  1. Mar 13, 2021 at 12:42 AM
    #9211
    Eric6621
    Eric6621 New Member
    2007 Tundra Extra Cab TRD
    Do you recall how many boxes you used?
  2. Mar 13, 2021 at 6:40 AM
    #9212
    Retroboy1989
    Northern Utah
    Thanks, I didn't realize there was no factory sway bar in the rear until after I asked the question.
  3. Mar 13, 2021 at 6:44 AM
    #9213
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I think the TRD models come with one. Got mine from a Toyota dealer off eBay
    https://www.ebay.com/itm/401751254108
  4. Mar 13, 2021 at 1:29 PM
    #9214
    Hanzo
    Hanzo New Member
    Finished up my with all new brakes, stainless lines, backing plates, rear bearings, and an oil change today!
  5. Mar 13, 2021 at 1:36 PM
    #9215
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Oof, rear bearings are a lot of work!
  6. Mar 13, 2021 at 4:48 PM
    #9216
    Punisher17
    Punisher17 New Member
    Did you get those calipers from Amazon? I got some aftermarket ones from Amazon and put them on because I thought the old ones were sticking a little bit. Ever since I put them on it seems like the brake pedal is a little squishy. I had les Schwab make sure they were bled and they said they didn’t get any air out of them and my mechanic says the pedal feels fine so I don’t know lol. Maybe there is still some air trapped in there... when I pump up the brake pedal it feels more firm. I like a hard brake pedal feels safer to me
  7. Mar 13, 2021 at 6:40 PM
    #9217
    TXTundraFan
    TXTundraFan New Member
    Where did you get this at? My '10 rearview mirror has started peeling.
  8. Mar 13, 2021 at 6:44 PM
    #9218
    Hanzo
    Hanzo New Member
    Mine are genuine Toyota calipers up front, but I’m getting some shaking when braking. Going to bleed them again tomorrow. Pads, rotors, and lines are stoptech.
    Punisher17[QUOTED] likes this.
  9. Mar 13, 2021 at 7:43 PM
    #9219
    Punisher17
    I’m really happy with this mod I really enjoy it and my 3 year old son thought it was so cool :thumbsup:DAB59F90-A3E1-4323-834E-A206895DDC46.jpg6F38072E-12A5-4EBB-995A-06EAD3F1DB6D.jpg
    WVI, Rengawt, Mountun Goat and 2 others like this.
  10. Mar 13, 2021 at 9:09 PM
    #9220
    oogabooga289
    oogabooga289 New Member
    Excuse the dirtiness. The truck hasn't really been used or cleaned since a camping trip...last summer.
    Tundra grade black cluster panel and Sequoia black console panel are in. The black cluster panel definitely is going to pick up and show dirt more purely based on the texture it has compared to the original silver. But eh, it's in.
  11. Mar 13, 2021 at 10:42 PM
    #9221
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
  12. Mar 13, 2021 at 11:04 PM
    #9222
    Retroboy1989
    Northern Utah
    Redline 75w-85 in the diffs
    Redline 75w-90NS in the Tcase
    Amazon crush washer kit
    :thumbsup:
    The Tcase oil looked new, but the oil in the diffs looked worn and had a shimmer to it. I guess the hypoid gear action really works the oil hard. I'm assuming it was the factory fill.
    I opted for the NS in the Tcase because it doesn't have LS friction modifiers. I wasn't sure if the Tundra Tcase needs friction to shift like some of my previous vehicles. The additives in the diffs won't do anything but stink up my garage for a few days
    I've been partial to Redline since my college days when I drove a 94 Toyota pickup. Redline MT90 did wonders for that transmission.
    Mountun Goat and SkipperPete like this.
  13. Mar 13, 2021 at 11:42 PM
    #9223
    azimuth
    azimuth New Member
    2010 double cab SR5
    Installed my Bakflip F1
  14. Mar 14, 2021 at 12:50 AM
    #9224
    Eric6621
    Eric6621 New Member
    Now you gotta let us know if it leaks or not. Looks sharp!
    azimuth[QUOTED] likes this.
  15. Mar 14, 2021 at 12:58 AM
    #9225
    Eric6621
    Eric6621 New Member
    Way back I had some shaking going on whilst braking. Turned out to be the rotors had a slight warp to them. In my case it was most likely due to overheating the rotors through heavy braking - the 1st gen front calibers were undersized. Don't wanna tell you stuff you probably already know, but new rotors need to be broken in - there is a procedure of light braking the first few hundred miles or so. I don't recall details, but google is your friend. Then there is the possibility that one or both rotors have a slight warp from the factory. Maybe oil on the pads? Maybe something not quite tight after the brake overhaul? Finally, check to see if there are any Gremlins living in the wheel wells...time for bed...
    Hanzo[QUOTED] likes this.
  16. Mar 14, 2021 at 5:10 AM
    #9226
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Local UPull. Came off a Nissan Maxima
    TXTundraFan[QUOTED] likes this.
  17. Mar 14, 2021 at 5:14 AM
    #9227
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
  18. Mar 14, 2021 at 5:51 AM
    #9228
    Danny3737
    Did you embed the pads and rotors right after you installed them? There is a break in procedure where you go through a series of medium then higher speed stops to transfer some braking material to the rotors. You have to do it per each manufacturer recommendations. If you don’t, you can feel pulsating in the brake pedal and or steering wheel. The speeds at which to do it can vary per manf. There are a lot of articles and videos on how to do it. You just need a stretch of road where you can speed up and break hard ( during the second phase ) without causing an accident. This may not be your problem, but it is something that needs to be done anytime you do a break job. Shops that do breaks very rarely do it. Hope this helps
  19. Mar 14, 2021 at 10:07 AM
    #9229
    azimuth
    azimuth New Member
    2010 double cab SR5
    Rube207[QUOTED] likes this.
  20. Mar 14, 2021 at 11:07 AM
    #9230
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    New wheels and tires.. Had the old Method 301’s since 2010, 18x9 295/70/18. Updated with the MR315 17x8.5 0 offset, 35x12.5x17. A little more “flashy”..... Old setup with never mounted matching spare is for sale in DFW. PM if interested.
    [​IMG] [​IMG]
    emdcksn, The Dude, wv00097 and 13 others like this.
  21. Mar 14, 2021 at 12:06 PM
    #9231
    audiowize
    Paul B.
    Rear bumper.
    RJVA, rons23, CM2007 and 7 others like this.
  22. Mar 14, 2021 at 12:45 PM
    #9232
    SkipperPete
    SkipperPete New Member
    Pete
    Nicholasville, KY
    2012 Silver Tundra Crewmax
    Looks great! Yours sits exactly how I want mine to. What rock sliders are you running? I like how they're tucked up there and don't hang down so low.
  23. Mar 14, 2021 at 1:25 PM
    #9233
    oogabooga289
    Nice. One of those Hooke Road bumpers? Are the BSM sensors real or plugs?
  24. Mar 14, 2021 at 1:36 PM
    #9234
    chickunfut
    Fort Worth, TX
    2007 Tundra Crewmax
    Thank you! It’s been a lot of fine tuning.
    Sliders are All Pro Off Road Apex. Very happy with them. [​IMG]
  25. Mar 14, 2021 at 1:37 PM
    #9235
    audiowize
    Paul B.
    The parking sensors are real. The outer two holes are the correct size for the outer two sensors. The inner two holes have to be enlarged properly to fit the sensors. This is par for the course for what Hooke offers.
    oogabooga289[QUOTED] likes this.
  26. Mar 14, 2021 at 4:31 PM
    #9236
    Eric6621
    Eric6621 New Member
    Opened a thread a while back about different styles of sliders peeps are running. This is the first of the All Pro Apex I've seen. Really like the looks of them too and the way they are mounted to the frame. I have to say though, as a welder and a frugal f#@k, the price is sobering. Makes me think about dusting off my trusty Hobart Handler, putting on some long sleeves, donning my gloves, and .....wait, gotta run and get some metal....be right back.
  27. Mar 14, 2021 at 5:31 PM
    #9237
    chickunfut
    Fort Worth, TX
    2007 Tundra Crewmax
    And it’s $200 to ship them! Even with shipping and powder coating, they’re still not the most expensive out there.
    Eric6621[QUOTED] likes this.
  28. Mar 14, 2021 at 8:47 PM
    #9238
    Eric6621
    Eric6621 New Member
    :facepalm:
  29. Mar 14, 2021 at 8:53 PM
    #9239
    TheBeast
    TheBeast The Beach
    very nice ! 4.6L or did you start de-badging it ?
    Silverghost likes this.
  30. Mar 14, 2021 at 9:01 PM
    #9240
    chickunfut
    Fort Worth, TX
    2007 Tundra Crewmax
    5.7 sleeper lol.. took those badges off the first day I got it.
