Engine down shifting
Discussion in '2nd Gen Tundras (2007-2013)' started by chefjeff, Mar 20, 2021.
  1. Mar 20, 2021 at 7:51 PM
    chefjeff
    chefjeff [OP] New Member
    jeffrey
    Black Tundra 2012 SR5 Crewcab
    Hey all
    My name is Jeff
    I now own a 2012 used Tundra
    I was a Ford F150 owner but have been convinced to give Tundra a try
    Based on great reviews and resale etc.
    The biggest bother for myself is that when I am descending a hill, if I touch the brakes the engine immediately down shifts and slows the truck unnaturally
    It feels like a bit of a bucking bronco on slightly undulating neighborhoods at slow speeds as well
    My take away from F150 vs Tundra is that the f150 drives more Cadillac style if you will and the tundra is jerky and rude not fluid
    Is there a setting that can be adjusted on my truck to stop all the downhill engine braking or is that Tundra
    YardBird likes this.
  2. Mar 20, 2021 at 8:40 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    My 2017 work f150 does this. My 07 Tundra does too. However, both only do it if I am slowing down quickly and not lightly applying the brakes. Does it to save the brakes on decent.
    Edit: I find my Tundra to be a much smoother ride.
    Cg13055, JohnLakeman and YardBird like this.
  3. Mar 20, 2021 at 8:59 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    Uh, what is a natural way to slow down? I ve come to appreciate the occasional boost from the trany when I come to a hill. Tap the brakes, and it s like a compression brake, but from the trany instead. If there is a setting that would change this I would not use it.
  4. Mar 20, 2021 at 9:02 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome, Jeff, from LA (Lower Alabama)!
  5. Mar 20, 2021 at 9:03 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It's called engine braking and it saves wear on your brakes.
    JohnLakeman, YardBird and TILLY like this.
  6. Mar 20, 2021 at 9:07 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Especially with the 4:30's. :)
  7. Mar 20, 2021 at 9:38 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  8. Mar 20, 2021 at 9:52 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I have to give it to you. You are the most welcoming individual on this forum, IMO.
  9. Mar 22, 2021 at 2:58 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Automakers have had to include this feature into transmission soft wear over the years. Vehicle owner's of today would rather take a beating than touch the shifter for anything other than P-D or R! :D
  10. Mar 22, 2021 at 7:27 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    That downshifting is nice when towing a trailer downhill. My ex-trucker Dad absolutely gushes over that feature. "Built-in Jake brake"
    The gas pedal is a touchy mofo..smoothness comes with time. That being said, I still mess it up every once in a while.
  11. Mar 22, 2021 at 8:04 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I only find the gas pedal touchy in tow/haul mode. I feel like I have to stomp it pretty hard to accelerate at a reasonable pace when not in T/H.
  12. Mar 22, 2021 at 8:31 AM
    CMB
    CMB New Member
    Cecil County MD.
    Sequential Shifter = ANSWER for any "shifting issues"
  13. Mar 23, 2021 at 7:56 AM
    idiggplants
    idiggplants New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels softopper ditch lights
    i will agree with you/everyone on the very touchy throttle. i find myself either accelerating from a stop painfully slowly, to the point where the person behind me probably thinks im a 65 year old retiree, or ive got my girlfriend looking at me from the passenger seat trying to figure out why im trying to give her whiplash. there is no easy way to roll onto the throttle. maybe it comes with practice, but as the tundra is my second vehicle, i doubt ill ever get it right as my daily driver is a stick shift that will trump the tundra with muscle memory.
  14. Mar 23, 2021 at 7:59 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Turn off tow/haul mode.
  15. Mar 23, 2021 at 8:17 AM
    idiggplants
    PA
    2013 DC 4wd
    its off by default. but what would that change as far as acceleration and a touchy pedal go.
  16. Mar 23, 2021 at 8:19 AM
    CMB
    CMB New Member
    Cecil County MD.
    Everyone comments on the 'Pedal Commander' for Tundra's stupidly sensitive throttle. Might want to check it out.
  17. Mar 23, 2021 at 8:36 AM
    idiggplants
    PA
    2013 DC 4wd
    thats pretty cool. had no idea that was a thing. ill keep an eye out for a used one to pop up though as its not a $300 problem. lol.
  18. Mar 23, 2021 at 9:18 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I don't know why Toyota did it this way but it changes the throttle sensitivity. I find in my truck I really have to step on the accelerator hard to even accelerate relatively gently and keep the engine around 2000 rpm. If I turn on tow/haul, a tiny touch of the gas pedal makes the truck leap forward
  19. Mar 23, 2021 at 9:38 AM
    idiggplants
    PA
    2013 DC 4wd
    Interesting. ill have to try it both ways. ive also heard that S mode also changes shift patterns a bit, and some people prefer to drive in S mode... so ill try that as well. thanks!
