  1. Mar 16, 2021 at 1:40 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    when I replaced my driver side trim those clips broke off. Wish I had a picture to show you what they look like. But you have an AC so they are cheap to replace if they are looking old and worn
    Jack McCarthy likes this.
  2. Mar 16, 2021 at 1:42 PM
    So if I remove those clips, the seal just pulls strait up?
    There is 19 years of dirt under there that keeps running down and staining the paint. I want to clean it up under there.
    Voss and onesojourner like this.
  3. Mar 16, 2021 at 1:45 PM
    Why not just replace it? Is there any felt left or is it just scraping against the glass? I believe it does pull straight up IIRC.
    Darkness likes this.
  4. Mar 16, 2021 at 1:47 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @FirstGenVol they are surprisingly hard to remove. When I removed mine it was clear they wouldn't go back on again. Idk how some remove them for paint and keep them in good shape. Several tabs snapped too.
    When you go to put them back on, push them way forward to the mirror. I had to fight mine a bit and didn't line them up proper, now I have a weird overlap on the handle side that would drive you insane. I'm too afraid to break them to pull them again and they're locked down.
    This part needs to go further in
    Or else you'll get this shit
  5. Mar 16, 2021 at 1:47 PM
    Last time I checked they were mucho dinero. I'll check again. Either way I have to remove to clean under them. The felt feels decent but the outside is rough from the sun.
  6. Mar 16, 2021 at 1:53 PM
    @Darkness
    This feels sketchy. The mangler is learning. I'm going to check for parts before I destroy these. The white clips will for sure snap but I almost wonder if they are even necessary to hold it down.
  7. Mar 16, 2021 at 1:54 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    They are a bit expensive. I went through @Roman because I couldn't find genuine for less. I was afraid of how aftermarket may fit funny (wouldn't matter now).
    Jack is right, they pull straight up but they are really hard to get out. I used a plastic trim tool.
  8. Mar 16, 2021 at 1:56 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The clips are necessary and I think part of where I messed up is they have alignment spots on the door that have to be met. You have to slide them around a bit on the strip to get the alignment right. I aligned mine best I could to meet the corner by the mirror but I was off by around 1/4".
  9. Mar 16, 2021 at 1:58 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Best success is to tape off and paint the trim in place on the door. I’ve done this at least twice successfully. Too many Mangle Stories on the pull off from others and like Darkness may end up with a Janked piece on put back.
    Conclusion: Low Risk/High Reward is to spend a little time on Blue Tape off and paint and not worry about having to buy an expensive item. If buying new ones is the entry strategy then pull off has to happen regardless.
  10. Mar 16, 2021 at 2:01 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    PHM is right ^ but might be hard to clean what you want. The rubber crap was too hard to peel off of mine, painting in place was my original thought but mine were chipped to hell.
    Whatever you do, don't use the impact gun here :D
    They shipped in an unusually large box too. It was seriously huge. I was expecting like a poster tube size package, you could fit a pair of front axles in the box they arrived in.
    FirstGenVol likes this.
  11. Mar 16, 2021 at 2:01 PM
    @FirstGenVol This might be helpful... I remember having to cut the OEM replacements since they were too long.
  12. Mar 16, 2021 at 2:23 PM
    I bet they are close to the same but on the 4runner I think I gently lifted the lower edge which exposes part of the clip, then used a bamboo skewer and pushed in as I tried to lift up. I also put tape below so I wouldn’t scratch anything
  13. Mar 16, 2021 at 2:23 PM
    Yes if it were not for the gunk under there, I would just paint in place like PHM is suggesting. You should see how nasty it was behind my mirrors when I removed them. All that crap was running down every time it rained and the stains were so bad at times that I had to wax them off. Soap wouldn't do it. The same thing is happening with these seals.
    @Jack McCarthy solid link you shared there. They actually are not as expensive as I was expecting and one person claims they come with the new plastic clips. I might have to spend some of my "stimilis monies" on these.
  14. Mar 16, 2021 at 3:09 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I had a Honda many years ago and brushed on some flat black rustoleum. It looked great for a decade after when I sold the car.
    Thrussn likes this.
  15. Mar 16, 2021 at 4:53 PM
    GeoB
    GeoB New Member
    Geo
    02 Tundra AC SR5 V8 TRD
    Had the driver side after-cat curve into y pipe fall off my tundra last week while going to pick up a cap. Just got a pipe bent to fit and had the shop cut the resonator out (also rusted, leaked like a sieve), and put a flowmaster 40 on that my buddy gave me. Super impressed with how little drone there is, since I do a lot of road running. Haven't really given it the full out-of-city road test yet but, that's happening tomorrow.
    My first baby step into the custom exhaust world...Probably will rust this setup into the ground and then look at a full system upgrade.
    Now to get back to sealing up my cap for backwoods camping!
    MS22, NUDRAT, Tundra2 and 1 other person like this.
  16. Mar 16, 2021 at 5:24 PM
    Well first NUT on the donut clamp at the exhaust stripped like it was made of rust! Cut the bracket off. All other bolts came out or snapped them off(at the header collector most of the snapped) I started on the driver side, trying to remove the dip stick; stupid suction accumulator for the AC gets in the way, so I started to loosen the motor mount but it’s dinner time soon. Tomorrow I’ll get at it, full tare down up to the manifolds was around an hour, hopefully tomorrow will go smoothly
  17. Mar 16, 2021 at 6:19 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Stopped a police chase. And funded a new front bumper build in process.
    Here is to felons that run from the cops but keep up on their Statefarm Payments!
    theblurry1, MS22, CodyP and 14 others like this.
  18. Mar 16, 2021 at 6:23 PM
    Congrats!
    I thought I was just reading somewhere, that you loose coverage if your committing a crime?
  19. Mar 16, 2021 at 6:26 PM
    A PT cruiser isn’t really much of a get away vehicle. :rofl:
    theblurry1, oscardog86, Voss and 3 others like this.
  20. Mar 16, 2021 at 6:45 PM
    Siebler
    CJ
    Eastern Oregon
    Uninsured motorist insurance will have me covered if not it sounds like. Also the damage us very minimal.
    Best part is dude tried to run on foot. Singular foot because the other one was in a cast from last weeks encounter with a k9 officer. People are fucking stupid.
    Basically he turned into my Cul-de-Sac, spun it around in an "OH SHIT" moment and hit my rig. Then he tried to run into my house where he was luckily (for him) tackled on my front porch.
    "Did you witness any use of force?"
    "Not near as much as if he had made it inside!"
    Pucks18, theblurry1, MS22 and 7 others like this.
  21. Mar 16, 2021 at 8:02 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    I feel like I should have these on my truck
  22. Mar 16, 2021 at 8:30 PM
    Voss
    2003 AC TRD 4x4
    The shop I had paint these on my truck looked beat after they completed mine. Dude told me getting these off was extremely difficult.
    oscardog86 likes this.
  23. Mar 16, 2021 at 8:39 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    My driver side one is exactly like that. It came that way from the factory, which only proves it's that much more difficult.
    Darkness[QUOTED] and oscardog86 like this.
  24. Mar 16, 2021 at 8:47 PM
    Thrussn
    Gabe
    NM
    I installed new shoes and brake hardware today. I reused my oem drum since it was barely worn and still in round. Plus I've read empty_lord's horror stories on non-oem drums. I just hit them with a coat of gloss black paint.
    I had to reuse the springs for the star adjusters just because the autostoned ones were too tight and making the mechanism bind up.
    I took PHMs advice and made sure I put some brake grease on the friction points on the dust shield thing.
    I should be in the clear until I do my rear disk conversion in a year or so probably.
    MS22, Darkness, des2mtn and 4 others like this.
  25. Mar 16, 2021 at 10:10 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    There is no shortage of crazy in this post. Oddly, the graphics on the PT Cruiser barely hit the radar.
    Whew. Glad things are mostly okay.
    MS22 and Thrussn like this.
  26. Mar 16, 2021 at 11:54 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Going through pictures, and deleting items as necessary. Found my screwdriver I bought, and used for the rear star wheels.
    This little guy worked wonders back there.
    NUDRAT, des2mtn, oscardog86 and 3 others like this.
  27. Mar 17, 2021 at 1:59 AM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    My driver side looks like the bottom one.
    Darkness[QUOTED] likes this.
  28. Mar 17, 2021 at 3:48 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Maybe the 05-06 have the accumulator sitting up a bit higher, but I changed out the dipstick tube no problem on my 04 as it was in bad shape. I was able to get really good access to the bolt from underneath the truck and a long extension.
  29. Mar 17, 2021 at 5:07 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Updated my latest post in the build thread with comparison shots with the new to me VLEDS reverse light bar.
  30. Mar 17, 2021 at 6:30 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I installed an oxygen sensor fouler today. The kit I ordered came with pieces for a Screw in type sensor also.
    I'm guessing that these threads are for the V8 screw in types.
    I don't have need for this, because both of my 02 sensors bolt on. It's for sale. Send me a PM.
    I don't see any need in starting a FOR SALE thread just for this little thing.
    Thrussn likes this.
