle picture.
    An owner close to me tows the Escape 5.0TA with an EcoDiesel and gets stellar fuel mileage. He said 12L/100km, about 18MPG I think.
  20. Mar 27, 2021 at 5:30 AM
    The Patriot 1776
    '16 TSS CM 4x4
    I’ve had a 32’ bumper pull, a 35’ 5th wheel and currently a 24’ bumper pull. No way could I full time in the 24’ or 32’. Maaaaaaybe the 35’ 5th wheel but I wouldn’t be happy because it only had 1 12’ slide. I think I would be satisfied to in a 35’ triple slide. To each their own I guess.
