Winter front
Discussion in '2.5 Gen Tundras (2014-2021)' started by mb66l79, Feb 9, 2021.
  1. Feb 9, 2021 at 3:52 PM
    mb66l79
    mb66l79 [OP] New Member
    Picked up a 2021 a few weeks ago. Anyone found a winter front? I want something more substantial for mounting than the adhesive mounting of the fia ones. Also can't block the radar in the emblem. I can't be the only one looking for a winter front, what is everyone else doing?
  2. Feb 9, 2021 at 4:11 PM
    Warreng
    Warreng New Member
    I honestly never see gas trucks with covers and its pretty cold here.
    I had one for bugs before, worked amazing.
    Im sure any upholstery shop could whip you up something.
  3. Feb 10, 2021 at 5:40 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Not gonna lie. I had to google a winter front. I don't think i've ever seen a truck with one. Do they really make a difference?
    panicman likes this.
  4. Feb 10, 2021 at 5:45 AM
    mb66l79
    They make a huge difference, I've always used them on my vehicles in the winter. Will depend on where you live and what winter temperatures look like for you though.
  5. Feb 10, 2021 at 5:52 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Ah the things I learn. I had no idea. I'm in NE Ohio. lowest we see on a normal basis is around single digits at night.
  6. Feb 10, 2021 at 5:55 AM
    Welcome from NY.
  7. Feb 10, 2021 at 6:01 AM
    mb66l79
    I regularly see colder temps here in North Dakota. I think you'd notice a difference too, but like anything else, it's a personal preference. I'm really hoping to find one.
    Grizzly660 and Jaypown[QUOTED] like this.
  8. Feb 10, 2021 at 6:51 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Cardboard behind the grill if you're worried about it...
    jordoncloutier, LS3 and MTRock like this.
  9. Feb 10, 2021 at 6:52 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Good Luck. I haven't heard of anyone on here with one but hopefully someone chimes in with something for you.
  10. Feb 10, 2021 at 6:56 AM
    mb66l79
    I've been thinking about that too, hoping to avoid the cardboard route, and don't want to make removal of the grill a seasonal activity.
    HulkSmurf14[QUOTED] likes this.
  11. Feb 10, 2021 at 6:57 AM
    Bammer
    Monroe, CT
    Was a must for my 07 Duramax, not sure it's needed on a gas motor?
    HulkSmurf14 likes this.
  12. Feb 10, 2021 at 7:03 AM
    mb66l79
    Not needed no, but definitely beneficial.
  13. Feb 10, 2021 at 8:01 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've never seen one on a reasonably modern gasoline engine. I would be surprised if you could find one. I suspect that your best bet is custom.
  14. Feb 10, 2021 at 11:57 AM
    RPO 579C
    RPO 579C New Member
    Minnesota
    2020 Tundra DC TSS barcelona red
    bed cover, weathertech mats, locking gas cap, fensens rear sensor, wet okole seat covers, trd rear sway bar
    I'm next door to you, OP, in northern Minnesota. This is definitely some nasty weather. Several -30 mornings lately, and wind chills around -50. My Tundra warms up pretty quickly with no grill cover, but if I wanted it to warm more quickly in the morning I'd install a block heater and keep it plugged in, even in the garage. Once my truck is warmed up I have to turn the heat down.
    Hope you find what you're looking for!
    BravoDeltaRomeo likes this.
  15. Feb 10, 2021 at 12:16 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    OP, try www.gofia.com
    if it's cold enough it can happen, my Outback was actually losing temperature while moving during one of the coldest snap couple years back, I had to put cardboard in front of the radiator since inside wouldn't heat up.
    Wynnded[QUOTED] and Black Wolf like this.
  16. Feb 10, 2021 at 2:51 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I had a Honda like that back in the 90s. The clutch would get more difficult to depress as I drove and easier if I let it sit and idle. I probably should've flushed the clutch master under the premise that the fluid had likely absorbed some moisture.
  17. Mar 23, 2021 at 5:55 AM
    mb66l79
    I talked to Fia, they sent me these pics, comes with both stick on and screw mount snaps. Bug screen also comes with the winter front. Not sure if I'm going to try it but am sharing this for anyone else that may be looking, the pics are nice to see. Note that the top snaps mount to the hood, I'd probably try to tuck it under and mount so they wouldn't have to be unsnapped to open the hood.image001.jpg image002.jpg image003.jpg image004.jpg
    Warreng, Bammer and MaxMB like this.
