  1. Mar 23, 2021 at 9:53 PM
    RobertD
    Robert
    DFW, Texas
    TomC843 likes this.
  2. Mar 23, 2021 at 9:55 PM
    TopNach
    TopNach New Member
    Nacho
    Santa Barbara
    2019 Tundra Limited Cement Gray Crewmax
    Stock atm, but looking to replace the bling up front!
    Should be going on this Friday.
  3. Mar 24, 2021 at 6:50 AM
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
    The hardest part, other than making sure you're not laying directly under a bolt you're loosening (dirt) is getting the bumper top cover off to access the top bracket bolts. The instructions have you disconnecting the license light and the trailer plug which if your fully removing the cover you need to do, but I found I could access the inboard bolt without entirely removing the bumper cover. I used a stubby socket, then a U-joint, then an extension. I taped the tailgate above the bolt so not to rub the paint. It's tight, but I removed and reinstalled the bolt using my 1/4" drive impact gun.
    Once loose, it takes some wrangling to get the old bracket out and more wrangling to get the new one in, but it's only 5 bolts. It's not difficult, but it's tight.
    CorsoTundra[QUOTED] likes this.
  4. Mar 24, 2021 at 7:12 AM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    I can't wait to see what this looks like on. Are you color matching the surround and bulge?
  5. Mar 24, 2021 at 7:48 AM
    Dwarven1
    Dwarven1 New Member
    Ross
    2018 SR5 w/TRD Off-Road.
    2018 SR5 - Bolo Mark XXb - Unit DNE of the Line. "Denny"
    SOCMOB. CBS. Cracked windshield. :notsure:
    Fortunately, my awesome insurance agent decided to put a "no deductible" glass rider on my comprehensive insurance. New windshield will be installed Tuesday.
    Standing On Corner Minding Own Business. Clear Blue Sky.
    RobertD likes this.
  6. Mar 24, 2021 at 8:02 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Many, if not most states requires the no deductible glass repair/replacement coverage these days due to safety.
  7. Mar 24, 2021 at 8:04 AM
    Dwarven1
    Dwarven1 New Member
    Ross
    Unfortunately, Vermont isn't one of them. Last windshield I had to replace cost me $350 or so.
    And I STILL haven't got a FUCKING CLUE what broke it!!! That's what's REALLY frosting my cookies. NO CLUE. Just came out from my service call and noticed the 3" crack on the right side.
  8. Mar 24, 2021 at 8:12 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Cleaned her up after our wonderful winter!
    ElNopal, equin, mgm16trdpro and 14 others like this.
  9. Mar 24, 2021 at 8:14 AM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    the tri color badge is money! nice looking rig you go there
  10. Mar 24, 2021 at 9:06 AM
    d_kinneyjr
    d_kinneyjr New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    Thanks @greg8765 I appreciate it
  11. Mar 24, 2021 at 9:18 AM
    Tundra_Curt
    Tundra_Curt New Member
    Curt
    2021 Tundra Limited CrewMax
    Just getting started...
    Am i right in assuming these fit between the brackets in the hood for the bulge, e.g. you didn't have to cut the hood?
    If so, can you post a link to the lights/install kit and some night shots? Nice job!!
    Aught16TSS[QUOTED] and Astom22 like this.
  12. Mar 24, 2021 at 9:25 AM
    TopNach
    TopNach New Member
    Nacho
    Santa Barbara
    All is going to be matched up front other then the corner caps (where the fog lights are). I was thinking about doing those and color matching it to the cement color. But I’m thinking I should just save the money and get a front bumper.
    So that will be the only silver
    JerryH[QUOTED] likes this.
  13. Mar 24, 2021 at 10:23 AM
    dorton
    dorton #RockCreekOverland
    North Carolina
    2020 Black Tundra SR5
    CBI Off Road Front Bumper, Rock Sliders, Skids, and Bed Rack. Prinsu Designs Roof Rack, CVT Hybrid Rainier Tent, Old Man Emu lift, Fuel Vectors, Yokhama 305/70r18s
    [​IMG][/url]
    Expedition Essentials TDPAM
  14. Mar 24, 2021 at 10:33 AM
    Aught16TSS
    Aught16TSS New Member
    J
    Tuckasee
    2016 TSS - Magnetic Gray Metallic
    Dual Flowmasters, hidden LEDs in hood bulge, 3.5" lift and Ridge Graps
    Yeah, no need to cut the hood. I got the idea from a light kit sold by Rough Crountry. (https://www.roughcountry.com/toyota-40in-led-hood-bulge kit-70847.html?find=2016-toyota-tundra-4wd-738571). I used the instructions on that page to get everything apart, instructions attached. I had the lights laying around for a different project, but realized they would fit in the hood bulge.
    Link to Instructions - https://s3.amazonaws.com/roughcountry/install/921708460.pdf
    Link for Lights below - at that price, I don't know how long they will last, but any similar sized LED light should work the same. I DID NOT use the brackets, double sided sticky tape on the bottom of the lights to the black plastic housing, but honestly they fit tight enough that you probably don't even need the tape.
    https://www.amazon.com/Ultra-Slim-S...words=online+LED+store&qid=1616605655&sr=8-47
    A couple of quick notes. Once the mesh grill is off you will see there are 4 "compartments" in the housing. They are all the same size, I just chose the two middle ones. I stuffed the lights in the black plastic housing, it made the housing bulge a little, but the front came right back together when I screwed the mesh back on as outlined in the instructions. I did have to drill holes in the black plastic housing to run wires, but I DID NOT drill any holes in my hood, I used one of the existing holes on the drivers side.
    I did not purchase a wiring harness for these lights, I made my own. I bought a fuse-able link from NAPA (Link below) and put that from the battery to the rocker switch with a 20 amp fuse and grounded the lights to the body ground beside the battery.
    https://www.napaonline.com/en/p/BK_...Isu6m0bbJ7wIVwbeGCh3CWQUeEAQYBSABEgLevPD_BwE&
    I routed the wires down the hood lift strut like the instructions and went through the rubber grommet in the firewall with the factory wiring harness and used an empty switch hole on the lower left portion of the dash beside the steering wheel. I bought my switch on scamazon and it did not fit correctly, so I had to "massage" the opening. I believe rough country sells a rocker switch that is the right size and will greatly reduce headaches.
    https://www.roughcountry.com/led-backlit-rocker-switch-709sw.html?find=2016-toyota-tundra-4wd-738571
    Having the switch wired directly to the battery allows me to use the lights without turning the truck on. I hope this helps and if I think of anything else I will update this post.
    I will try to remember to get some night time photos.
    *Cheesy Disclaimer - Most states it is illegal to run any lights higher than your headlights on public roadways.*
  15. Mar 24, 2021 at 10:48 AM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Plastidipped my wheels and added TRD center caps and black color lugs. This was my first time plastidipping anything, not too bad of a process. Ended up doing 7 coats of dip and 4 coats of glossifier.
    Only issue I ran into was when I pulled off the old center caps, it took some dip with it. What’s a good way to fix that? Also had one place with a bubble, should I just pop it and respray? Both are barely noticeable, I just don’t want them to start peeling.
  16. Mar 24, 2021 at 11:11 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    You guys out there replace windshields with 3" cracks? Here in Alberta a car is unique if it doesn't have a crack, we don't replace windshields until it spiders into the main drivers eye part of the windshield. If I replaced after every 3" crack I'd be about 5 windshields in on my truck and I'd be lucky for them to last 6 months there's so many stones and rocks on our roads.
    Sonicbluerider likes this.
  17. Mar 24, 2021 at 12:29 PM
    Tundra_Curt
    Curt
    Thanks for this!!
  18. Mar 24, 2021 at 12:35 PM
    Wahayes
    Will
    2017 tundra limited
    Cleaned it. Again....... :anonymous:...... tri color badge as well. I will not go offroading I won't go offroading ..... :annoyed::annoyed::annoyed::anonymous::mudding:
  19. Mar 24, 2021 at 12:38 PM
    Tundra@21
    Tundra@21 New Member
    Percy
    2021 Cement Gray Tundra TRD OffRoad CM
    AFE Air Intake, TRD Exhuast System
    can you only do this on the JBL Head Units or does the none JBL Head units capable of doing this as well?
    i have tried to customize my screen but un able to do so.
  20. Mar 24, 2021 at 12:49 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    it's not possible in 2020 and 2021 trucks. The newer HU doesn't have that feature.
    Tundra@21[QUOTED] likes this.
  21. Mar 24, 2021 at 12:49 PM
    RainMan_PNW
    Casey
    Clark County, WA
    You realize you are "off road" in those pictures, right?
    twistedcricket likes this.
  22. Mar 24, 2021 at 12:50 PM
  23. Mar 24, 2021 at 12:55 PM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    I think of how much money in vacations I could save if my view already looked like this from home... Like endless upgrades to the tundy.
    jonclark96 likes this.
  24. Mar 24, 2021 at 1:03 PM
    Wahayes
    Will
    2017 tundra limited
    Lol I always forget about that when I post pics at the house ......:D I'm from Texas and that's the exact reason I moved here lol
    jpod[QUOTED], RainMan_PNW and JerryH like this.
  25. Mar 24, 2021 at 1:04 PM
    Wahayes
    Will
    2017 tundra limited
    Although I think I spend more on vacations now..... we are so much closer to cool stuff now we go more often. In texas we were days away from anything.... here it's 4 hours to Vegas, California isnt far, let's take a 4 hour trip to the grand Teton lol
  26. Mar 24, 2021 at 1:43 PM
    Wahayes
    Will
    2017 tundra limited
    Haha yea wellll I was pressure washing my offroad off my driveway lol I just mean not to make my truck look like this again ...... at least for a few days....
  27. Mar 24, 2021 at 1:59 PM
    Wallygator
    Nice! I would suggest that you add an inline fuse on the hot side.
    NewImprovedRon likes this.
  28. Mar 24, 2021 at 2:59 PM
    Lampy415
    Lampy415 New Member
    What about that Lambo she have cargo lights?
  29. Mar 24, 2021 at 3:03 PM
    Dwarven1
    Dwarven1 New Member
    Ross
    Yeah, well... the city boys in Montpelier, Brattleboro and Burlington usually outvote the rest of us outside the cities. and we're an "inspection" state. I haven't looked at the Vermont regs, but in Marxachusetts (where I escaped from) a windshield will FAIL your car's inspection if it's got a crack that can't be covered by a dime. And zero deductible glass insurance is mandated for all cars, so no one really cares about getting it done as they don't 'pay". (they don't consider the car insurance costs, of course.)
    Wallygator likes this.
  30. Mar 24, 2021 at 3:03 PM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Hired a pro to put on a snorkel an relocate my rear breather
