VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Mar 18, 2021 at 9:00 AM
    #5461
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Quick question here as im sure this comes up often, I do not see my base stock tune listed for my ECU ID on my 2008. Would this imply I dont have the latest TSB or my ECU needs to be added to support list ?
    I purchased the software bundle, waiting on my tune pack to arrive any day now.
  2. Mar 18, 2021 at 10:59 AM
    #5462
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    this ECU version is not supported yet. We are working on obtaining the stock data.
  3. Mar 18, 2021 at 12:21 PM
    #5463
    TX210Tundra
    Ok good deal, thank you for confirming that is very helpful !
  4. Mar 19, 2021 at 12:41 PM
    #5464
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I just tried flashing and get "Communication/ECM Error ERROR UNLOCK INVALID". This is after it says "KEY authorization success". Anyone else had this happen and know what I'm doing wrong?
  5. Mar 19, 2021 at 12:49 PM
    #5465
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Make sure you are using 1.2.9.9.2 and also make sure the file you're trying to flash matches your trucks ECU ID
  6. Mar 19, 2021 at 12:53 PM
    #5466
    snivilous
    SW UT
    Yea, ID is 3YWF3400 and Calibration ID is 3YWF3400. Version 1.2.9.9.2, drivers are updated too. I had a slightly tweaked file I first tried, then tried the file the "stock" file that comes with VFT and same thing happens with both. When I try to start the truck it does the usual gurgle on first try, then fires up on second try like the ECM got reset. Computer has internet access when I try too.
  7. Mar 19, 2021 at 12:54 PM
    #5467
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Ok send all details to zendesk I'll investigate further
    snivilous[QUOTED] likes this.
  8. Mar 19, 2021 at 2:43 PM
    #5468
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I have the exact same scenario. I don't know if you are already aware of this after our trial and error session a short while ago (9 March). I will send what is an almost identical screenshot to Zendesk.
    snivilous likes this.
  9. Mar 20, 2021 at 7:28 AM
    #5469
    apbreaux
    apbreaux New Member
    Paul
    CO
    2016 Tundra DC
    Intake, exhaust, remote starter, LEDs everywhere, OVTune
    Is there a simple tutorial on how to flash our ECUs with vftuner?
  10. Mar 20, 2021 at 7:56 AM
    #5470
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
  11. Mar 20, 2021 at 8:38 AM
    #5471
    apbreaux
    apbreaux New Member
    Paul
    CO
    2016 Tundra DC
    Thanks for that. I am upgrading from OCM51 to OCM52. First time starting truck it actually died right away. Waited a couple seconds then it started up. Let it run for a few seconds and shut it down. I'll take it for a test drive here shortly.
    HulkSmurf14 likes this.
  12. Mar 20, 2021 at 8:45 AM
    #5472
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That start and die is normal. Oftentimes the idle will be really low as well then will increase after running for 5-10 minutes.
  13. Mar 20, 2021 at 8:48 AM
    #5473
    apbreaux
    apbreaux New Member
    Paul
    CO
    2016 Tundra DC
    If I want to go back to OCM51 for any reason, how would I do that? Do I have to now unlock the OCM51 file?
  14. Mar 20, 2021 at 8:50 AM
    #5474
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I suppose you could just try to flash it, if you're not allowed to go back to it I would imagine that the software wouldn't flash it.
  15. Mar 20, 2021 at 9:03 PM
    #5475
    shellshock
    Iowa
    2019 TRD PRO
    You cannot revert the ecu to a previous version. You can only flash different tunes of that same ecu ID (including stock)
  16. Mar 21, 2021 at 6:46 AM
    #5476
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    But there was this↓ comment that may make that particular ECU an exception?
    HulkSmurf14 and Tyger like this.
  17. Mar 21, 2021 at 8:26 AM
    #5477
    apbreaux
    apbreaux New Member
    Paul
    CO
    2016 Tundra DC
    Yes. My question remains - Do I need to unlock the OCM51 to do this? I unlocked "OCM52 Upgrade" to gain access to that file. What's kinda throwing me is that the actual file that was uploaded is OCM51... . Anyway, just looking for some clarification before I start doing trial and error, and spending points. Thanks.
  18. Mar 21, 2021 at 8:45 AM
    #5478
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Personally, what I might try to do would be to see what happens when you try to select (Select Calibration File) the 0CM51 file without burning credits (unlocking).
    Hypothetically, it may be that the changes from 51-52 were so minor that Mat was able to "port/transfer" them over from 52 to 51 without technically changing the ECU ID. That may explain why he's said that you could "go back". Maybe he's essentially renamed 51 to 52 to keep track of the changes in his mind because they were so minor. It's possible that he could've renamed it "51b" or some such, but wanted to try to avoid confusion and a flood of questions among users by calling it 52 because that's basically what it is in the code and it mitigates the entire "upgrading your ECU ID" process. Just my thoughts though, I'm not trying to claim that it would be that straightforward or to assume that's Mat's process/solution.
  19. Mar 21, 2021 at 8:50 AM
    #5479
    apbreaux
    apbreaux New Member
    Paul
    CO
    2016 Tundra DC
    True. Hoping Mat would chime in with a definitive answer, but may try your suggestion. Much appreciated.
  20. Mar 21, 2021 at 8:56 AM
    #5480
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, but who knows what other fires he's probably trying to put out. For example, it looks like some 07-13 ECUs aren't playing nice with the software that he may be prioritizing, or even something pertaining to a different vehicle model.
    apbreaux[QUOTED] likes this.
  21. Mar 21, 2021 at 3:08 PM
    #5481
    shellshock
    Iowa
    2019 TRD PRO
    Huh weird
    I musta missed that post. Must be something new that’s been added
  22. Mar 21, 2021 at 4:33 PM
    #5482
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Or an anomaly. Anyone's guess.
  23. Mar 21, 2021 at 6:29 PM
    #5483
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Yes just flash the 0CM51 file.
    So with our tundra software, we are making *backwards* compatible upgrade cals, which means you can go back to the previous version if you want to.
    For example 0CM51 - select 0CM52 upgrade - and you are backwards compatible now.
    Same with 0CL43 (being added) to 0CL44
    Etc etc
    Important to know that to retain backwards compatibility you must select the "upgrade" file.
    This will be covered in our new instructions
  24. Mar 22, 2021 at 7:32 AM
    #5484
    apbreaux
    apbreaux New Member
    Paul
    CO
    2016 Tundra DC
    Thanks, Mat. Which file should I make changes to when I start making changes to the ECU (eg, OCM52 Upgrade or OCM52)? Thanks.
  25. Mar 22, 2021 at 7:47 AM
    #5485
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    Mat,
    When using the Toyota Flash Tool to flash a Tundra ECU (in my case, a 0CP50) tune, does the tool automatically reset the TCU adaptation values, and thus is it possible to receive some rough shifting as the truck relearns its values?
    Vr0ck likes this.
  26. Mar 25, 2021 at 10:09 AM
    #5486
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    It resets fuel trims, and other stored / learn values yes.
    Also, vF Tuner 1.2.9.9.3 releases tomorrow, support for 0CL43 added, among other things.
    still working on obtaining 0CA33.
    Crazy that there are still more dang calibrations out there. Never ending!? supply of new IDs....
    Vr0ck likes this.
  27. Mar 25, 2021 at 10:20 AM
    #5487
    realprotundra
    realprotundra Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock TRD Pro DC
    Any word on 2021 support? I was hoping that with you being the proud owner of a 2021 we might get a speed boost on the support :)
  28. Mar 25, 2021 at 10:58 AM
    #5488
    TX210Tundra
    Thank you for the update
    I keep saying "The juice is worth the squeeze"
  29. Mar 25, 2021 at 5:41 PM
    #5489
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    Hey Mat, Will any of these releases have any tune packs available for the 2019 Toyota Tundra FFV 3URFBE? Do I need to send anything to you or to Zendesk about
    Direct shift and gear lock?map switching?
    Tyger and Vr0ck like this.
  30. Mar 26, 2021 at 7:15 AM
    #5490
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Not yet sorry.
    Tune packs w/out those features are being made at this time.
    FitsofRage88[QUOTED] likes this.
Thread Status:
