  1. Mar 20, 2021 at 5:00 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Wire harness connector on the trans probably has corrosion
  2. Mar 20, 2021 at 5:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I can tinker with this tomorrow.
    Unhook battery, and then unplug each connector one by one? Checking for corrosives, and anything amiss with the wiring before the plugs.
    I tried to find info on this error code on the FSM, but maybe I wasn't searching the correct key words.
  3. Mar 20, 2021 at 6:11 PM
    empty_lord
    05 rollover special
    Eh battery doesn’t need to be
  4. Mar 20, 2021 at 6:47 PM
    biebs96
    PA
    ok.. I don’t know why.. but I love this!
    I think I might need it.
    Jack McCarthy likes this.
  5. Mar 20, 2021 at 6:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  6. Mar 20, 2021 at 6:57 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Right? I saw it on a youtube where some guy used it for floor mats back in the early 00s and it got me thinking.
  7. Mar 20, 2021 at 7:29 PM
    Outbound
    Aaron
    Northern Alberta
    The Woman had her car into the dealership the other day for an oil change (they do it cheaper than I can...), so I had her pick up an oilfilter and air filter. Today I picked up some Bosch Icon wipers. Iirc, they carry the @Professional Hand Model endorsement.
    Tomorrow's project is to do the oil change, grease everything underneath the old girl and install the wiper blades.
  8. Mar 20, 2021 at 9:15 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    That’s a 20x9 -12mm offset
  9. Mar 20, 2021 at 9:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Who all is using deaver overload 3 leaf springs? Currently have the hellwig 991 helper spring sitting in my garage not installed but due to have 206K miles I may just go this. Plus I’d be able to get rid of my 1 or 1.5” block lift I have in the back I think.
  10. Mar 20, 2021 at 10:04 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Missed a tad...
    CodyP[QUOTED] likes this.
  11. Mar 20, 2021 at 11:39 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Yanked my 2wd stock 3.9 open diff.
    For this 4wd rear that is 4.1 w/LSD.
    FYI: 4wd and 2wd have slightly different pinion flange bolt spacing (60 vs 65mm iirc) and the flange needed to be swapped.
    I also installed a solid pinion spacer and a new pinion seal, before throwing it all back together.
    My fluid of choice for clutch type LSD's is Motul 90pa.
    Thrussn, RUSTYNUTS, MS22 and 18 others like this.
  12. Mar 21, 2021 at 3:41 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Since I've been monitoring my MPGS here I had data points to confirm improvement using oxygen sensor fouler instead of relying solely on butt dyno
    Initial data point says 1.41 MPG increase. :rofl:
    I'll take it especially with the trying times coming sooner rather than later... :poking:
    NUDRAT, Filthyphil and Voss like this.
  13. Mar 21, 2021 at 4:37 AM
    Fred
    Hand Protectors
    Yeah. Many here have recco’d them. I’m on my first set on the truck and MzPHM Mobile as they were replaced simultaneously. Pretty decent! Not happy about $52 per vehicle replacement cost as I’m used to the Old Sckool Refill Technique where just the rubber insert is swapped for about $3-4 per vehicle (old sckool price). The auto stores don’t offer the Old Sckool Technique anymore. Its Conspiracy!
    I’ve researched the Denso Designer Series Blades ($40/pair) which have the insert swap out capability and will buying those next. Will be using Tricos for the refills which are about $7/pair.
  14. Mar 21, 2021 at 4:41 AM
    Don't we have a few members that did a leather wrap on their steering wheel? I need to do this.
  15. Mar 21, 2021 at 4:43 AM
    Fred
    Hand Protectors
    :boink:
    Tundra2[QUOTED] likes this.
  16. Mar 21, 2021 at 4:46 AM
    Fred
    Hand Protectors
    Nice on the Straight 90 oil find! Looked hard a while back and not success. Asked around with no response but glad its out there. Stoked.
    Thrussn, MEWaters and Tundra2 like this.
  17. Mar 21, 2021 at 5:17 AM
    Richid
    Richid New Member
    All those do is pull the O2 sensor further out of the exhaust stream. If you installed them on the rear sensors, your data is contaminated by another variable as these sensor only monitor cat efficiency and do not impact fuel delivery.
    If you installed them on your front sensors (do NOT do this!), you are forcing the engine to run lean - which would show in fuel consumption and power loss. If you did this, check your plugs before you incur any engine damage, like burning or melting a piston.
    If your determined to run an engine at it's most efficient, do a full tune and custom map on a dyno.
  18. Mar 21, 2021 at 5:31 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Finally got both my new brake lines in! I don’t wish that tedious job on anyone. Both lines run down to a two port union fitting along the frame rail almost directly under the driver door. One runs across the fire wall to the ABS module and down the LH frame rail. The other runs from a “T” under MC down the LH frame rail.
    I had originally thought only one of the lines was leaking, but figured I’ll replace both while I’m working in that area. Glad I did both as I found that they both had pin hole leaks! The line that runs across the fire wall was very weak and snapped as soon as I tried moving it.
    EA474186-E006-4ACA-95A1-D26ED7008912.jpg 28C74F17-DC2A-4901-BDA4-131748112307.jpg
    Just need to finish bleeding system. Got the rear all done.
    MS22, NUDRAT, abcinv and 4 others like this.
  19. Mar 21, 2021 at 5:34 AM
    Fred
    Hand Protectors
    Nice job. Were these rusting from inside?
    MS22 and RustyShackle323[QUOTED] like this.
  20. Mar 21, 2021 at 5:42 AM
    RustyShackle323
    Stewart
    NC
    @Professional Hand Model no not rusting from the inside, all the brackets that support these two lines were completely rusted/broken away as shown below. It allowed the line to move/vibrate and wore the gray paint off overtime I suspect. This bracket is in the LH wheel well. They’re two other brackets after this one that too are broken. Got them coming.
    MS22, NUDRAT, Voss and 1 other person like this.
  21. Mar 21, 2021 at 5:42 AM
    Richid
    Richid New Member
    Wow - ya that's huge PIA. Last time I did pre-bent lines, it was all on a old 87 extra cab. Did not realize what a puzzle it would be to get all the lines actually under/through the truck.
    Has anyone used the nickel-copper lines as replacements? Was thinking of trying these when the next one rusts through.
  22. Mar 21, 2021 at 5:45 AM
    @RustyShackle323 I'm sure working with those hard lines isn't easy. That looks like torture. Nice work.
    MS22 and RustyShackle323 like this.
  23. Mar 21, 2021 at 5:48 AM
    RustyShackle323
    Stewart
    NC
    Yes sir, lot of profanity during this project haha. Move and inch, get hung up. Up down up down feeding it through the small opening down the frame.
    oscardog86, Voss, Tundra2 and 2 others like this.
  24. Mar 21, 2021 at 5:53 AM
    Fred
    Hand Protectors
    Ok. I suspected as it looked like bracket width rust. I noticed one of my clips was cracked whilst doing the fuel filter job and for bonus I cracked another one myself. Was able to use HD Wide Zip Ties to secure back and alongside the next line properly in the shared tandem clip above.
    I’ll be looking out more for these clips scenarios. May end up going new if enough are broken.
  25. Mar 21, 2021 at 5:56 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I am aware that they remove the sensor from the direct flow of exhaust gases, and it was installed on my post cat heated oxygen sensor. My reasoning for this was to clear my P0420 (cat below efficiency, My cat is bad) code.
    My understanding wasn't very clear as my brain broke all my readings down into basically this.
    1. Engine make boom.
    2. Boom makes exhaust using fuel/air combo.
    3. Engine monitor exhaust before, and after "treating" (cat) exhaust gases.
    4. Computer tells engine "We need more/less Air/fuel because we are out of target area."
    5. Engine adds more fuel/air to compensate for inefficiency.
    6. Compensation doesn't work.
    7. CEL for 02 sensors/cat.
    8. Engine can't get mix air/fuel properly.
    9. Engine runs rich/lean.
    10. Decreased MPG due to lack of proper mixing.
    If that incredibly dumbed down version of how it works is wrong, then by all means help me out. I'm always eager to learn new brain juice.
    NG.
    I'm not after peak efficiency because I'm not Ricky Bobby. I'm just after more efficiency without going full ape shit. My 3.4L V6 will probably never see a track lol. Tune, and dyno time aren't anywhere near my radar. Little things I can do on my own are on my radar.
    NUDRAT, Lil Steve, Voss and 2 others like this.
  26. Mar 21, 2021 at 6:00 AM
    RustyShackle323
    Stewart
    NC
    That is my plan. Just two more brake brackets and they are all fixed (that I am aware of). Seven total in total brackets will be replaced! It is a domino effect once one breaks. I added an extra one in the center of the fire wall for added support too!
  27. Mar 21, 2021 at 6:10 AM
    Fred
    Hand Protectors
  28. Mar 21, 2021 at 6:13 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I knew as I typed that you'd do this. lol
    Darkness likes this.
  29. Mar 21, 2021 at 6:46 AM
    Richid
    Richid New Member
    So - not really. Only the front O2 sensors provide feedback that is actually used by the ECU to adjust the amount of fuel.
    The ECU does not care if your cats are working or not - they do not affect optimal air/fuel ratio. The rear O2 sensors only job is to ensure that cat efficiency is met. They only thing the ECU does when the signal is out of range is trip a code which set the MFIL (CEL). This is also why 0420/0430 codes do not force a flashing of the MFIL, there is no damage caused by it.
    So, the rear O2 sensors can only turn on the check engine light, they cannot affect the amount of fuel used. That's why I indicated you are missing another variable in your MPG testing.
    And I'm not suggesting that you go for a full tune, but if you're going to play around with your engine management system without measuring the effect on your engine - don't be surprised if something bad happens. There is only so much energy contained in every drop of fuel and you can maximize how it used, but there's only so much an internal combustion engine can convert to mechanical energy.
    If your goal is just to turn off the monitoring of cat efficiency, you can disconnect the rear O2 sensors and send the ECU a signal that cat efficiency is in range.
    Hope that helps.
  30. Mar 21, 2021 at 6:55 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The nickel copper stuff is super nice. Bends easily without tools and it's a lot easier to flare.
