USB charging??
Discussion in 'Audio & Video' started by Bammer, Mar 16, 2021.
  1. Mar 16, 2021 at 5:04 AM
    Bammer
    Bammer [OP] I'm disinclined to acquiesce your request.
    Monroe, CT
    I use Waze when traveling and just started plugging my Samsung S9 into the USB port . After my usual 3.5 hour trip to upstate NY, the phone battery is at 17% after starting at 95% +. It will charge the phone (powered off) to 37% or so after 1.5 hours? Is this typical?
  2. Mar 16, 2021 at 5:05 AM
    War Machine
    War Machine SSEM # 5 3MW
    No, not at all. Mine would be at 100% after that amount of time, even using a navigation app the whole time.
    Bammer[OP] likes this.
  3. Mar 16, 2021 at 5:39 AM
    Bammer
    Monroe, CT
    Hmmmmmmmmm????
  4. Mar 16, 2021 at 5:49 AM
  5. Mar 16, 2021 at 6:19 AM
    What type of charger? Cheaper ones can do this
  6. Mar 16, 2021 at 6:24 AM
    Bammer
    Monroe, CT
  7. Mar 16, 2021 at 6:24 AM
    Bammer
    Monroe, CT
    Samsung cord, came with the phone.
    T-Rex266[QUOTED] likes this.
  8. Mar 16, 2021 at 6:25 AM
    :thumbsup:
    Sean492 likes this.
  9. Mar 16, 2021 at 6:35 AM
    Bammer
    Monroe, CT
    Easily changed, or a lot of disassembly?
  10. Mar 16, 2021 at 6:38 AM
    10 minutes tops.
    Pull the dash peice out, unplug, file the hole to make it fit better, plug into original harness and tape up then replace.
    Bammer[QUOTED][OP] likes this.
  11. Mar 16, 2021 at 6:38 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  12. Mar 16, 2021 at 10:38 AM
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    2023 Black SR5 Crewmax Long Bed
    Why not just get one of the 12v plug ins that has the dual usb on the back of it??
    But if you do want to swap it out, the hardest part is getting the damn stock one out of there. I just installed a HDMI port in there for my head unit and getting the stock one out without breaking it was a B.
  13. Mar 16, 2021 at 10:59 AM
    Bammer
    Monroe, CT
    I use the 12v port for my GPS
    BravoDeltaRomeo likes this.
  14. Mar 17, 2021 at 4:32 AM
    Bammer
    Monroe, CT
    Looks like that Amazon replacement goes where the cig lighter is now? I want to keep that, will the afore mentioned unit from amazon go where the usb ports are now?
  15. Mar 17, 2021 at 6:09 AM
    BlueCrushSC16
    Charleston, SC
  16. Mar 17, 2021 at 6:41 AM
    Bammer
    Monroe, CT
  17. Mar 17, 2021 at 6:52 AM
    Bammer
    Monroe, CT
  18. Mar 17, 2021 at 7:06 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    That's weird that when your phone is being plugged in, that you went from 95% > 17%. If you're using AndroidAuto, shouldn't it be charging your phone while you use Waze via the infotainment?
  19. Mar 17, 2021 at 7:39 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Would this work swapping out the one on the rear of the center console for the backseat? No clearance issues? I will occasionally have people back there for a 4ish hour drive and they usually only bring cords with them.
  20. Mar 17, 2021 at 7:42 AM
    Bammer
    Monroe, CT
    X2, seeing as I already bought it and won't be using it for the front..
  21. Mar 17, 2021 at 9:07 AM
    BlueCrushSC16
    Charleston, SC
    Not plug and play. You have to solder the pigtail onto the OEM wiring.
  22. Mar 17, 2021 at 9:08 AM
    BlueCrushSC16
    Charleston, SC
    You'd have to verify clearance as far as depth. You'll have to enlarge the hole a little bit a cut/ solder in the wires from the new plug.
  23. Mar 17, 2021 at 9:27 AM
    Bammer
    Monroe, CT
    OH...………….. Not fond of that...……………...:pout:
  24. Mar 17, 2021 at 9:41 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Why use both?
    Waze is by far better than a basic garmin
    Why not use an ANKER fast charger at the 12v outlet.
    Since it has 2 USB ports, just get a USB connector for your GPS.
  25. Mar 17, 2021 at 9:47 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    I installed a 2 port fast charger in my 4runner
    1: on/off switch for the USB ports. They are connected (and fused, of course) directly to the battery. I've read that USB ports power drain even when off.
    2: USB ports (12v 3a)
    Both are hooked into the dash lights and light up when on. I have a deep cycle battery and use these ports a lot when camping.
    Forgive the hanging wires and ARB switch, it's just the picture I had available to show the USB stuff.
  26. Mar 17, 2021 at 9:50 AM
    Bammer
    Monroe, CT
    Great point
  27. Mar 17, 2021 at 9:53 AM
    Bammer
    Monroe, CT
  28. Mar 17, 2021 at 10:07 AM
    Bammer
    Monroe, CT
  29. Mar 17, 2021 at 5:24 PM
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    Do you not have 2 of them? I also have USB ports in the armrest and on the back side of the console.
  30. Mar 18, 2021 at 3:15 AM
    Bammer
    Monroe, CT
    YES... Now that I looked at it closer! Two years in a vehicle and I don't know this?:oops::oops::oops:
