How do I plug these?
Discussion in 'Tonneau Covers, Caps and Shells' started by Cody56, Mar 26, 2021.
  1. Mar 26, 2021 at 3:20 PM
    Cody56
    Cody56 [OP] New Member
    2021 Tundra 1794 Wind Chill Pearl
    1.jpg I have replaced my tonneau cover and no longer need the drain hoses that were in use with the oem cover. How can I easily/best plug these holes remaining? (I don't know what these plastic ports are called?
  2. Mar 26, 2021 at 3:24 PM
    Go to Lowes or Home Depot, they have those speciality draws in the hardware/screw isle. In those drawers they have rubber grommets.
    Bob likes this.
  3. Mar 26, 2021 at 3:39 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    I think you want a hole plug as grommets usually also have holes in them.
  4. Mar 26, 2021 at 7:32 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The best solution is to just order the bed hole plugs from Toyota, pop the old ones out and push in the new.
    https://www.sparksparts.com/oem-parts/toyota-plug-hole-474190c010
  5. Mar 26, 2021 at 8:08 PM
    biebs96
    PA
    You could probably post them on here for someone to swap them.
    someone installing a cover with drain tubes might easily help you out.
    GODZILLA and irishpride114 like this.
  6. Mar 26, 2021 at 8:24 PM
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    Do you have better pictures? And what size are the holes?
  7. Mar 27, 2021 at 8:54 PM
    Cody56
    The plug is 4" by 2 1/4". The hole for the drain hose is 3/4". The small pinholes near the top and bottom of the plug is about 1/8".
  8. Mar 27, 2021 at 8:55 PM
    Cody56
    Plug with only the pinholes
  9. Mar 27, 2021 at 9:12 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Your solution is below.
    Replace the OEM plugs.
    However, you may not need to bother replacing the ones with the 1/8" holes.
    It kinda looks like the OEM plugs may have those 1/8" holes...
    I can't tell since mine have bed liner on them..
    But it sure looks like my first pic has that small hole in the top..
    5131B7D8-52A8-485B-AAEA-B6F0FE8F5E20_zps_1e57c1f79258df3f3c31004f6e0169385f44dbb0.jpg C53E03AA-7462-4102-9DC9-BA6292984014_zps_5e2976ed3ad235188897ceda57e2e8d4470f817d.jpg E355DC48-7966-4544-ADAD-18E9F2EFB8F2_zps_e92daa3e773b904f1a007a76b913a8bee749e935.jpg
    @JohnLakemanyou are a great American.
    Saved me the time of looking up that part number.
    Thank you.
    JohnLakeman[QUOTED] likes this.
  10. Mar 28, 2021 at 4:31 AM
    JohnLakeman
    All the credit goes to @Roman.
    I tried to find the part number without luck. I remembered @Roman had posted the part number months ago.
    Unfortunately, no picture for the skeptical, only a schematic of about a hundred Toyota plugs. :thumbsup:
    TundraRV and 1lowlife[QUOTED] like this.
  11. Mar 28, 2021 at 6:37 AM
    Bull
    Bull New Member
    Use black silicone. Smooth off the surface with a utility knife blade
  12. Mar 28, 2021 at 6:40 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Yup I just used silicone sealant but I do use the holes still for wiring running into the bed for the DC-DC charger and solar panel.
  13. Mar 28, 2021 at 6:48 AM
    Bull
    Bull New Member
    Use the grommet that use for HID headlights.
    It locates on the wire for the ballast. Check any auto store
  14. Mar 31, 2021 at 2:15 PM
    Cody56
    Found some Toyota molding push retainers that fit. Tried to post a pic and couldn't. Thanks for all of the responses.
