A build for speed and handling, I know it sounds crazy.
Discussion in '2.5 Gen Builds (2014-2021)' started by Fastlane47, Feb 5, 2021.
  1. Feb 13, 2021 at 1:56 PM
    #61
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You do know those wheels are not available in our bolt pattern, right?
  2. Feb 13, 2021 at 2:35 PM
    #62
    clint444
    clint444 New Member
    Derek
    2015 Tundra
    TRD Supercharger, TRD Sway Bar, AMP Running Boards, 13.5" JL Audio 13TW5v2-4 Low-Profile Sub, Transfer Flow 46 gal.
    Thanks. I definitely will lower the truck. I am told and have researched that 600 HP is OK without constant abuse. Yes, a new fuel system too. Good I'm on the right track. I am planning on tighter suspension, selective differential lock to engage posi-traction, traction control bars, wheels and tires. I suppose now I need to research a "shift kit". Not sure what that will do but will be fun to find out.
  3. Feb 13, 2021 at 2:44 PM
    #63
    Fastlane47
    Fastlane47 [OP] New Member
    Maryland
    2018 Platinum
    Yes, years down the road. I have an engine builder at work who makes some mean LS engines.
    MJoeP likes this.
  4. Feb 13, 2021 at 2:52 PM
    #64
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Sick truck brother!!!
    :muscleflexing:
  5. Feb 13, 2021 at 3:03 PM
    #65
    Wahayes
    Will
    2017 tundra limited
    Waitttt you're not going to put an ls in IT right???
  6. Feb 13, 2021 at 3:22 PM
    #66
    Fastlane47
    Maryland
    2018 Platinum
    No, I love the corvette engines but not in my Toyota. I would build the 5.7, maybe a stroker kit.
  7. Feb 13, 2021 at 3:25 PM
    #67
    Fastlane47
    Maryland
    2018 Platinum
    Look up IPT Toyota shift kits, John is amazing, he will be making mine.
    Rex Kramer and Vizsla like this.
  8. Feb 13, 2021 at 3:26 PM
    #68
    Fastlane47
    Maryland
    2018 Platinum
    They are, I have gotten a few quotes for the Tundra. I think I just looked up the wheel for that pic.
  9. Feb 26, 2021 at 1:38 PM
    #69
    Fastlane47
    Maryland
    2018 Platinum
    Pulling the valve body this weekend to send it to IPT. Installing a Gator back belt and I'm also going to pull the TRD Pro grill out and have it paint matched to the truck. I will post some highway some highway pulls and pics soon.
    300BLK and AZTundra like this.
  10. Feb 26, 2021 at 1:56 PM
    #70
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    suuuuuuuupraaaaaaaaa!
    oh and the truck...
    love a head turning lowered truck. nicely done.
  11. Feb 26, 2021 at 1:56 PM
    #71
    2mchfun
    FYI, a stroker kit is on the market for this beast, it will need block modification and a little head work though.
  12. Feb 26, 2021 at 2:08 PM
    #72
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    Looks ridiculous....in a great way:thumbsup: AMAZING
    Fastlane47[OP] likes this.
  13. Feb 26, 2021 at 6:36 PM
    #73
    AZTundra
    Paul
    Phoenix, AZ
    Sweet truck. Curious, did you do that G-Tek Fab mod to the magnuson airbox? Any real gains? Got mine supercharged just over a year ago as well. Check out the radium engineering catch can, I catch a fair amount on the pcv side. Good quality stuff from them.
    Rex Kramer and thetastelingers like this.
  14. Feb 26, 2021 at 6:39 PM
    #74
    Fastlane47
    Maryland
    2018 Platinum
    Yes, I did the mod on the Magnuson air box. I feel the top end power picked up, more sound for sure. I'll look up the catch can system, thanks!
    AZTundra likes this.
  15. Feb 26, 2021 at 6:56 PM
    #75
    AZTundra
    Paul
    Phoenix, AZ
    If you do the catch can which I'd recommend for being supercharged just get the pcv can. I went with the dual kit which also included a catch can for crankcase. The crankcase can hasn't caught anything in a year and 12k miles.
    I'll check out the G-Tek kit. When you say it has more sound I assume you mean from the airbox, not the supercharger whine right?
  16. Feb 26, 2021 at 7:08 PM
    #76
    Fastlane47
    Maryland
    2018 Platinum
    I can hear more from the supercharger, could just be me, but I could barely hear it before the mod.
  17. Feb 26, 2021 at 7:09 PM
    #77
    AZTundra
    Paul
    Phoenix, AZ
    Ok, thanks!
  18. Mar 9, 2021 at 3:02 PM
    #78
    Fastlane47
    Maryland
    2018 Platinum
    Just finished up the valve body from IPT. While the truck was down I went with a smaller s/c pulley from URD and removed the TRD grill. I had it painted to match the truck paint. I will make some highway pulls and post them soon.
  19. Mar 9, 2021 at 5:46 PM
    #79
    AZTundra
    Paul
    Phoenix, AZ
    Nice updates. Curious to see your thoughts on the smaller pulley.
  20. Mar 9, 2021 at 5:50 PM
    #80
    Fastlane47
    Maryland
    2018 Platinum
    I will do some pulls tomorrow and let you know. For some reason it always takes me about 500 miles or so to notice any mods that I do. I don't expect much from the pulley, but every bit of hp helps.
  21. Mar 14, 2021 at 11:18 AM
    #81
    Fastlane47
    Maryland
    2018 Platinum
    Made some highway pulls this weekend, the shift kit from IPT works well. The smaller pulley from URD pulls harder on the top end. The new gator back belt works great with the smaller pulley.
    Highway run
    https://photos.app.goo.gl/RP93xasoK8N2D21o8
    Installed a TRD shifter
    The wheels and new speakers will be here next week, I think that will be it for this year. Next year I'm going to install a rear diff and maybe a fuel system.
    Mountun Goat and AZTundra like this.
  22. Mar 20, 2021 at 3:36 PM
    #82
    Fastlane47
    Maryland
    2018 Platinum
    New wheels came in and installed today.
    PXL_20210319_170256056.jpg PXL_20210319_202350507.jpg PXL_20210320_222715186.jpg PXL_20210320_222656560.jpg PXL_20210320_222647864.jpg
  23. Mar 23, 2021 at 7:21 AM
    #83
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    This is screaming for TRD bbk with the 400mm rotors.
  24. Mar 23, 2021 at 7:23 AM
    #84
    Fastlane47
    Maryland
    2018 Platinum
    I know, I'm looking into a custom kit, hopefully soon.
  25. Mar 23, 2021 at 7:32 AM
    #85
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Nice build, you should be proud of your work.
    I'm sure all the NASCAR / Toyota guys are lifting a beer in your name.
    ATV25 and Fastlane47[OP] like this.
  26. Mar 23, 2021 at 9:02 AM
    #86
    Pineapplehead
    Pineapplehead New Member
    Philip
    New Meadows, Idaho
    2010 Super White Tundra DC
    Very nice build. Quite the hot rod, if you ask me. Makes me miss my old 1994 Lightning, though it was nothing compared to this. I've just always thought that trucks make the best hot rods!
    SnrDisregardo and Fastlane47[OP] like this.
  27. Mar 23, 2021 at 11:18 AM
    #87
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Nice rig !
    Did you happen to weigh those wheels before install ?
  28. Mar 23, 2021 at 11:24 AM
    #88
    Fastlane47
    Maryland
    2018 Platinum
    90lbs each, wheel with tire, not too bad.
  29. Apr 16, 2021 at 8:53 AM
    #89
    Fastlane47
    Maryland
    2018 Platinum
    I have been driving around for a few weeks now with the new set up. I can feel a difference with the smaller pulley and a big difference with the shift kit. I started get a belt nosie when taking off from a stop, took off the gator back and installed a Gates HD belt, seems to work well with the supercharger. PXL_20210416_154619370.jpg PXL_20210416_154716258.jpg
  30. Apr 16, 2021 at 9:15 AM
    #90
    NoRcptn
    NorCal
    2017 Platinum
    Dayuum thats a nice truck.
