  1. Mar 11, 2021 at 2:10 PM
    oscardog86
    oscardog86 New Member
    Southern California
    I agree, I think around 2 inch lift is considered the most you really want to do without getting into trouble down the road with other parts on the truck.
    des2mtn and Darkness like this.
  2. Mar 11, 2021 at 2:15 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That says so much with so little words
    :rofl: I wish I could use that at work.
    NWPirate likes this.
  3. Mar 11, 2021 at 2:19 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    From what I have read, some on here have reported getting more lift than expected from OME. YMMV
    https://www.tundras.com/threads/kings-and-spacers.77617/
    speedtre and Darkness like this.
  4. Mar 11, 2021 at 2:20 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    2008-ish. Jake's day, a program done up by the local NWTF people to promote education in the outdoors.
  5. Mar 11, 2021 at 2:55 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Tundra2 likes this.
  6. Mar 11, 2021 at 3:30 PM
    Fred
    Hand Protectors
    This morning pre-ignition. I wonder what the Ambient Temp was?:D
    Bottom pic is after 20 miles straight highway drive time. Transmission Temps seem 15-20° higher with the Derale Valve.
    des2mtn and Tundra2 like this.
  7. Mar 11, 2021 at 4:12 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  8. Mar 11, 2021 at 4:24 PM
    Fred
    Hand Protectors
    theblurry1 likes this.
  9. Mar 11, 2021 at 8:32 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  10. Mar 11, 2021 at 8:58 PM
    Mitch09
    Mitch09 New Member
    NC
    2022 SR5 TRD Off-road
    Looks good with the Tacoma wheels man.
  11. Mar 11, 2021 at 11:05 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    That Griots garage '3 in 1 Wax' and 'Ceramic Speed Shine' beading-up nicely.
    Stuff's Legit.
    912, NUDRAT, hammeron and 12 others like this.
  12. Mar 11, 2021 at 11:25 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    That's one clean looking 1st Gen. Awesome Detailing:thumbsup:
    NUDRAT, HBTundra[QUOTED] and Tundra2 like this.
  13. Mar 12, 2021 at 2:35 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    Very nice Tundra, thanks for sharing!
  14. Mar 12, 2021 at 6:30 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Just stunk up the neighborhood dousing the rear suspension bolts in some pb blaster. Rear suspension work starts tonight.
    How much beer should I have on hand? The rear shock top bolt access look like 2 beers each...
  15. Mar 12, 2021 at 6:53 AM
    A long, flex-head ratchet wrench really helped me with that job. 1-2 beers should do it. But it is Friday so maybe have a 6-er on hand JIC.
    Voss, Darkness, oscardog86 and 2 others like this.
  16. Mar 12, 2021 at 6:54 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I wanted to share this to the thread with the guy talking about Raptor lights. My wife says I need to work on being nicer to people though.
    Acatlin96, Darkness and FrenchToasty like this.
  17. Mar 12, 2021 at 7:09 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    I've put off this job longer then I should have, rear shocks look to be the original 4600 that came on trd package. So could have a fight on my hands.
    NUDRAT likes this.
  18. Mar 12, 2021 at 7:16 AM
    You might be fine. I didn't have a hard time when I removed my 4600's which were 17 years old at that point. I think the hardest part is that the internal shaft wants to spin instead of the nut. Your PB Plast should help.
    What are you putting in their place?
    NUDRAT, bmc02[QUOTED] and oscardog86 like this.
  19. Mar 12, 2021 at 7:20 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    He’s right. A pair of nicely place vice grips will stop that as long as you plan on throwing the shocks away when you’re done.
    Tundra2, bmc02 and oscardog86 like this.
  20. Mar 12, 2021 at 7:21 AM
    oscardog86
    Southern California
    Thats exactly what i used to get mine off, and didnt have to much trouble
    bmc02 likes this.
  21. Mar 12, 2021 at 7:22 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Chit chatted with PHM about star wheel. He was able to help me understand how to adjust the wheel to take tension off the drum to take it off.
    I was just going to do a test run adjusting the tension, and then readjust. Got more than I bargained for when I broke my multi-bit screw driver, and the bit fragment went in the peep hole. :facepalm:
    Pulled the drum off for the first time ever! Did some parking brake cable testing. Looks like five clicks will disengage the mechanism enough to adjust the wheel. I'm not PHM though. No special hand techniques here. Just struggle.
    While it was off, I made a video to help me understand, and see the mechanism in action. Its rather long, and it's just me working through it in my own way.
    https://youtu.be/1fGZTmzlxWk
    All buttoned back up... for now.
    NUDRAT, HBTundra, FirstGenVol and 3 others like this.
  22. Mar 12, 2021 at 7:23 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    I'll cut off the protective boot so I can get some vice grips on the shaft. That's worked in the past. It probably has the flat on the top post but a lot of good it does when you can't get to it...
    Have some 5100s to go along with the wheelers 3 leaf packs to replace my current block.
    Hope I'm pleased with results. I'm not really demanding of suspension so I think I'll be happy.
    Acatlin96, Tundra2 and CodyP like this.
  23. Mar 12, 2021 at 7:25 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I knew I was shit canning my old rear shocks. I took an angle grinder under the truck with me, and ground two flat spots in the shaft. Gave me p-lenty to grab hold of.
  24. Mar 12, 2021 at 7:31 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    That's a good idea! I figured my dewalt grinder would end up under there with me at some point.
  25. Mar 12, 2021 at 7:34 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I struggled with this first shock. I even cut half way through the shaft with a hack saw...
    I was a noob back then. Still a field flunkie.
    It was one of the first things I did to my "overhaul." May dig that post up for ole times sake. Bed time now. Up in 3.
    bmc02[QUOTED] likes this.
  26. Mar 12, 2021 at 7:37 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Exactly what I had to do. I tried vise grips but they had no grip. I made some flat spots with the grinder and that got me out.
    @bmc02 I would reserve one beer per shock and one beer for any technique building brainstorming you'll do, plus one beer for the celebration when you're done.
  27. Mar 12, 2021 at 7:56 AM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I remember when doing mine that I was able to get a crescent on the flat spot and use a ratcheting box end 14mm to make quick work of it.
    How do I remember this you ask? Because I chased a rattle for about a year afterwards. It was driving me absolutely nuts. Turns out I left that crescent just chilling in the bottom of the crossmember. :annoyed:
  28. Mar 12, 2021 at 8:02 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    3 beers... I'll need more then that. Probably start with a beer in the pre-op planning and tool gathering.
  29. Mar 12, 2021 at 8:06 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    That's funny. I've forgotten a tool somewhere a time or two as well. My 98 4runner ate a socket that I'm positive is still rattling around somewhere in the frame.
    NUDRAT, Darkness and oscardog86 like this.
  30. Mar 12, 2021 at 8:09 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Depending on how rusted or bad the top of the shock is, I've just removed the lower attachment and bent back and forth till the top post broke or until I could get the grinder to it. Or you could do it the "nice/clean" way and vice grips, remove the nut on top, etc. It'll take more beer that way...
    Jack McCarthy and Darkness like this.
