Anyone running 17" rims on your 2.5 gen?
Discussion in 'Wheels & Tires' started by BuckWallace, Apr 2, 2018.
  1. Mar 11, 2021 at 6:03 PM
    #571
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Best rim out there lol but I maybe bias
  2. Mar 11, 2021 at 6:27 PM
    #572
    COTundra23
    COTundra23 New Member
    nah.. you right. I'll be doing these soon
    619CementGrey likes this.
  3. Mar 11, 2021 at 6:40 PM
    #573
    619CementGrey
    619CementGrey New Member
    Not gonna argue with you
  4. Mar 15, 2021 at 12:03 PM
    #574
    Kaoyamu671
    Kaoyamu671 New Member
    2019 SR5 CM
    All stock w/TRD suspension add-ons
    Thought I’d post my contribution to this excellent thread!
    Hutchinson Rock Monsters 17x8.5/+25 offset. 285 70/17 Cooper AT3 XLTs
    2019 Tundra CM SR5 w/ TRD suspension add-ons@stock height. upload_2021-3-15_15-2-17.jpg
    EvoTundra, TK1979, Elduder and 2 others like this.
  5. Mar 15, 2021 at 12:05 PM
    #575
    Kaoyamu671
    2019 SR5 CM
    Side view.
  6. Mar 15, 2021 at 4:14 PM
    #576
    Burdturger
    Burdturger New Member
    Looks like we have a new option from method in 17s. Method 317.
    SpecificationsMR31778558800
    Wheel Diameter (IN)
    17
    Wheel Width
    8.5
    Bolt Pattern
    5x150
    Offset (mm)
    Hub Bore (mm)
    110.50
    Backside Spacing (in)
    4.75
    Wheel Weight (LBS)
    30.1
    Max Load (LBS)
    2650
  7. Mar 25, 2021 at 10:16 AM
    #577
    nomad_dave
    nomad_dave New Member
    Colorado Springs, CO
    2021 Tundra Ltd double cab
    OME BP-51,SPC UCAs
    This thread is so helpful and I have looked at many. Thanks for all the pictures and info on your setups and when I get my wheels and tires on I will be sure to add it here. OME BP-51 and SPC UCA's should be done being installed today and the planned wheel tire combo is the Icon Rebound 17X8.5 with +25 offset and Falken Wildpeak A/T3W 285/75r17 or BFG ko2 same in size.
  8. Mar 27, 2021 at 4:00 PM
    #578
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Believe it or not this was a BF purchase. Came in today. Guess I better get on the tire and suspension upgrades!
    equin and mgm16trdpro like this.
  9. Mar 27, 2021 at 4:02 PM
    #579
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    17 inch on 35.
    J&ATundra, DondeContente and equin like this.
  10. Mar 28, 2021 at 5:10 PM
    #580
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    You have a thoughtful boyfriend. :laugh:
    J/K, it's going to look great! Go with 35s or 315s.
  11. Mar 28, 2021 at 7:30 PM
    #581
    Pillslinger
    Rollin
    SWMO
    Lol! I never expected a BLACK FRIDAY shipment would have taken so long. Week after week the folks at Icon were top notch, I feel like we are on a first name basis. Glad to finally have my wheels tho.
  12. Apr 16, 2021 at 6:54 PM
    #582
    tahoe
    tahoe New Member
    2013 RW, 6112 @1.9” front, 5100 rear
    I just joined the site to jump in this thread. I’ve got a 2013 rock warrior with the original 17” wheels (+50 offset).
    I really want to put bfg ko2 12.5x35 tires on her. I saw a few of you have done this. Ive got 6112’s up front at 1.9” and 5100 rear for a level ride. I’ve seen some folks that have done it on their trucks, but haven’t seen it with only 1.9” lift up front. Can I do it without the BMC?
    Is anyone running this setup?
    If anyone wants a pic of 285/70/17’s with 1.25” spidertrax spacers (as it is now), lemme know.
    Thanks!
    king.cong.1119 likes this.
  13. May 13, 2021 at 4:41 PM
    #583
    Teegee
    Teegee Around
    Grouch
    21 MAX
    KMC 717 Bully 17x8.5 +18
    Toyo AT3 285/75/17
  14. May 13, 2021 at 5:12 PM
    #584
    tahoe
    tahoe New Member
    I got toyo at3 35x11.5r17 installed on my RW wheels. No rubbing with the 1.25” spacers. 6112s on 3rd (1.9”) setting. Front mud flaps, fender liners and skid plate removed. RCI skid gets here next week.
    Thanks to everyone who posted earlier in this thread.
  15. May 13, 2021 at 6:10 PM
    #585
    king.cong.1119
    king.cong.1119 New Member
    6112/5160 (1.9inch front and 0 rear). 17inch icon rebound 315/70r17
  16. May 28, 2021 at 9:08 AM
    #586
    Twowheelssoar
    Twowheelssoar New Member
    NC
    2021 Cement SR5 6-Seater
    How are you liking the tires so far? Do you have any experience with E load tires to compare the ride?
  17. May 28, 2021 at 9:12 AM
    #587
    Twowheelssoar
    NC
    Read this whole thread and didn't see anyone running the Method 703 in the 17x8.5 with 35mm offset. Will be running stock UCA's with a Bilstein or Eibach leveling strut. Really like the look of these wheels, but trying to figure out if the +35 offset is going to get too close to the UCA's. Anyone with experience or thoughts on if it will be too close?
  18. May 28, 2021 at 9:32 AM
    #588
    Pillslinger
    Rollin
    SWMO
    Have you run the numbers here? I'm running a 305/70 on a 25mm offset and feel like I have plenty of room. What size tire are you planning?
    On a quick and dirty calculation you could go up to 35 x 12.5 on a 35mm offset and still be 0.13in further away from your uca then you would be on stock setup.
    EvoTundra likes this.
  19. May 28, 2021 at 10:33 AM
    #589
    Twowheelssoar
    NC
    I had not used that calculator. That’s really helpful. Thanks!
    I am looking at the 35x11.5 r17 Open Country AT3, so the calculator says I’d actually be 2/3 inch further from the suspension than with the stock SR5 alloys and 275/65 r18 Bridgestones. Makes me feel much better and seems like plenty of clearance not to need a BMC.
  20. May 28, 2021 at 10:40 AM
    #590
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    do you think you could have fit those same tires with +25 offset? Im trying to run 35s and dont know if 0 or 25 offset is going to be better. eyeing some similar method wheels
    i have 5100s in the front on top setting with arb front summit bumper. trying to avoid bmc or cmc
  21. May 28, 2021 at 11:09 AM
    #591
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you’re trying to avoid chopping, the +25 is 1000% better.
    equin and Trdwillie14 like this.
  22. May 28, 2021 at 7:48 PM
    #592
    Pillslinger
    Rollin
    SWMO
    X2
  23. May 31, 2021 at 7:48 PM
    #593
    tahoe
    tahoe New Member
    I think they’re great. I was worried they’d be loud on hwy, but they’re not. I’ve had e load tires in the past, but can’t remember which... maybe bfg ko? Anyway, these are c rated and seem pretty “plush”. It may be more the extra rubber with 35s instead of 33s rather than the load rating though. They have had good grip on some rocky spots off road. Haven’t had them in snow yet. All in all I give them two thumbs up. If they wear well, I’ll get another set at 200,000 miles.
    Twowheelssoar[QUOTED] and equin like this.
  24. Jun 18, 2021 at 2:28 AM
    #594
    JoshR324
    JoshR324 New Member
    North TX
  25. Jun 18, 2021 at 2:52 PM
    #595
    Redcon41318
    Redcon41318 New Member
    Is that the trd center cap or sticker?
  26. Jun 21, 2021 at 8:56 PM
    #596
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Has anyone fitted 17s over stoptech st60 calipers?
  27. Aug 8, 2021 at 9:47 PM
    #597
    Rippyro
    Rippyro New Member
    2014 Tundra 1794 - Sunset Mica Bronze
    Trying to decide between icon rebounds in 17" or 18" (both +25 offset) or black rhino stadiums in 17" or 18" (+10 offset)
    The main question I have is how big of a pain is it to get the wheel on and off of the hub with the 17s? Anyone have to shave down the caliper to fit the 17" wheels or is the tiny gap between the caliper and wheel enough?
  28. Aug 8, 2021 at 10:37 PM
    #598
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I have the 17” Icon Rebounds and really like them. I can’t speak to the Black Rhino Stadiums, but my Icon Rebounds are no more difficult to reinstall than the 18” MB352s I had on before and the 20” TSS wheels that first came from the dealer when I bought it new. For me, though, it’s not so much the hub space as it is the weight of the tire/rim combo that makes it challenging for me. Even so, the 17” Icons are a relatively light wheel, so that helps in that regard.
    TRDblvd and Rippyro[QUOTED] like this.
  29. Aug 8, 2021 at 10:39 PM
    #599
    Rippyro
    Rippyro New Member
    Looks great. How much space is there for the caliper with the rebounds? About the thickness of a sheet of paper? Lol
  30. Aug 8, 2021 at 10:49 PM
    #600
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Clearance is just less than the thickness of the stick on wheel weights. Weight placement is key.
    Rippyro[QUOTED] likes this.
