Paint polishing question
Discussion in 'Detailing' started by Aggiesdm, Mar 22, 2021.
  1. Mar 22, 2021 at 7:54 PM
    Aggiesdm
    Aggiesdm [OP] New Member
    Derek
    2016 Crew Max Platinum 4X4; '25 Limited 4X4
    '16: 2" lift and Retrax bed cover
    Hi all, I recently bought a 2016 Tundra 4x4 in Super White (040) and it appears that the previous owner removed the 4x4 emblem on the tailgate and then scuffed the paint trying to get the adhesive off. The adhesive is gone, but that area is really hazy now. I don't think the clear coat has been compromised, but not sure how to shine it up so that it's not noticeably different from the polished paint around it.
    I've just never had to do that to a car before. Any advice would be appreciated.
  2. Mar 23, 2021 at 9:38 AM
    briarpatch
    briarpatch New Member
    If the clear coat is compromised, then I'd say there is nothing you can do, other than to have it repainted. A less expensive option may be a decal of some sort, or put new badges on. If it shows up well on a pic, please post one
  3. Mar 23, 2021 at 10:07 AM
    Pineapplehead
    Pineapplehead New Member
    Philip
    New Meadows, Idaho
    2010 Super White Tundra DC
    Start with a glaze/swirl remover. That will be the most gentle polish. You may have to work your way up from there to a polishing compound. I've been surprised before by what looked pretty bad turning to looking pretty good. Even if clear coat is hurt, bringing the shine up can make it better match the surrounding finish. Good luck!
    THOR's and Runway like this.
  4. Mar 23, 2021 at 11:40 AM
    Aggiesdm
    Derek
    Thanks all, I'll try to post a pic shortly. I don't think the clear is compromised but just significantly scuffed.
  5. Mar 23, 2021 at 1:46 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    After color sanding, automotive paint is completely flat matte before polishing. Fixing that hazy spot should take about five minutes using a Porter Cable 7424 RO polisher, Lake Country CCS orange foam pad, and 3M 05973 rubbing compound.
    You may find you have some clearly deeper tool mark scuffs after a first easy pass. Those will be the last to polish out if you try to polish them out with compound. You will have to decide if they are deep enough that you need to carefully level the tool marks with 2000 grit paper before proceeding with polishing. Stop polishing when it's as shiny as the rest. Hopefully, you will have enough clear coat to not wear through.
    THOR's likes this.
  6. Mar 23, 2021 at 3:39 PM
    Aggiesdm
    Derek
    Great advice! Thanks so much! I'm gonna give it a try. I don't have a RO polisher, but I think my buddy does!
  7. Mar 23, 2021 at 3:48 PM
    briarpatch
    If that's the case, then there may be hope. I'm hesitant to give you any advice without seeing it, or at least a pic
  8. Mar 23, 2021 at 6:15 PM
    Aggiesdm
    Derek
    You can see the hazy area just above the dealer emblem. It’s really hard to get a very good shot.
  9. Mar 23, 2021 at 6:15 PM
    Aggiesdm
    Derek
    See pic above
  10. Mar 23, 2021 at 6:24 PM
    briarpatch
    Looks as though it can be saved. Always go least aggressive first, so a polish may end up being all you need. That's where I would start, and go to a compound if it does not give you the results you're looking for.
    Runway likes this.
  11. Mar 23, 2021 at 6:30 PM
    THOR's
    THOR's New Member
    Thor
    North Carolina
    2021 Tundra TRD Sport and XP Predator Package
    If you have never used a buffing pad/wheel before, make sure you understand how to operate it. I am sure there is a YouTube video showing you how it is done. You need to make sure the rotation is away from the hard edge of the tailgate and not into the edge. Secondly, let the wheel do the work... a light pressure is all that is needed. You may want to take it to a shop and have them buff it out if you are hesitant.
  12. Mar 23, 2021 at 6:52 PM
    briarpatch
    ^^^^^^^^that's some good advice right there^^^^^^
    THOR's[QUOTED] likes this.
  13. Mar 23, 2021 at 7:10 PM
    JohnLakeman
    Better to use a random orbital polisher that does not require that kind of caution. Rotary polishers are much faster, but should be left to the pros imo.
  14. Mar 23, 2021 at 7:49 PM
    briarpatch
    ^^^^^^^^^^^even better advice there^^^^^^^^^^^^^
  15. Mar 25, 2021 at 9:34 AM
    Aggiesdm
    Derek
    Well, I went yesterday to get a small dent removed by a great PDR guy and after he did the dent repair, I asked him to look at the scuff and he said...no problem. He pulled out some 3000 grit sandpaper and then hit it with some polish on a RO polisher and it looks brand new. Thanks for all the insight thought...I'll keep it in my back pocket for the next time!
    THOR's and JohnLakeman like this.
  16. Mar 25, 2021 at 12:36 PM
    THOR's
    THOR's New Member
    Thor
    North Carolina
    Glad it worked out for you! :thumbsup:
  17. Mar 25, 2021 at 12:44 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Next time try fishing line or nylon string to remove emblems...I'll get the exact product name. Buddy did some the other day at his sign/vinyl shop.
  18. Mar 29, 2021 at 3:47 PM
    Aggiesdm
    Derek
    Thanks. I'm familiar with how to remove them. This removal and damage was done by the previous owner, not me.
    Hi06silver[QUOTED] likes this.
  19. Apr 2, 2021 at 10:10 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    DONT BUY FROM AUTOGEEK
    jhardy1979 and Cg13055 like this.
  20. Apr 2, 2021 at 10:30 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Why is that?
    Nm. Found the reason on the other thread. Sorry man that's shitty of them
    ToyoMafia[QUOTED] likes this.
