Need advice for pro grille on 2018 SR-5
Discussion in '2.5 Gen Tundras (2014-2021)' started by SnowedIn, Mar 17, 2021.
  1. Mar 17, 2021 at 11:14 AM
    SnowedIn
    SnowedIn [OP] New Member
    Krista
    2018 Silver Tundra TRD TSS Package
    None...yet
    I'm thinking about swapping out my 2018 SR-5 grille for a Pro grille but not changing the surrounding. I would need the garnish thing and the grille insert. Has anyone done this before? Pretty sure it's got the TSS system. I'm trying to find a part number - I can get one at cost from Toyota (I work for a car dealership) but I don't know the part numbers. I saw a post on here about how to separate the insert from the surrounding, so that might help me. Jeeze, I'm all kinds of A.D.D. with this post, sorry!
  2. Mar 17, 2021 at 11:36 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Can't help with the TSS stuff, my 2014 doesn't have it, thankfully.
    But as to separating the insert form the surround;
    It is easier with 2 people.
    1 to pull the parts apart, the other to use a small jeweler's flat blade screwdriver to gently separate the tabs.
    They break easily, I only broke one when I did mine..
    Luckily it was close to the screw..
    6F990F15-3A3E-48AE-BBE7-4FBD81C0B984_zps_c1a9755db08c4500e5c71f04b76bf6a3259445c2.jpg
  3. Mar 17, 2021 at 11:37 AM
    SnowedIn
    Krista
    None...yet
    That's what I'm worried about. Are the tabs on the surround or the insert?
  4. Mar 17, 2021 at 11:59 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    That was years ago..
    I think the part with the tabs to bend to release where on the surround.
    The insert had the 'inserts'..
    It isn't that hard.
    If I would have had someone helping I wouldn't have broken any..
    Just go slow and take your time.
    even 1 or 2 get broken, it isn't going to make that much difference..
    It is worth it to have the TRD Pro insert..
  5. Mar 17, 2021 at 12:04 PM
    SnowedIn
    Krista
    None...yet
    Man, that looks badass on your truck. The main thing that's stopping me is that the 'TSS grill garnish' costs more than the grille itself. $350-ish for the inset and $400 for the littel 3x4 inch piece that fits into the grill where the TSS sensor and camera is.
  6. Mar 17, 2021 at 2:58 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Do a little more searching..
    Some will use this and buy the older 2014-17 Pro grilles that doesn't have insert.
    That insert ruins the look for the Pro grille anyway..
    TSS Relocation Bracket - 10052B (ajtdesign-llc.com)
    [​IMG] [​IMG]
    Again, I know nothing about the TSS sensor, since I don't have one..
    Not sure about any camera..
  7. Mar 17, 2021 at 3:03 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    210A4E73-BFA1-40A2-A7F6-F49E97EC7E68.jpg You can get the 2014-17 pro grill and it doesn’t require a garnish....it does require the sensor relocation bracket.
    I had the ajt relocation bracket and it caused periodic sensor malfunctions. I switched to the Jomax relocation bracket and haven’t had a problem since
    1lowlife likes this.
  8. Mar 22, 2021 at 6:11 PM
    pillpusher84
    pillpusher84 New Member
    2024 Silverado High Country
    53141-34010 TSS Sensor Cover
    The most expensive piece of plastic I have ever purchased!
  9. Mar 22, 2021 at 6:12 PM
    pillpusher84
    TRD Pro Grille:
    53101-0C070
  10. Mar 22, 2021 at 7:17 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    IIRC, inserts aren’t sold by itself for the 2018-current model...
  11. Mar 22, 2021 at 9:30 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Are you looking for the old style Pro grill or the current version?
    The old style insert will require a TSS relocation bracket as mentioned above. Several options to choose from.
    Check out @2020Platinum mod to put the sensor behind the bottom of the surround itself.
    https://www.youtube.com/watch?v=rDTXe9eNAFg
    If you want the current style Pro grill, some folks on here found an aftermarket version that comes with the little plastic cover, and they seem pretty happy with the quality. Pretty sure its this one:
    https://mcautoparts.com/products/18...tHVPFpnAyiM8-CXqwvQkzyQLaI8dtPIxoCoxQQAvD_BwE
