  1. Mar 13, 2021 at 11:32 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  2. Mar 14, 2021 at 1:35 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Yep.
    You'll probably need the clockspring. I don't think they came with the correct one prior to 04 or 05.
    If your radio can program resistive type buttons, you won't need any additional parts from crutchfield. Just wire the 3 wires to the radio (or sometimes 2 wires w/resistors and to the radio ground).
  3. Mar 14, 2021 at 3:30 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Here's a sampler platter. I added a clock to all these hyperlapses going forward unless it falls off the table, and goes kaboom.
    I thought it was a good idea.
    Wireless battery operated :yes:
    https://youtu.be/DjCSeGwGi-U
    Darkness, NUDRAT and RustyShackle323 like this.
  4. Mar 14, 2021 at 4:51 AM
    speedtre
    speedtre New Member
    Inland Northwest
    FYI....flip your phone sideways and voila, full search...:thumbsup:
  5. Mar 14, 2021 at 6:35 AM
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    I actually drove it a little this week and it rolled into six digits.72D6A1A7-3814-4A79-9715-AFCBACA556AB.jpg
    Voss, standard, oscardog86 and 10 others like this.
  6. Mar 14, 2021 at 8:06 AM
    Your truck (5 speed auto) requires the WS fluid. PHM is rollin' ol' skool with a 4 speed auto and can run more conventional ATF. There are some alternatives to the Toyota branded WS that are cheaper.
  7. Mar 14, 2021 at 8:51 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Plug and play. They have the cutouts for the buttons
    jImmegart[QUOTED] likes this.
  8. Mar 14, 2021 at 10:41 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    While cleaning up the drivers side drum I found a stud hole to stud hole crack on the inside. Not sure if it came that way or not because I didn't verify structural integrity when I got these at auto-bone.
    It's not through to the otberside yet.
    Safest bet would be to replace the drum, eh?
  9. Mar 14, 2021 at 10:58 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I’d say replace. If it’s Duralast brand it might be a lifetime warranty part.
    speedtre and NUDRAT like this.
  10. Mar 14, 2021 at 11:05 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It is durablast. Local autobkne won't answer the phone. I can't find my receipt either.
    Never done that before so not sure if I even need a receipt. Maybe I put it on my account back in July.
  11. Mar 14, 2021 at 11:14 AM
    Good eye catching that, definitely replace.
  12. Mar 14, 2021 at 11:14 AM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Generally just need the phone number you gave when you bought it for warranty. Ive even had them pull shit off my old phone number that I bought when I first got Taco in 06
  13. Mar 14, 2021 at 11:15 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well, looks like I'm going to town then. :D
  14. Mar 14, 2021 at 11:17 AM
    empty_lord
    05 rollover special
    Yup... OEM if you can swing it... I’ve had 0 luck with afgermarket
  15. Mar 14, 2021 at 11:20 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oem will have to be later down the road. Wallet is getting tight like sphincter.
    Now that I know how to pull drums I could do a monthly check I suppose.
  16. Mar 14, 2021 at 11:24 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Full send with the inline 4 cylinder, 5 speed...
  17. Mar 14, 2021 at 12:08 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I always liked those Nissan trucks, just prefer less plastic up front. The early Frontier with the steel bumper is a good one.
  18. Mar 14, 2021 at 12:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I like the way this truck drives, and handles.
    It's a good time on 4 wheels at 85mph.
    Feels like the whole truck is shaking apart.
    I once drove this during rush hour on the interstate in clarksville Tennessee between exit 4, and exit 10. You couldn't drive a toothpick in my ass with a 10 pound sledge.
    @Siebler was correct. Phone number did the trick.
    Free.99 all day long!
    Voss, NWPirate, speedtre and 4 others like this.
  19. Mar 14, 2021 at 12:19 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I found my post back in June. Key words I remembered was "check point charlie."
    Another example of remembering things that have no help on my day to day life. @FrenchToasty
  20. Mar 14, 2021 at 12:54 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Today I drain and filled the transfer case. Was kinda pointless because the fluid looked really good still but supertech is nice and cheap!
  21. Mar 14, 2021 at 12:55 PM
    Outbound
    Aaron
    Northern Alberta
  22. Mar 14, 2021 at 1:39 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Sneak peak into the editing process using big screen for enhanced viewing.
    FrenchToasty and RustyShackle323 like this.
  23. Mar 14, 2021 at 1:43 PM
    kenadavis
    kenadavis New Member
    Ken
    South Florida
    2006 Tundra Limited Access Cab
    Same here. Actually the dealer wanted a fortune to do it so I took it to my mechanic.
  24. Mar 14, 2021 at 2:19 PM
    Cummins3500
    Logan
  25. Mar 14, 2021 at 2:54 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Nissan had a great truck thing going on for decades (if not quite up to Toyota standards, but the "hardbodies" got close)....I lusted after one of these....
    I think that new Frontier is the best attempt at a Tacoma copy visually so far by any competitor....given my disappointment with the 3rg Gen Taco if I was shopping new midsize, I would definitely give it a test drive...
  26. Mar 14, 2021 at 3:16 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Guys, please help me out... I feel silly asking but I am not finding an actual part number for this half of the master cylinder that mounts to the brake booster. My next project is literally replacing/rebuilding all but just a few lines and the ABS module. But I can’t for the life of me find a part number for this half of MC. It’s actually making me a little mad :mad: lol
    Parts diagrams whether that is with Toyota or aftermarket do not really give a fair amount of confidence I am actually getting that half with the actual MC.
    Any help would be much appreciated!!
  27. Mar 14, 2021 at 3:34 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Got wheelers 3 leaf kit and 5100s installed along with new SS brake lines. All done except I broke a special bolt on the parking brake system. So couple days before I get replacement from dealer. Probably do another round of brake bleeding in couple days as well.
    Drive around the neighborhood felt nice enough.
  28. Mar 14, 2021 at 3:44 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @Darkness @FirstGenVol
  29. Mar 14, 2021 at 3:47 PM
    I'm studying your picture and your MC isn't the same as mine. I don't have the part you are pointing to. My MC bolts directly to the booster.
    I would just call a dealer or visit one, they will help you get the right part number if someone here can't.
  30. Mar 14, 2021 at 3:55 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @empty_lord maybe?
    I think it might be a whole assembly. Thats the f'd up one that comes on some 05/06.
