  1. Mar 21, 2021 at 5:28 PM
    If you watch it will be double, I did this ridiculous hand yoga move as I was doing my motor mounts. The bolts came from underneath(mind you this is one handed thru the front hole one you remove the fender skirt, passenger side) I held the bolt with my pinky, as I handed/fingered the nut to my pointer and middle finger, which landed the nut on the inverted bolt which I then did a switch a roo and finished tightening with thumb and forefinger....... I had to take a water sprits after that!!! Still haven’t come up with a name for that move yet.....
  2. Mar 21, 2021 at 5:30 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Looks great!
    taranovich92[QUOTED] likes this.
  3. Mar 21, 2021 at 7:44 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    I didn’t know they made a TRD rear sway bar for the first gen. Nice!
  4. Mar 21, 2021 at 8:34 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Today I gave the girl a nice wash including her underside.
    cleaned the throttle body
    Changed passenger side valve cover gasket, replaced PS ignition coils & spark plugs.
    Spent so much time cleaning... I feel these sparks plugs alone should improve the overall performance compared to what was in there...
  5. Mar 21, 2021 at 8:37 PM
    When I was puttsing around with headers, I decided to stick my fingers on a valve cover bolt, to my surprise, I loosened it with ease!!! Haha next project is torquing all those bad boys down!!!
    Darkness, Filthyphil and Voss[QUOTED] like this.
  6. Mar 21, 2021 at 8:52 PM
    Voss
    Valod
    2003 AC TRD 4x4
    All mine were really loose. I don’t think they’re supposed to be torqued down much.
  7. Mar 21, 2021 at 8:54 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Yeah probably should check mine as well.
    MS22 and FrenchToasty[QUOTED] like this.
  8. Mar 22, 2021 at 3:30 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    53 in-lbs on those valve cover bolts.
    I've started checking mine at every oil change.
  9. Mar 22, 2021 at 4:13 AM
    pm07
    pm07 New Member
    Shane
    2006 Black Tundra
    You have to love pollen season here. :)
    Darkness and abcinv[QUOTED] like this.
  10. Mar 22, 2021 at 5:35 AM
    Where does one jack up the engine without crushing the oil pan? I haven't studied it that closely. Is there a flat spot to put the jack?
  11. Mar 22, 2021 at 6:26 AM
    Surprisingly the pan is pretty strong, just don’t let your wood block smash the drain plug and your good to go
  12. Mar 22, 2021 at 7:14 AM
    Wow. How'd I miss this? This would make a great bed mat and with a tee, a portable driving range off the back of my truck for use in the empty back parking lot at work. :D
    pm07, RUSTYNUTS and abcinv like this.
  13. Mar 22, 2021 at 8:14 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Forgot to post this yesterday. Added seafoam to crank case and went for a quick 15 mile circle around the county on the back roads to really werk it good before oil change. I just wanted an excuse to drive it. :D
    https://youtu.be/pDzxg9yShew
    Voss, BubbaW, Lupe and 1 other person like this.
  14. Mar 22, 2021 at 8:59 AM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    Installed Yellow Fogs
    Voss, 912, oscardog86 and 4 others like this.
  15. Mar 22, 2021 at 9:33 AM
    Love how they match that yellow license plate. :D
    MS22, Voss, Glock 40 and 6 others like this.
  16. Mar 22, 2021 at 9:34 AM
    Heeeey hey hey, look at what pops passed down during my last trip out there. Woot!
  17. Mar 22, 2021 at 9:38 AM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    Its funny how my license plate is yellow, i live in NJ
  18. Mar 22, 2021 at 9:39 AM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    Slow down your speeding lol
    MS22 and NUDRAT like this.
  19. Mar 22, 2021 at 9:53 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    That's my fault. I'm always telling @Tundra2 "faster".
    CodyP and Voss like this.
  20. Mar 22, 2021 at 10:50 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Hope you took a video! The pipe work looks good. :thumbsup:
  21. Mar 22, 2021 at 11:15 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    What size bars do you have on that rack?
  22. Mar 22, 2021 at 12:14 PM
    Haha I was so twitterpayted I forgot how to use my phone!
    Letting the paint dry, then back up under the truck, and do the “test pipes” then it’s time to go rip it!
  23. Mar 22, 2021 at 12:48 PM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Looking to add audio controls to my steering wheel on the 05 DC. Finally managed to score a reasonably priced airbag cover (with airbag). It was guaranteed to be free of recall, but I still may swap the cover on to my existing airbag. Still waiting on the switches.
    Anyhow, I’m looking for any info that you all might be able to shed as to how to wire the switches into the stereo. I have an aftermarket stereo and don’t recall seeing extra wires when I installed it. @empty_lord Ive seen you refer in a few posts about “running a few wires” if I remember correctly. Could you share any insight?
    I’ll do a little write up when I get this done to help anyone in the future that might want to do the same.
    Also looking for a perforated leather wrap kit for the wheel. Any recommendations?
    Thanks in advance!
    NUDRAT and Jack McCarthy like this.
  24. Mar 22, 2021 at 12:59 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    90% sure your tundra will be wired already for the switches. Likely won’t have to run anything, ID you did it’s 3 wires from
    The junction connector on the passenger side under the radio.
    912[QUOTED], oscardog86 and Darkness like this.
  25. Mar 22, 2021 at 1:20 PM
    912
    2005 DC 4x4
    Awesome, thanks man. I’ll look behind the dash and report back when I get it done!
  26. Mar 22, 2021 at 1:46 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    It won’t be. I did this back when I first got my truck. The new controls will plug directly into the clock spring but you need to run 3 wires over to the radio from the back of the spring.
    At the time I was doing car audio so I had access to AllData. I can’t tell you much about where the wires plug in spring side. But I can tell you that I took this picture of the back of my radio when I was replacing it. The wire colors are arbitrary because they were just what I had lying around.
    I know it’s not a lot of help but I bet you can cross reference the pin locations with whatever the new Metra steering wheel control adapter is and it will get you pretty close.
    hammeron likes this.
  27. Mar 22, 2021 at 1:48 PM
    empty_lord
    05 rollover special
    Yours wasn’t wired to the clock spring? Access and regular cabs are unless they’re V6.
    all I had to wire was the radio harness itself
    shifty` likes this.
  28. Mar 22, 2021 at 1:58 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Nope, those wires that you see plug into the back of my clock spring. Also, there was no harness to plug into my radio with those wires in it or I wouldn’t have needed to plug those pins into the radio.
  29. Mar 22, 2021 at 2:01 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    These, but male, are the only two harnesses located behind my radio. Obviously, non JBL.
  30. Mar 22, 2021 at 2:05 PM
    empty_lord
    05 rollover special
    Interesting. Reg and access cabs have a radio harness that connects down by the passenger side of the center console area.
