Does Tundra have a safety lockout?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TylerDurden311, Mar 21, 2021.
  1. Mar 21, 2021 at 8:50 AM
    TylerDurden311
    TylerDurden311 [OP] Paper Street
    2018 Tundra CM
    Just parked the truck after running a few errands and when I went to lock the truck I got nothing. Put the key in the ignition and same. Battery is reading 13v across the post and 12v to ground. Any ideas?
  2. Mar 21, 2021 at 9:07 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Nothing works?
    No lights, door locks, anything?
  3. Mar 21, 2021 at 9:12 AM
    TylerDurden311
    2018 Tundra CM
    Nothing at all, not even a dash light
  4. Mar 21, 2021 at 9:14 AM
    Kanobi13
    Kanobi13 New Member
  5. Mar 21, 2021 at 9:15 AM
    TylerDurden311
    2018 Tundra CM
    Investigating now
  6. Mar 21, 2021 at 9:19 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Turn the key on, and then use your voltmeter to measure between the negative post and a body ground, like one of the unpainted headlight mounting bolts.
    Also measure across the battery posts with the key in the on position.
  7. Mar 21, 2021 at 9:27 AM
    TylerDurden311
    2018 Tundra CM
    I just put the key back in the ignition, now I have power and the truck started on the second try... So now I’m even more confused
  8. Mar 21, 2021 at 9:31 AM
    TylerDurden311
    2018 Tundra CM
    Battery post 12v -on
    Neg to ground- 0v-on
    landphil[QUOTED] likes this.
  9. Mar 21, 2021 at 9:45 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    About what you want to see, but if it’s still working at this time you should get good readings. Wiggle that body ground cable on the inner fender, make sure the bolt is tight, and your battery post clamps are tight and corrosion free.
    If all good there, have that battery load tested ASAP.
  10. Mar 21, 2021 at 9:50 AM
    TylerDurden311
    2018 Tundra CM
    Will do. Thanks for the assistance
  11. Mar 21, 2021 at 10:01 AM
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    Very interestingly I had the exact (and I mean exact) same thing happen to my first Gen. however one of my battery terminals had come loose causing me to it have power. To make a long story short it was my alternator. My truck had good battery juice and then would start and then die. Eventually I had zero battery too.
  12. Mar 22, 2021 at 5:58 PM
    pillpusher84
    pillpusher84 New Member
    2024 Silverado High Country
    strange ... did you figure out the problem?
