Help on posting new thread
Discussion in 'New Member Introductions' started by Hogdog, Mar 15, 2021.
  1. Mar 15, 2021 at 10:12 AM
    Hogdog
    Hogdog [OP] New Member
    Stephen
    Orange Grove, Tex
    2001 Black Tundra SR5 Flatbed
    Flatbed installed 19 years
    I have read All navigation thread. I have lost two both trying to post them. Do I select upload file or create thread. Thanks for any help.
    Prostar 190 and YardBird like this.
  2. Mar 15, 2021 at 10:48 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    To post a new thread, go to the forum where you want to post it and click on the blue button in the top right corner that says "Post New Thread." You will be asked for the title and the body of your new post.
    Jim LE 1301, Hogdog[OP] and Bob like this.
  3. Mar 15, 2021 at 10:54 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
    Hogdog[OP] likes this.
  4. Mar 15, 2021 at 10:56 AM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    What @Bakershack said above and you can also try the pencil at the top-right of the page
  5. Mar 15, 2021 at 10:57 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I'm not sure I fully understand your question, as it seems you figured out how to post a new thread. Is there something else you're trying to do?
    Hogdog[OP], Bob and BravoDeltaRomeo like this.
  6. Mar 15, 2021 at 10:58 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    The same way your created this one? :facepalm:
  7. Mar 15, 2021 at 11:16 AM
    War Machine
    War Machine SSEM # 5 3MW
    No
  8. Mar 15, 2021 at 11:17 AM
    Hogdog
    Stephen
    Orange Grove, Tex
    2001 tundra 4×4 flatbed. Right taillight went out.Flatbed was installed by dealer when new. Never any problems other than new taillight every now and then. I have read and read the thread on flatbed here. and on another forum. Will try not to make this too long. Live on farm, multiple trailers and equip. Not totally lost. Old light was led two wire. Bought two cheep lights at part place both three wire. After installing one, still nothing.would light up. Checked ground wire res 320 OHMS. Have wiring diagram. Found ground under right kick panel corroded. Cleaned and used diaelectric grease. Light worked on all functions. Left tailight working fine. You know, both taillights would be blinking when combo switch on right turn. While blinking. I checked ground, zero resistivity. NOTICED, when engaging RH blinker the ohms are going from 0 to 320 in sequence when light flashes. Ran a wire from neg batt post. Same problem. I solder all connections. Drilled and tapped frame ran another ground. Same. Replaced with new taillight and removed trailer wires too. Has factory colored wires. Same problem. Replaced flasher. Same problem. Before, tearing in to combo switch, I have questions. The taillights are 3 wire push in wire loom w/ ground on on mounting stud double nutted. Could the. Blinker wire be contacting the internal ground and causing ohm surge ? That would create a dead short right ? Do I need to go to truck parts and buy a better light ? Do I need a hodgens switch. Do I just buy a new combo switch. I thought I knew a little !!! Would greatly appreciate any help.My great grandsons think Im stupid now
  9. Mar 15, 2021 at 11:31 AM
    Welcome from The RGV
  10. Mar 15, 2021 at 11:43 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  11. Mar 15, 2021 at 12:04 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Any red-lensed, three-wire light bought at a parts store probably has a single two-element bulb that combines all functions, i.e. tail/stop/signal, into one light. One wire for tail light, another wire for stop/signal, and the third wire for ground.
    You refer to a "combination switch". If this something the dealer added with the flat bed? I'm unfamiliar with Gen1 Tundras, but prior Toyota trucks had the tail/stop/signal functions divided differently than US products. When I added a trailer receptacle to my 86 4Runner, I had to include a small black convertor box in the harness to provide separate tail light from stop/turn function. If that was a "hodgens" box, I would try replacing that if systematic electrical trouble-shooting is unproductive. They aren't that expensive as I recall.
    Welcome from the Texas Hill Country.
  12. Mar 15, 2021 at 7:24 PM
    Welcome from Ohio
  13. Mar 16, 2021 at 9:35 AM
    The Californian
    Eric
  14. Mar 17, 2021 at 7:26 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  15. Mar 17, 2021 at 7:32 AM
    Welcome from NY.
  16. Mar 19, 2021 at 5:34 AM
    Hogdog
    Stephen
    Orange Grove, Tex
  17. Mar 19, 2021 at 5:40 AM
    Hogdog
    Stephen
    Orange Grove, Tex
    Thank you John. I am going to buy an isolater. I have everthing hooked up on three wire but as you probably know the brake light overcomes the right turn signal.Love the Hill Country. I live in Brooks Co.
  18. Mar 19, 2021 at 5:49 AM
    JohnLakeman
    When you click "Quote", you can then add your new message directly below the quote in the reply box, and they'll come out together on your post.
    I've done a little more research on those "black boxes", and these days, they are used in reverse from mine, i.e. for towing a (edit: three-wire) system vehicle behind a (edit: two-wire tow) vehicle (?). :crazy: If you have a black box now, just be mindful of the "Input" and "Output" descriptions on the new box, and what you're trying to accomplish.
    I didn't know anything could go wrong with the "block box", but if you've done your due diligence looking for voltage, then...maybe that's it.
  19. Mar 19, 2021 at 5:51 AM
    Hogdog
    Stephen
    Orange Grove, Tex
    I see where your coming from Pal. A pro answered my dissertation politely. Just let this old dog lay.
  20. Mar 19, 2021 at 6:26 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  21. Mar 19, 2021 at 8:00 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
