Gen 1 Raptor Grill Lights
Discussion in '1st Gen Tundras (2000-2006)' started by jerryallday, Mar 11, 2021.
  1. Mar 11, 2021 at 7:14 PM
    jerryallday
    jerryallday [OP] New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Going to be installing some Raptor Grill lights tomorrow (three), it's a homemade kit. I will be filming an install video also and adding pictures.
    Would anyone be interested in a kit? Trying to see if there is any interest.
    kb7 and MS22 like this.
  2. Mar 11, 2021 at 8:04 PM
    Kcrusher62
    Kcrusher62 New Member
    Interested, would kit be grill specific or more universal fit?
  3. Mar 11, 2021 at 8:53 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Do you have an example of what you would like to see?
  4. Mar 12, 2021 at 4:27 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    I’m curious...
  5. Mar 12, 2021 at 9:50 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Here is the look(s) I am going for
    [​IMG] [​IMG]
    bulldog93, Rej1stGen, MS22 and 2 others like this.
  6. Mar 12, 2021 at 2:27 PM
    Kcrusher62
    Nice looking lights, not to big and spacing fits for 4 lights. Any more info pics/video and price info would be great
  7. Mar 15, 2021 at 7:01 PM
    Cbaldwin
    Cbaldwin New Member
    Casey
    2000 tundra black limited
    I’d be willing to buy a kit. A picture of what yours came out like would be great
  8. Mar 15, 2021 at 8:41 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Below is a photo
    sorry for the delay, I was waiting to black out my grill this weekend. Also waiting on new fog light bulbs to match the headlights.
    Lights connect to the headlights with a fuse tap. Working on getting the kit all dialed in so it’s an easy install. I went with amber and also looking into other options and placements for mounting
  9. Mar 15, 2021 at 11:24 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I prefer the look of 3 lights but......
  10. Mar 15, 2021 at 11:42 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Have an updoot for proper use of star trek meme.
  11. Mar 16, 2021 at 4:13 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Pics of Fuse Tap? And location Tapped? Pics of Kit?
    Come’on man...:D
  12. Mar 16, 2021 at 4:55 AM
    artsr2002
    'Yonder
    OP, looking forward to the install vid/pics. Thanks.
    RustyShackle323 and Tundra2 like this.
  13. Mar 16, 2021 at 1:38 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Photos below, still working on getting it all pretty aka more zip-ties and wire loom. tubing. I tapped into 15A - H-LP/DRL (Headlights on two clicks). You can run the wire pointed toward the driver side if you wanted to also
  14. Mar 16, 2021 at 3:46 PM
    Nick.hiatt
    Nick.hiatt New Member
    Dope. I’ll buy a set if/when available
  15. Mar 16, 2021 at 3:48 PM
    Fred
    Hand Protectors
    :yes:
  16. May 15, 2021 at 5:30 PM
    Powderkeg
    Powderkeg New Member
    Kegan
    2001 Sequoia
    I appreciate the 1st gen write up. All other write ups I see are for the newer gens. I was able to get everything wired up and achieved illumination, but the issue I’m running into is illumination even when the headlights are off. They’re on if the ignition is on. I imagine they aren’t supposed to be unless the parking ambers are on. Unless this is some drawback that no one has ever mentioned! I’d rather not have to splice into the parking ambers...
  17. May 15, 2021 at 5:42 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I did this on my 16’ 4Runner. Used a fuse tap and found an open circuit in the fuse box that was on with key on. Worked perfect for over 4 years now.
    B4108238-DE63-4CFD-A70D-59BEFAE4B31C.jpg 77BA5338-9CFA-43B1-9C1A-D309A82F8882.jpg D193A84B-445B-45FC-ABD5-639BC7E412EC.jpg B803B83E-0A60-41BA-AD14-D38A8F868EB7.jpg
  18. May 15, 2021 at 6:02 PM
    Powderkeg
    Kegan
    2001 Sequoia
    The ones I have a super similar to yours Diablo, but what you’re saying is that they are intended to be on regardless of the head light switch position?
  19. May 15, 2021 at 6:09 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    @Powderkeg yeah, I wanted them on whenever the key is on. They are bright and very visible during the day.
  20. May 15, 2021 at 6:12 PM
    Powderkeg
    Kegan
    2001 Sequoia
    It sounds like I would need to tap into the power/ground of the parking lamps to achieve my desired effect. Bummer. If anyone has advice otherwise I’d appreciate it. Thanks Diablo
    Diablo169 likes this.
  21. May 15, 2021 at 6:15 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Honestly, I thought the same as you, but a fuse tap doesn’t mess with any of your factory wiring, and it’s protected by the original amp fuse to prevent any damage to your system. Plus those lights only draw like .1amps
  22. Nov 12, 2021 at 11:43 AM
    Rej1stGen
    Rej1stGen New Member
    2004 SR5 Tundra Access Cab
    Bilstein 5100s Front
    I am interested, I like the look of two lights in the grill.
  23. Nov 12, 2021 at 12:00 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    How much is the kit? I would like mine to turn on with the corner lights even if the head lights are off.
    jerryallday[OP] likes this.
  24. Nov 12, 2021 at 4:13 PM
    I did a set of three amber LED's in my bull bar. Tied them into the parking lights. So yeah, there's THREE!!
  25. Nov 13, 2021 at 2:01 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Send a message to Vale_tundra on Instagram he is doing the kits. He does other great lighting kits aswell.
    https://instagram.com/vale_tundra
  26. Nov 13, 2021 at 3:45 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Looks good, Well done Sir. Leds are bright same reasons there on my gen 2 beast... Thanks for sharing.IMG_20210227_132357.jpg
  27. Nov 13, 2021 at 5:07 AM
    Dave8699
    Dave8699 Trackrat
    NJ
    Thank you but I have no IG
  28. Nov 13, 2021 at 8:29 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I just sent him a message to see if I can get an email to share
    Dave8699[QUOTED] likes this.
  29. Nov 13, 2021 at 9:51 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    You guys are rad!!! All this new led lighting is pretty cool. More ideas please...
  30. Nov 13, 2021 at 9:56 AM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    While I am always respectful of anyone doing whatever they want to their rigs (the grief i have taken over yesrs for shit ive done is thick...), I just cant see myself wanting to make myself look more like a Ford. Isnt why I got a Toyota.
    For this reason I suggest we start a movement in the Toyota Community to at least Rename these lights something better than "Raptor Lights" because that definitely makes it worse. Like you really wanted a Ford. They definitely arnt going away but damnit lets at least own our own name for the mod haha.
    But also in seriousness they look clean and well done. Tip for dude making them- Braided Loom looks 1000% better than plastic split loom, takes less space to store, is a bit cheaper now days ive found ,and end termination looks super clean with some Shrink tube.
    jpink, Dave8699 and shifty` like this.
