  1. Mar 18, 2021 at 6:06 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That demon has been staring at me since 2009. Before I could even drive lol
  2. Mar 18, 2021 at 6:06 PM
    luck of the Irish
    While I was mocking up some exhaust pieces this morning I saw my neighbor ride by on his bicycle and yelled what’s up, he pulled in and asked what I was doing; he’s the one that loves when I make loud noises on the weekend and such and actually doing stuff to my house not hiring someone. He sounded excited to hear the open header start up!
    He came walking back 20 mins later with both hands full, he had a rake and a different trench shovel; delivered, do you want either of these, he said? I acted koi and said I’d take the rake(I broke my handle on mine months ago) and couldn’t pass up a shovel I don’t own two of. @Professional Hand Model this might have been better than a curb side find for me today!
  3. Mar 18, 2021 at 6:07 PM
    Fred
    Hand Protectors
    Truck running better or feel the same? Nice on the light/code elimination!
    Tundra2[QUOTED] likes this.
  4. Mar 18, 2021 at 6:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Butt dyno says slightly better. Feels slightly more "right" if that makes any sense?
  5. Mar 18, 2021 at 6:18 PM
    Fred
    Hand Protectors
  6. Mar 18, 2021 at 6:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  7. Mar 18, 2021 at 6:27 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    285/70/17. The Cooper ATP that I had on there were the same size but these are considerably larger.
    Thanks for that, I’ve put a lot of love into this ol girl.
    Edit: I feel like I should mention that they are the E range. For some odd reason, every single resource lists the E range Wildpeaks as being 6lbs lighter than the C’s.
  8. Mar 18, 2021 at 6:40 PM
    costman13
    costman13 New Member
    Cam
    Oregon
    2003 AC Tundra TRD 4x4
    OME 2885, Nitrochargers, SPC UCA, Wheelers AAL, Firestone Ride-Rite Airbags, Method 701 & 285/75R16 Toyo Open Country AT III
    Before
    After
    OME 2885s w/ Nitrochargers all around, Wheelers Progressive AAL / Firestone RideRite Airbags, SPC Uppers, Method 701 16x8 and 285/75R16 Toyo Open Country AT IIIs.
    I also changed out the LCAs, CVs, swaybar links...
  9. Mar 18, 2021 at 7:37 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    They look good. I forget, are you running spacers cause these look pretty darn good as far as poke goes. Any profile shot?
  10. Mar 18, 2021 at 7:42 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Correct, I am running Spidertrax 1.25”spacers front and rear. I’ll try to get a side shot tomorrow. These tires sit almost dead flush with the flares due to that huge tread bump on the sidewall.
    I am almost certainly going to have to get out the BFH tomorrow too. I’m getting some gnarly rubbage.
  11. Mar 18, 2021 at 7:45 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I have the same spacers but still in the boxes as they are too much with my 20” wheels currently. A side shot would be lovely if you have the time please.
  12. Mar 18, 2021 at 7:49 PM
    oscardog86
    oscardog86 New Member
    Southern California
    I'm getting a squealing from my engine when I turn the wheels, sometimes when just turning them or when I turn them all the way to full lock and Im thinking I should replace my serpentine belt. Would this be a good thing to do to fix a steering squeal? My power steering fluid looks clean and everything functions fine, im just getting the noise here and there.
    It only happens when Im going at slow speeds and Im guessing theres extra strain on the steering at that time.
    Looking at OEM parts it looks like its called V- belt? Ive just started researching this so dont know much about what im talking about but figured Id ask you guys. Also, is this a relatively easy job to do? Thanks!
  13. Mar 18, 2021 at 8:01 PM
    Serp, idler and tensioner if your in there, which requires a bit work but worth it
  14. Mar 18, 2021 at 8:07 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Going to do this to mine soon. Getting a little screech when I do an aggressive take off.
    Thrussn and Tundra2 like this.
  15. Mar 19, 2021 at 5:35 AM
    Richid
    Richid New Member
    Ya - learned the hard way that these are now maintenance items when the old F250 started making a horrible noise. Stopped to pop the hood an noticed that the idler bearing seized. Luckily it actually snapped the pulley so the belt was turning the remaining piece of the pulley around the old bearing center.
    Lots of sparks, turns out you can't run idlers/tensioners/belt for > 16 years.
    Now this is on my list for the Tundra - I know the belts been changed but I think all the other parts are original.
  16. Mar 19, 2021 at 5:54 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    When engine overhaul happens I plan on replacing idler bearings and other spinny things. Using cruise control truck will rev right up to 5k rpm (Edit: on hills when i forget to turn it off before hill.) Screeches like two cats fucking in a dumpster at 4,200 rpm
  17. Mar 19, 2021 at 5:55 AM
    Fred
    Hand Protectors
    I highly recco the Green Gates HD Belt. Stout at almost twice the weight as my fairly newer 2 year old Continental Belt by Goodyears.
  18. Mar 19, 2021 at 6:12 AM
    oscardog86
    Southern California
    Thanks for the heads up, Im guessing i should get OEM for all those parts except the green gates belt that was recommended by PHM?
  19. Mar 19, 2021 at 6:14 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    That belt is like a librarian with lace under her frock.
    ...and I see a rusty bolt, bottom of that picture.
    :boink:
  20. Mar 19, 2021 at 6:18 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Its hard to write text with a mouse....
  21. Mar 19, 2021 at 6:18 AM
    Fred
    Hand Protectors
    Nice incorporation of the word Frock!
    Yeah. Since the Timing Belt Job, I discovered a few Rusty Nuts. Been working them aggressively with 3in1 Oil. Improving! :rofl:
    RUSTYNUTS, NUDRAT[QUOTED] and Tundra2 like this.
  22. Mar 19, 2021 at 6:22 AM
    Fred
    Hand Protectors
    Yeah. Thats a New Toy OEM Hose. Got some Crankle going on with it. :annoyed:
    Bottom Lower Hose looks even worse in pics, but to the eye looks normal. :D
    NUDRAT likes this.
  23. Mar 19, 2021 at 6:27 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I highlighted newt. Hose was good contrast for shitey mouse type.
    NUDRAT likes this.
  24. Mar 19, 2021 at 6:30 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Rounded newt. Least you still got yours.
    I know a fella with one newt. He adorned himself with a new nickname I can't say publicly. :gossip:
  25. Mar 19, 2021 at 7:26 AM
    oscardog86
    Southern California
  26. Mar 19, 2021 at 7:37 AM
    Fred
    Hand Protectors
    No need for TB parts although your job will be halfway there. I got the GatesHD from a site thats too big and needs broken up.
    All other parts I procured via local stealer parts programme. The Acc. Belt Tensioner is a newer design (just a heads up). Didn’t click your links, but you need the Accessory Belt Tensioner (not Timing Belt), Idler Pulley, and most important (IMO) the Fan Clutch Pulley. Mine was grindy and had a cold morning chirp.
    Might as well put on a new Fan Clutch, as well. My new one pulls so much more air and works like new again.
  27. Mar 19, 2021 at 7:40 AM
    oscardog86
    Southern California
    Thanks PHM for the heads up and steering me in the right direction! I like your description for "A site thats too big and needs broken up" hahaha
  28. Mar 19, 2021 at 7:42 AM
    Fred
    Hand Protectors
    Yeah. I’ve been sending hidden signals around here and I think they are on to me. Might need to go into the Marbles Protection Programme soon.
    NWPirate and oscardog86[QUOTED] like this.
  29. Mar 19, 2021 at 7:44 AM
    oscardog86
    Southern California
    I see the gates belt in the parts list on the bottom of this forum page. It says micro V belt. Is that the correct belt?
  30. Mar 19, 2021 at 7:46 AM
    Fred
    Hand Protectors
    Yes. Now I know Smart Dust is real. This guy was telling me about it a few weeks ago.
