  1. Mar 12, 2021 at 6:46 PM
    #5641
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Installed a new belt drive garage door opener today. Wasn't too bad at all. I had to replace a loud, old, slow screw drive unit. I'm happy with how quiet it is and the features. Nice upgrade for $150
  2. Mar 12, 2021 at 6:50 PM
    #5642
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Spent most of the day tackling this landscaping. Weeds were bad. Since house was being repaired, we didnt bother touching it (shingles kept getting dropped on them and workers trampling through them). Then after finishing that, went and wrapped up the playset so the kids can play on it. Got some open ends to add more onto it, but lumber is so damn high. I just had to get them something to replace theirs that got swept away.20210312_173906.jpg 20210312_173853.jpg 20210312_171735.jpg
    Cutting grass tomorrow for first time this year hopefully
  3. Mar 12, 2021 at 6:53 PM
    #5643
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yes. Looking at your in wall, they are two independent shower valves (not one feeding the second one). I would do the separate temp / flow on both of them. If your hot water temps are fairly consistent, you’ll set the temp on the valve and just about never mess with it again (except a little tweak if you or the Mrs prefers a different temp). Then when you take a shower, just turn the valve to full on, wait till the water from the head is warm and jump in.
    Good thing about delta is the body on their shower valves are the same for a lot of different trims so you can sheets swap it out later if you want a different style.
    AZTundra[QUOTED] likes this.
  4. Mar 12, 2021 at 6:55 PM
    #5644
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Is that one of those Infinity Backyards I keep hearing about? Like an Infinity Pool? It just doesn't end.
  5. Mar 12, 2021 at 6:57 PM
    #5645
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Oh it ends...fortunately and unfortunately. We're on a lil over 2.5 acres, sometimes I'd love more, other times I want a lil less. But ultimately I'm happy with it
  6. Mar 12, 2021 at 7:00 PM
    #5646
    RainMan_PNW
    Casey
    Clark County, WA
    No way I’d deal with that much grass. I’ve got 5ac and only more about 1000 SF. All the rest is just natural woods
    MS22 and TaquitoBandito like this.
  7. Mar 12, 2021 at 7:03 PM
    #5647
    AZTundra
    Paul
    Phoenix, AZ
    Thanks Casey! I'll get them ordered tonight...man those things are pricey. Can't wait for everything to come together.
  8. Mar 12, 2021 at 7:03 PM
    #5648
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I enjoy cutting grass like I enjoy washing the vehicles. I do have a pond in the back that takes up some of the lot, so it's not too bad.
  9. Mar 12, 2021 at 7:09 PM
    #5649
    RainMan_PNW
    Casey
    Clark County, WA
    No grass in our front yard - just lots of plants and bark dust (mostly plants). There’sa little bit of grass to the east and south of the parking area and a little under the trees to the north of the yard. Squiggly line is a creek originating to the NE.
  10. Mar 12, 2021 at 7:16 PM
    #5650
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I like the secluded setup....to an extent. Nice plot and could see the many perks of having that land with the house oriented such. Can I pluck a few trees and move them to my treeless yard?:(
  11. Mar 12, 2021 at 7:24 PM
    #5651
    RainMan_PNW
    Casey
    Clark County, WA
    Dunno how firs and alders will do in LA, and I think the freight might be a challenge. But you’re welcome to a few... :thumbsup:
  12. Mar 12, 2021 at 7:33 PM
    #5652
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    If you uproot, I'll make the drive:fistbump:
  13. Mar 12, 2021 at 7:35 PM
    #5653
    RainMan_PNW
    Casey
    Clark County, WA
    I had a few blow over...they’re about 80 feet tall but the roots are all intact. Actually have two bitter cherries that went over as well.
    Fotnot[QUOTED] likes this.
  14. Mar 12, 2021 at 7:36 PM
    #5654
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    :eek2: surprised they kept the root system with that kinda height. Geez
  15. Mar 12, 2021 at 8:00 PM
    #5655
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Thanks for all the info and advice. I appreciate it.
    Will I be able to determine the drain size just by looking under the sink, or would I need to open the wall up to see the actual drain in the wall? Seems like thats the most important thing if a sink is gonna happen or not.
  16. Mar 12, 2021 at 8:11 PM
    #5656
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I’m a little late to update this but I got my new stairs in and new railing and custom baby gate up. 6409D078-D99A-4053-B0CD-B20628F11E46.jpg
  17. Mar 12, 2021 at 8:13 PM
    #5657
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Looks great. :thumbsup:
    JH5370[QUOTED] likes this.
  18. Mar 12, 2021 at 10:09 PM
    #5658
    RainMan_PNW
    Casey
    Clark County, WA
    Hard to tell at the wall, but you might be able to determine it. The p-trap on a standard lav will be 1-1/4” but the actual drain line at the wall could either be 1-1/4” or 1-1/2” for the stub-out that the p-trap is connected to. If you look at the nut that the p-trap goes into and it is big enough to fit a 1-1/2” p-trap into (but is using a reducing washer for the 1-1/4” trap), then you know you’ve got a 1-1/2” drain pipe in the wall at least below the trap (which would give you the easiest method of modifying things). If the slip nut at the wall is 1-1/4” then you’d have to get the wall open to be sure.
    Personally, I always plumb a lavatory with a 1-1/2” drain line coming from it, and only reduce at the actual sanitary tee (so the branch that the slip nut is on is 1-1/4” but the actual pipe main is 1-1/2”) but that’s not specifically required so your setup may not be that way...so I can’t say it would be safe to assume that’s what you have.
    ToyoMafia likes this.
  19. Mar 12, 2021 at 10:46 PM
    #5659
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    The drain should stub out from the wall under the sink then connect to the P trap. So you should be able to see and or measure what size you will need. It will probably be black ABS in between or next to your supply lines.
  20. Mar 13, 2021 at 7:59 AM
    #5660
    NoKenDo
    NoKenDo New Member
    Ken
    Grand Rapids MI.
    2018 Platinum 4x4 Mesquite Brown
    TRD Pro Suspension. Moonroof. Front window tint. Compustar Pro T11 remote starter. N-FAB running boards Bedrug Bedmat XLT DiamondBack HD Tonneau Weather Tech Window Visors
    Replaced a leaky bathroom faucet. Also needed new lines, back to the store. But the shutoffs weren't working so back to the store for new ones. once everything was hooked up and not leaking the damn faucet wouldn't work. Back under the sink to start troubleshooting. disconnect hoses from faucet, plenty of water. WTF? Time to read the manual. There was an aerator wrench, I loosened the aerator and SUCCESS. Lowe's wanted 120.00 to install it. Would have been the best 120 i spent in a while.
    My takeaway from this is "just because I have plumbers crack does not make me a plumber".
    MS22, ToyoMafia, CodyP and 6 others like this.
  21. Mar 13, 2021 at 11:32 AM
    #5661
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Stairs look great! :thumbsup:
  22. Mar 13, 2021 at 2:03 PM
    #5662
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    40733009-A1E8-4F18-952F-F267C42E2671.jpg Prepping the house for painting ....each spring our house eaves turn into the neighborhood nesting zone. Wife stresses out about all the baby birds.... we usually need to try and save a few. Not no more.... sorry little birdies:)
  23. Mar 13, 2021 at 8:30 PM
    #5663
    AZTundra
    Paul
    Phoenix, AZ
    Bedroom tile was finished on Friday except for the closet. He's coming back tomorrow to do the grout. Also, leveled out the shower pan since we are doing a curbless shower.
  24. Mar 13, 2021 at 8:36 PM
    #5664
    AZTundra
    Paul
    Phoenix, AZ
    Signed a contract today for the pool to get started. We are chipping out the plaster and replacing it with mini pebble. New waterline tile will be going in as well. Also adding a dedicated suction line for the pool cleaner and adding an automatic water leveler. They'll start in about 2 weeks.
    Horrible pics, but here is the mini pebble color and the waterline tile we chose. The 2 inch square blue tile will be accents on the steps.
  25. Mar 13, 2021 at 9:14 PM
    #5665
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Those damn free loaders
    TaquitoBandito and drobb[QUOTED] like this.
  26. Mar 13, 2021 at 9:26 PM
    #5666
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Started the water heater install. Had to move lines out of the way. Also had a leaky/bad shutoff coming in, so turned the water off at the street, replaced said valve and started new plumbing to pex. Wishing I got a little more done today, but had to go shopping first, and had a dinner date.
  27. Mar 14, 2021 at 12:06 PM
    #5667
    TaquitoBandito
    Joel (AKA Bif)
    So I should plan our for our family vacation to Arizona in a month? Can you give me a little better timeframe? I have to get somebody lined up to watch the cat.
    Kung, alee891, NewImprovedRon and 4 others like this.
  28. Mar 14, 2021 at 12:10 PM
    #5668
    TaquitoBandito
    Joel (AKA Bif)
    We have roof rats, Mexican free-tailed bats, and I just looked out this morning and saw a Norway rat off of our deck. I'm running a damn rodent refuge. Fortunately none of them have penetrated the living areas. I'm mostly worried about the rats - there's been a lot of construction with the old houses around us so I think it's driving them our way.
    I have a plan to keep them out, I'm just waiting for the weather to cooperate. It's gonna be a long week.
    AZTundra likes this.
  29. Mar 14, 2021 at 12:16 PM
    #5669
    RainMan_PNW
    Casey
    Clark County, WA
    Night vision and a pellet gun?
    ToyoMafia, AZTundra, CodyP and 2 others like this.
  30. Mar 14, 2021 at 12:31 PM
    #5670
    TaquitoBandito
    Joel (AKA Bif)
    The rats are getting in under our deck, I think. I put hardware cloth around the house - 3 inches deep into the ground in an "L" shape for another 3 inches. But we had a deck put on and I think they dug under the steps where the deck touches the house. I'm going to add hardware cloth around the deck.
    For the bats, since they are protected, I have to be careful. I have window screen that I'm going to hang above where they are coming out at and let it drape 2 ft down. This way they come out but can't figure out how to get back in. I need the weather to cooperate so I can get it done before they start having their pups in April. Otherwise, it will be me on a ladder on a metal roof in 100 degree heat in August trying to get rid of them.
    My neighbor bought some bat houses and he's going to give me one - hopefully they'll move into that.
