Powder coated brake calipers
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bking, Mar 21, 2021.
  1. Mar 21, 2021 at 4:23 AM
    Bking
    Bking [OP] New Member
    B
    New York
    TRD PRO
    Has anyone powder coated their brake calipers ?
  2. Mar 21, 2021 at 4:30 AM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Probably have, but it’s easier to just paint them yourself.
  3. Mar 21, 2021 at 4:44 AM
    Bking
    B
    New York
    TRD PRO
    I hear you, I thought about that too but powder coating will adhere better. It will also look much better. I know it will cost more and calipers also have to be taken apart.
    I_Am_Thee_Walrus likes this.
  4. Mar 21, 2021 at 5:24 AM
    AlrightAlrightAlright
    AlrightAlrightAlright New Member
    Northwest Arkansas
    2020 SSM DC 4x4 with SR5 Upgrade Package
    RetraxONE MX retractable bed cover TRD Rear sway bar Debadged FabFours Matrix front bumper Smittybilt 9,500# XRC winch Aries 30" light bar (internal bumper mount) Diode Dynamics SS3 3" SAE Fog and Driving lights ConsoleVault RhinoRack crossbars
    Dunno about the Tundra, but they make color covers for the Mustang. Helps with dust accumulation on the wheels without sacrificing heat dissipation, supposedly.
    Bking[OP] likes this.
  5. Mar 21, 2021 at 6:13 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    I did powder coating on my Chevy and it worked great. Just be sure the guy covers the holes where the pistons go. If not, it will be scuffed in the cleaning process.
    I used spray paint on my Corolla calipers. Never again. Paint came off when I was bleeding the brakes.
  6. Mar 21, 2021 at 7:27 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Use Ceramic BBQ Rustoleum Flat as a primer coat(s). Finish with Gloss Black, or your favorite color, with a few more coats. You can do this with the wheels off without removing Calipers. Slip a plastic grocery bag up and under rotors to isolate Caliper for spraying. Proper prep is key.
    I’ve done it both ways on and off truck. In the pic, I sprayed these off as they were a new upgrade. Holding nicely. A little dirty a year in, but to be expected. Washes off clean.
  7. Mar 21, 2021 at 8:17 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  8. Mar 21, 2021 at 8:57 AM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
  9. Mar 21, 2021 at 9:05 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  10. Mar 21, 2021 at 9:45 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    I would use cerakote. can be applied yourself and much more heat resistant.
  11. Mar 21, 2021 at 10:17 AM
    1UP
    1UP Truck Gang
    See the top quote as well as this thread https://www.tundras.com/threads/adding-toyota-x-series-caliper-covers-on-rear-of-trd-pro.80851/. Hadn't done it yet but found the post in "What have you done..... today" thread
    It's on my list of mods to do.
  12. Mar 21, 2021 at 3:44 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
  13. Mar 21, 2021 at 7:40 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    They look tacky, snow accumulation can also rip them off, if anything , I'd rather paint the existing calipers, vht and rustoleoum look much nicer than those covers.
  14. Mar 21, 2021 at 7:42 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I was kind of thinking that. Looks like they won’t fit the fronts anyway. There isn’t much room to clear the BBS wheels.
  15. Mar 22, 2021 at 7:32 AM
    Downytide
    GTA
    It doesn't stick out that much, I recall they are held on by these double ended screws or sort, then they ask you to use silicon glue too, its fine on sliding calipers where the outer surface is just flat, but on our front calipers things get caught because there's big gap between the surface and the back of the cover, one of the guys at work did that on his GMC Sierra (new one), which has similar 4 pistons caliper as we do in shape, his broke into 2pcs after one winter storm because the snow keep accumulate in between.
  16. Mar 22, 2021 at 7:43 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I’ve seen a few guys on here who have them they look sharp.
  17. Mar 22, 2021 at 5:48 PM
    pillpusher84
    pillpusher84 New Member
    2024 Silverado High Country
