17” wheel hitting tire rod, help?
Discussion in 'Wheels & Tires' started by Adimattio, Nov 5, 2020.
  1. Nov 5, 2020 at 3:07 PM
    Adimattio
    Adimattio [OP] New Member
    Alexander
    2010 rock warrior
    Icon 6” coilovers, 35” general grabbers, rhino rack
    I’m trying to mount fifteen52 wheels and they are hitting the tire rod ends and ideas
  2. Nov 5, 2020 at 3:14 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Wheel spacers. Or, you need to see if there's a different tie rod end.
  3. Mar 15, 2021 at 7:55 AM
    AggiePhil
    College Station, TX
    Did you ever get this resolved? What offset were the wheels you were trying? The Fifteen52 Analogs are 0 offset.
  4. Mar 15, 2021 at 10:47 AM
    Adimattio
    Alexander
    2010 rock warrior
    I used wheel spacers but not the wheels rub. I cut the wheel liners and did the body mount chop but it still rubs. Has anyone tied to cut the tie rods to give more caster?
  5. Mar 15, 2021 at 10:54 AM
    AggiePhil
    College Station, TX
    So...what is rubbing exactly?
  6. Mar 15, 2021 at 11:20 AM
    Adimattio
    Alexander
    2010 rock warrior
    Tires rubbing on body mount
  7. Mar 15, 2021 at 11:21 AM
    Adimattio
    Alexander
    2010 rock warrior
    Even after the chop
  8. Mar 15, 2021 at 11:22 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    What UCAs?
  9. Mar 15, 2021 at 11:31 AM
    Adimattio
    Alexander
    2010 rock warrior
  10. Mar 15, 2021 at 11:46 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Bingo! That's your problem. They don't provide enough caster. MCM or TC will fix your caster.
    sr5shark, AggiePhil and TheBeast like this.
  11. Mar 15, 2021 at 12:11 PM
    Adimattio
    Alexander
    2010 rock warrior
    What about cutting the tie rods?
  12. Mar 15, 2021 at 12:12 PM
    AggiePhil
    College Station, TX
    Sounds...like a bad idea??
    831Tun likes this.
  13. Mar 15, 2021 at 12:17 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That's a suggestion I've personally gotten from Icon to fix camber. Makes no sense to me to cut the tie rods. IMO the arms should've been made correctly to begin with. But, to your point, the arms set the caster and I don't think cutting the tie rods will have any effect. I've been down this road and switching to MCM arms fixed my camber issues and gave me far better caster numbers. With MCM I got 0* camber both sides, 4* caster left and 4.5* caster right. The caster is offset, higher on the right, to accommodate the road crown.
    SC_TRD and sr5shark like this.
