  1. Mar 14, 2021 at 6:48 PM
    Hongkongwongdonf
    Hongkongwongdonf New Member
    Will
    Gastonia, NC
    2017 tundra limited
    5% tint. Black rhino arsenal 20x9.5 295/55/20 KO2.
    Love the skid plate looking super good!
    AZBoatHauler[QUOTED] likes this.
  2. Mar 14, 2021 at 6:50 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    Mine stayed at ~350mi to empty for the first 200+ miles of driving... Definitely an odd feeling
  3. Mar 14, 2021 at 7:10 PM
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    Went got the pontoon from the boat slip yesterday.
  4. Mar 14, 2021 at 7:16 PM
    typerlegend
    typerlegend Will work for Mods
    Will
    SoCal, North Orange County
    2020 Super White Tundra SR5 TRD Sport
    Kicker sound system. Kings 2.5 Adjustables Total Chaos UCA Total Chaos 3/4' Rear Shackles 17' Methods 703s KO2 35/12.5/17 Baja Design Amber Squadron Sport Fogs
    Prep for Baja Design Squadron Sport Ditch lights. Brackets are Rago Low Profile.
    GarTX526, Hightide, GAknight and 7 others like this.
  5. Mar 14, 2021 at 7:34 PM
    Hongkongwongdonf
    Will
    Gastonia, NC
    2017 tundra limited
    Yeah I use a microfiber mitt but I’m looking for something like a brush but I’m worried about scratching up my paint.
    pvn.beluga[QUOTED] likes this.
  6. Mar 14, 2021 at 7:56 PM
    AggiePhil
    College Station, TX
    Did you have to melt or trim the plastic cowling underneath? I definitely had to with the CBI brackets.
    Hightide and pvn.beluga like this.
  7. Mar 14, 2021 at 7:57 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Usually takes a couple tanks for that thing to get it figured out
  8. Mar 14, 2021 at 8:19 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Hah, don’t sweat it. But you definitely do need to make sure you use a 2 bucket wash method. Otherwise you’re for sure going to scratch your paint.
  9. Mar 14, 2021 at 9:07 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Xkglow is the name of the company. Super easy install.
  10. Mar 14, 2021 at 9:22 PM
    typerlegend
    Will
    Nope, the passenger side does press down on a rubber piece but did not need to trim. I'll get a picture tomorrow and post. Driverside had no problems.
    Hightide and AggiePhil[QUOTED] like this.
  11. Mar 14, 2021 at 9:45 PM
    itsZEUStime
    itsZEUStime New Member
    Paul
    2019 White Tundra SR5 Crewmax
    RCI Sliders RCI Skids Prinsu Rack AJT Chrome Delete Pop & Lock Power Tailgate Lock Super Pacific Camper Incoming
    Installed Pop n Lock for tailgate keyless lock as well as a mountain hatch.
  12. Mar 14, 2021 at 10:44 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
  13. Mar 15, 2021 at 3:50 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    I've used these for years and haven't noticed scratches although I carry mine through the woods frequently so it has some already. I use a pressure washer first to pre rinse as much dirt off as possible before I use the brush too.
    https://www.amazon.com/dp/B0009IK9DG/ref=cm_sw_r_cp_apa_fabc_AJEN8AH6XPPN6NKVZTQ1
    cjmay13 likes this.
  14. Mar 15, 2021 at 4:17 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I filled up after getting 506 miles on a tank. Took about 33 gallons to fill up.
    RainMan_PNW, WILLINH and pvn.beluga like this.
  15. Mar 15, 2021 at 4:32 AM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I installed the Bumpershellz white end caps over the chrome and then took back off. Nothing against the quality of the part or how it's designed, I just like the original cap style better and being able to see the complete fog light bezel, so I'll be installing those later. Also, I'm still a little on the fence and not convinced the white looks much better than chrome. This is partially because the new white is too bright compared to 2016 paint that has lost a bit:
    WFD473, Part_time, 3xYOTA and 12 others like this.
  16. Mar 15, 2021 at 5:37 AM
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    I think it looks good with the chrome caps and color matched grill surround. I'd leave it like it is. Just my .02 cents worth.
  17. Mar 15, 2021 at 5:42 AM
    Badknees
    Badknees New Member
    Thanks for the comments. Next to what wheels/tires to install, it's been my biggest internal debate.
    TheBubbaDude and JerryH like this.
  18. Mar 15, 2021 at 6:16 AM
    CappyKD
    CappyKD Older, grayer member.
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    Ouch. Who did you order from? The DD website shows 1-2 weeks lead time. I ordered from HR. I guess it's a good thing I'm not in a rush to get it lol.
  19. Mar 15, 2021 at 7:13 AM
    Hongkongwongdonf
    Will
    Gastonia, NC
    2017 tundra limited
    If your a fan of no chrome you could go method racing or black rhino I have the black rhino Arsenal 20x9.5. It gives a little bit of poke and also I was going for a military wheel look. And i can say the ko2 is a fantastic tire my wife’s 4Runner is about to get some.
    CorsoTundra and Badknees[QUOTED] like this.
  20. Mar 15, 2021 at 7:21 AM
    Badknees
    Badknees New Member
    I just installed a set of TRD Pro BBS wheels and Cooper 295/70 R18s so my big spending is done for a long time! Would like to see your set-up though.
    pvn.beluga likes this.
  21. Mar 15, 2021 at 7:32 AM
    Hongkongwongdonf
    Will
    Gastonia, NC
    2017 tundra limited
    The second pic is after I installed the eibach lift. My tires are also 295 but I’m running 295/55/r20 on black rhino arsenals 20x9.5 so I have a little poke I was hoping that the 2.5 inch lift would stop the rubbing but for some reason it still rubs in reverse.
  22. Mar 15, 2021 at 7:43 AM
    Badknees
    Badknees New Member
    You have a very nice truck. I used a heat gun and small dead blow hammer on the front splash well and mud flap to shape/mold the plastic and eliminate rubbing. I had to remove small front mud flap too and trim the ears on the skid plate where the tires rubbed - all easy work.
    AggiePhil likes this.
  23. Mar 15, 2021 at 7:44 AM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    May need to add some bumper shims.
  24. Mar 15, 2021 at 8:33 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Got lost for a bit and got the truck dirty with my family. 63057692-81F5-4712-89BB-3BA604553619.jpg
  25. Mar 15, 2021 at 8:37 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Hey Mike! Your rig is looking kick ass as usual
    However, you forgot another often requested “Hey what kind of...” about your rig... So I will add it now.
    It’s a Southern Style Off-Road slimline hybrid bumper with a Warnplatinum Xeon 10s winch and Baja Designss8 30" lightbar in driving combo.
    :thumbsup: How did I do, did I get it!
    Cheers Brother!
    mgm16trdpro[QUOTED] and Hightide like this.
  26. Mar 15, 2021 at 9:43 AM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Looks good white. Check out revemoto. They have actual painted end caps like sparks toyota not shells. Which I believe wont have that flaw design on the fog bezels.
    Badknees[QUOTED] likes this.
  27. Mar 15, 2021 at 11:14 AM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    2021 SR5 Tundra Crewmax 4x4
    Bakflip G2 Tonneau Cover
    That's how you do night squirrel huntin' in Oklahoma!
    easleycrawler likes this.
  28. Mar 15, 2021 at 11:33 AM
    Badknees
    Badknees New Member
    Will do. Many Thanks for the recommendation.
  29. Mar 15, 2021 at 11:39 AM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    “what tires are those” jk looks awesome man!
    mgm16trdpro[QUOTED] likes this.
  30. Mar 15, 2021 at 12:14 PM
    Hongkongwongdonf
    Will
    Gastonia, NC
    2017 tundra limited
    How close do you have to hold the heat gun ? I installed the lift with my father and brother so moving a little bit of plastic should be easy can you add some photos of how much to move the plastic ? I’m not rubbing the front anymore just the rear mud flap I though about grinding the plastic down.
