  1. Mar 21, 2021 at 6:59 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I had this old boss that used to say some of the funniest shtuff. He was a small business owner and we just finished a job at a clients. Guy asks my boss if he could drop off a letter in the mailbox on the way out of the neighborhood. My boss says, ‘Would you like me to pick up a gallon of milk, too?’ :rofl:
    oscardog86 likes this.
  2. Mar 21, 2021 at 7:04 AM
    Fred
    Hand Protectors
    My Rear o2’s were both zero Ohm and out of Spec with no check engine light. Not sure what was up with that, but ended up replacing all 4. The 2 fronts were Bosch and out of Spec (9 vs 13Ohm). Truck drives better. MPG creeped up a little and feels like way more torque. Denso all the way baby!
  3. Mar 21, 2021 at 7:40 AM
    Outbound
    Aaron
    Northern Alberta
    I look forward to your report.
  4. Mar 21, 2021 at 7:42 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I did mine in black cause I knew I wasn’t gonna be able to match the fawn color. I like the thickness of the wheel better since it’s pretty thin without anything.
    Tundra2 likes this.
  5. Mar 21, 2021 at 7:44 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm following you to here. Front 02 does the adjustments needed. Rear 02 flips the light on or off when needed. I completely understand the lack of flash for the CEL. No real damage like this example. When I had bad plug wires three years ago I was 70 miles from home, and it was 3:00 am. I limped her home CEL flashing the whole time.
    One thing I don't understand is if I have consistently documented my real world fuel mileage in this thread, and it consistently been in the 15 range. Why would it change immediately after my fouler install?
    What could be the variable? I'm driving on the same roads. I'm driving mostly the same way. If I had a heavy foot I documented that in the thread I linked earlier. I'm driving at roughly the same times, and got gas predominantly at the same gas station unless I just HAD to get gas elsewhere.
    So, my fouler was really as far as I was going to go into this rabbit hole. If it turned off my CEL, then great. I've been looking at that damned orange light since before I could drive.
    If the rear 02 only does "Hey your car don't work right" light then I'm still good. No engine harm just turning off a light.
  6. Mar 21, 2021 at 7:45 AM
    Fred
    Hand Protectors
    Might be after this Summer as mine historically (brand regardless) last about 1 year. Reason for my frustation in spending $$$ when we can save. The Denso should be quality. Hard to find and with shipping may be around $50 but the money is in future saving$.
    I’ll start working the autozoners in a few months picking their brainz for in store delivery.
    Outbound[QUOTED] likes this.
  7. Mar 21, 2021 at 8:01 AM
    Outbound
    Aaron
    Northern Alberta
    If they work well and are available here in the land of ice and snow, I may follow your lead. I've been using the Michelin wipers from Costco up until now. I probably run them longer than I should, but I would get a little over a year out of them as well but the quality of the wipe degrades by about month 8. These Bosch ran me $58 Canuckistani Pesos, and the Costco ones came in around $43 Canuckistani Pesos according to my records. Not a huge difference, especially if the Bosch are significantly better quality and I milk more life out of them.
  8. Mar 21, 2021 at 8:07 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @Richid maybe things are different for the 5VZ-FE engine. I've only got two sensors.
    Pre-cat, and post-cat.
    I do not have four Like the rest of yall
  9. Mar 21, 2021 at 9:17 AM
    Good morning neighbors! Open header start up, felt just like Ricky Bobby
  10. Mar 21, 2021 at 9:25 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I just put a leather wheel in.
  11. Mar 21, 2021 at 9:25 AM
    empty_lord
    05 rollover special
    5vz only has one bank
  12. Mar 21, 2021 at 9:27 AM
    empty_lord
    05 rollover special
    I’m afraid to say that’s just placebo effect. The rear sender does one thing only, it just reads to see if the cat is ok. You can drive with it completely off abs be fine (other than the check light)
  13. Mar 21, 2021 at 9:28 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Yup. Loncky Leather. It’s still the jam.
  14. Mar 21, 2021 at 9:43 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Okie dokie then
  15. Mar 21, 2021 at 9:45 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    I thought I heard some thunder coming from the southeast of me!
  16. Mar 21, 2021 at 9:48 AM
    Dannydirtyfingers
    Dannydirtyfingers New Member
    Texas RR
    2004 Tundra AC SR5 2wd
    5100 Bilsteins 4th notch, JBA uppers
    No pics, in the process of plastidip'in all the chrome...even though the paint on this truck sucks lol.. no suspension parts coming in yet so just doing little things.
  17. Mar 21, 2021 at 9:52 AM
    Richid
    Richid New Member
    Unless your going to set up one of those EPA labs, you'll never be able to factor out things like weather/wind/acceleration rate. If your local depot has switched to summer blend, you'll see a difference as well.
    So many factors that can impact mileage.
    It's much better to have the CEL light off so you can see if you are having other problems. My old pathfinder had it on for the rear O2's as well and I missed the misfire code until one of the coils actually failed. It would have been way easier than limping it to the dealer to pay full price for one. The only reason I used a circuit on it as that the location was tough to add one of those 'defoulers' due to space.
    But same result - as long as the light's off, you'll be able to see if a new code triggers it.
  18. Mar 21, 2021 at 10:00 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    :thumbsup: thanks for the education @Richid and healthy discussion. Lest I forget @empty_lord. :thumbsup:
    In other news, oil change.
  19. Mar 21, 2021 at 10:37 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    Lookout Mtn Georgia
    First wash in '21; been a bum for a bit.
    My baby and my daily beater...
  20. Mar 21, 2021 at 10:46 AM
    Seems like a lot more money and work. What's the best website to shop for used wheels?
  21. Mar 21, 2021 at 10:50 AM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Is that a c30 I see?? I grew up with volvos as my parents cars and Ive always wanted a manual c30
    Darkness, NUDRAT and abcinv[QUOTED] like this.
  22. Mar 21, 2021 at 11:17 AM
    empty_lord
    05 rollover special
    I got mine locally, but eBay is usually the best bet. Mines pretty mint
  23. Mar 21, 2021 at 11:35 AM
    abcinv
    Tommy
    Lookout Mtn Georgia
    It is; an R Design 6 speed.
    My last three daily's have been manuals; 1988 CRX SI 5 speed, 2013 Golf TDI 6 speed (loved this car) and now the 2011 C30.
  24. Mar 21, 2021 at 12:56 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Tried removing my step bars a few weeks ago and 1/2 breaker bar wasn’t going to cut it. Used it as an excuse to finally order my 1/2 cordless impact. Two bolts sheared right off and the others came out after rattling on them a bit. I think it looks cleaner, especially since the bars were getting pretty rusty.
    They weren’t joking when they said 1400ft/lb
    of nut bustin’ torque
    Before:
    After:
  25. Mar 21, 2021 at 2:30 PM
    Fred
    Hand Protectors
  26. Mar 21, 2021 at 2:58 PM
    Fred
    Hand Protectors
    Tool’d around on the truck today. Got her washed and AeroSpace 303’d.
    Sealed off a few holes from engine bay that connect with the Filter Box Intake Chamber to stop hot bay air from infiltrations. Swapped in new Denso Made in USA filter replacing the STP China. Big difference in feel and look.
  27. Mar 21, 2021 at 3:41 PM
    taranovich92
    taranovich92 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Nitto TerraGrappler G3 285/70/17, Apple CarPlay, CB radio, Randy Ellis Design front bar, Hella 500 rally lights, Mini LED projector headlights, Trailrunner Customs fogs, SkidRow Offroad skid plate, 333 Fab steering rack clamp.
    Gave the old TRD rear sway bar and hardware a refresh.
  28. Mar 21, 2021 at 4:08 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    It's not my choice because of it being a straight 90 weight. It's the additive package and fluid engineering. As long as it says 90 on the end, it meets the requirements for our diffs (ie: 75w-90 or 80w-90).
    I went through about 12-15 different gear oils with my pricier Cusco RS 2-way LSD and this stuff was the best for having good lockup without excessive chattering/clunking. Basically it comes with a proper amount of friction modifiers.
  29. Mar 21, 2021 at 5:18 PM
    Did some big beads on everything I could get to. Technically I started piping after nine and was cleaned up before 5. Custom making brackets and trying to hold everything up and tight as I could took the most time. The drive shaft has one of my fingers clearance(my dad had banana fingers, and I’m not far behind) and the lowest part is the x pipe which is basically flush with the frame rails/sliders so that’s good!
    21C5FB91-F66D-4F86-957F-EE800CD7BCA7.jpg B753EC33-CDC5-431F-BABC-B6DF37F44217.jpg 550C72DE-5A35-441F-8435-2E23CA25BF32.jpg 913D741E-8AEE-4152-BC37-5E7C3B0E9B0C.jpg
    Tomorrow I just have to finish the muffler exit over the axle and then pull it all down and fill weld! Also towards the end of the day I was getting that island breeze which isn’t conducive for mig welding!
  30. Mar 21, 2021 at 5:24 PM
    Fred
    Hand Protectors
    Island Breeze = 5 o’clock somewhere.
    Nice work. How much will you charge me to do mine?:D
