What Gear Oil are you using in the differentials and Transfer Case?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kemosabi, Mar 16, 2021.
  1. Mar 16, 2021 at 1:55 PM
    Kemosabi
    Kemosabi [OP] New Member
    2016 Limited TRD Off Road
    My 2016 Tundra has the 4WDemand Part-Time 4WD w/Elec Controlled Transfer Case, A-TRAC & "Auto LSD"
    I just bought the truck with 60K miles and all the services was done at the dealer but it doesn't look like the gear oil was ever changed.
    My owners manual says to use LT 75-85 GL-5, I can't tell if the LT fluid is for limited Slip or not.
    I have looked at a-lot of the posts and it seems like most people have open diffs.
  2. Mar 16, 2021 at 2:24 PM
    Pineapplehead
    Pineapplehead New Member
    Philip
    New Meadows, Idaho
    2010 Super White Tundra DC
    "Auto LSD" isn't really a limited slip, I thought? Someone will chime in that knows better.
  3. Mar 16, 2021 at 3:24 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Amsoil for the diffs
    Ravenol for the transfer case
    Casper3 and GAknight like this.
  4. Mar 16, 2021 at 8:35 PM
    llbts1
    llbts1 New Member
    2018 Tundra Limited
    I just did Redline on diffs and transfer case.
  5. Mar 16, 2021 at 8:46 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    Supertech synthetic Wallyworld special.
    Ruggybuggy and Rodtheviking like this.
  6. Mar 17, 2021 at 4:12 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Ravenol 75w85
  7. Mar 17, 2021 at 4:23 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    Correct - don't need the LSD diff oil version which Toyota calls LX.
  8. Mar 19, 2021 at 7:38 PM
    Otanguma
    Otanguma New Member
    Omar
    SR5 CrewMax 4x4
    6" Pro-Comp Lift, Catskinz leather seat covers, Rigid 30" Light Bar mounted on TRD PRO Grill 35" Nitto Ridge Grapplers mounted on 20" LRG rims
    I've undertaken the task of changing my front/rear diff oil along with transfer case oil on my own so I have been researching a little. Various videos on YouTube say to use 75W-90 on differentials but 75W for transfer case and that's what manual recommends too. I was buying local and went to the Toyota here in Midland, TX. Parts lady said they only carry and use the BG brand Syncro Shift II 75W-80 on vehicles there and never heard of "75W" rating.
    I'll probably return this unless I find something saying it's ok to use. I don't do much offroading in my crewmax unless muddy.
    Can anyone enlighten on that dealership BG brand transfer case oil?
  9. Mar 21, 2021 at 9:49 PM
    Tsgrav2011
    Tsgrav2011 New Member
    Yuma
    2006 4D TRD 2WD
    Brush scratches and dents
    So, if this sticker is on your rear differential cover, it’s a limited slip differential.6FAE5ACC-AC64-4DC9-BD6C-68F6DFFBF317.jpg
  10. Mar 25, 2021 at 11:08 AM
    db52282
    db52282 New Member
    Georgia
    2017 Silver Tundra Limited
    Just changed the gear oil in my rear differential 3 days ago. Mine is 2WD so no front diff to worry about. Called 2 dealers and one said to use 75W140 and the other said only use 75W90. I went to my local wally world and they only had one bottle of 75W90 but several 75W140 bottles. I said what the heck ... and bought 4 bottles of the 140. Was Valvoline synthetic with the LS additives. I was told that it doesn't matter if it has the LS additive or not since it won't really hurt the differential. Installed the bottles and truck seems very smooth. It is hot here most of the year and I tow once in a while so not too worried about the heavier weight gear oil.
  11. Mar 25, 2021 at 11:14 AM
    Mr Badwrench
    Mr Badwrench New Member
    At what mileage do we even have to change these fluids? My manual doesn't have the intervals for these :confused:
  12. Mar 25, 2021 at 11:18 AM
    db52282
    db52282 New Member
    Georgia
    I think I read somewhere that it was 25-30K for "severe service". I presume that means heavy towing. I plan on changing mine about every 50K since I don't tow all the time. Doesn't take long to do and I can chase my grandkids around while it drains. :)
    Mr Badwrench likes this.
  13. Mar 25, 2021 at 12:14 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    ^^^^ This^^^^
    75w85 for diffs
    75w for the t-case
  14. Mar 25, 2021 at 6:23 PM
    Bravohook
    Addame
    NY
    2007 RCSB
    Cool Things
    Depends on what you do and how hard you work it.
    I bought mine used and changed it out at 80k just to be safe...
    My pumpkins looked like foamy caramel and my transfer case looked good to go. But changed it anyway.
    Mr Badwrench[QUOTED] likes this.
  15. Mar 25, 2021 at 6:26 PM
    Bravohook
    Addame
    NY
    2007 RCSB
    Cool Things
    No, they do not require the lsd additive to run properly. The rear brakes are what do the slowing of wheel speed. Instead of a locker it slows the wheels to simulate locking..
  16. Mar 25, 2021 at 6:47 PM
    Tsgrav2011
    Yuma
    2006 4D TRD 2WD
    This photo has been moved over from the Gen 1 forum, it is of my 2006 TRD. My guess is it is different from the 2015’s and might not be applicable to the 3rd Gens.
    AZBoatHauler likes this.
  17. Mar 25, 2021 at 6:48 PM
    AZBoatHauler
    So.Arizona
    He has a 1st gen with a mechanical LSD.
