**SOLD** 2007 Sequoia Limited 4x4 Speedo Cluster (for swap into double cab)
Discussion in '1st Gen Tundra Parts Marketplace (2000-2006)' started by 912, Feb 11, 2021.
Thread Status:
Not open for further replies.
  1. Feb 11, 2021 at 9:49 AM
    912 [OP] @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    If you want to swap your DC cluster for the LED Sequoia cluster, this is the one to use. I searched high and low for this for awhile. It's from a 2007 4x4 in MPH with air suspension (the only one that works). Has right about 129,000 miles on it. Has the beautiful tinted plastic with all LED gauges and needles. It looks like Lexus tbh. I swapped this into my 2005 and it is super sweet, but I decided to go another route, as I don't want to mess with the mileage of my truck. There are some FB and forum posts about this swap if you search. If you're interested in maintaining the integrity of your mileage, there are services available or DIY videos (out of my scope). The only thing that doesn't work right out of the box is the coolant temp, which there is a workaround for.
    S O L D
    CF9F5633-C9BD-417C-8137-130FF84DF240.jpg 9A97E77E-9025-4957-B01C-4274382EC824.jpg 552EC36E-FA35-4094-BAD5-719AA313701E.jpg B5B7DC9C-7451-44C5-BBE5-D29222C75556.jpg
    https://youtu.be/5EtIgYBQNJY
    FirstGenVol likes this.
  2. Mar 18, 2021 at 11:59 AM
    Tangency
    Tangency New Member
    JD
    '05 Tundra SR5 Double Cab 4x4 4.7L in Spectra Blue Mica
    Lifted, 1.5" spacers w/ LT 275/70R 18's w/ Cooper Discoverer AT3, & helper springs.
    Wow, I have not done the research on this mod but I have to know, was this plug and play in your 05 DC?
    Tundra2 and 912[QUOTED][OP] like this.
  3. Mar 19, 2021 at 12:40 AM
    2005 DC 4x4
    Yep plug and play for 05-06 except the coolant temperature doesn’t register and the tpms light stays on.
    ramnozack212 and Tundra2 like this.
Thread Status:
