Can’t get an alignment ?!?!
Discussion in 'Suspension' started by Cogx5dad, Mar 4, 2021.
  1. Mar 4, 2021 at 4:36 PM
    Cogx5dad
    Cogx5dad [OP] New Member
    2010 SR5-TRD off road
    Debadged, waiting on bielsteins and shackles
    So I put Beilstein 5100s on top setting and +3 shackles last week. Took it to the four-wheel-drive mod shop around here and they could not get it aligned. They said everything was froze up. They said that I needed to replace the lower control arms and eccentric bolts. Of course they have a mechanic shop and offered to give a bid. Before I grow dropping a bunch of money on that I wanted to get some opinions here. Does this sound like accurate information? Or is it And attempt at selling work?
  2. Mar 4, 2021 at 4:38 PM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    This has been discussed on this forum in the past. Someone had frozen lower control arm bolts.
    YardBird likes this.
  3. Mar 4, 2021 at 5:13 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Can’t see why they’d need to replace the entire LCA unless the ball joint is bad. Sure it’s not just the bushings? I’d ask for an explanation. Any pics?
  4. Mar 4, 2021 at 5:17 PM
    No, it's legit. Been there, fixed them myself.
    If you did the work yourself replacing the lower control arms and eccentric bolts, be prepared to go through several diamond cut sawzall blades with a reciprocating saw to cut through the old ones.
    I don't know if you can find new bushings to replace the old ones and have them pressed in place or if buying new LCAs would be easier. I chose the latter route.
    Sunnier and YardBird like this.
  5. Mar 4, 2021 at 5:25 PM
    Mr Badwrench
    Mr Badwrench New Member
    Get another opinion or find a shop employee who will moonlight it. Unless your truck is terribly rusty underneath, I can't imagine that they are unable to align it.
    Some shops will turn down lifted vehicles though...
  6. Mar 4, 2021 at 5:50 PM
    Black
    2014 Tundra Limited CrewMax
    Take it to a commercial truck shop
  7. Mar 4, 2021 at 6:43 PM
    BobsYourUncle
    BobsYourUncle New Member
    2021 Super White Tundra TRD Pro
    Haven't had to do that to my Tundra (too new), but did have to cut the bolts on my FJ. I found the Milwaukee Torch blade was about the only one that actually worked and wasn't smoking after about 30 seconds. Would recommend grabbing one (or more) of those if anyone does have to cut them out.
  8. Mar 4, 2021 at 6:50 PM
    Sunnier
    Sunny
    San Diego, CA
    Same occurred when we upgraded suspension on our 2001 4R. Wouldn’t hold alignment. Bushings were shot. For that vehicle, we got a 2nd opinion: same story— cheaper (more parts, less labour) to replace the LCA’s than to replace the bushings.
  9. Mar 4, 2021 at 9:34 PM
    x2 on the Torch blades. I remember you could get 3 in a pack for $12-15 years back. Now they’re like $15 each (diamond grit) at Home Depot. Still the best blade I found.
  10. Mar 5, 2021 at 5:28 AM
    Cogx5dad
    We replaced struts and nothing was particularly rusty. I’m in the mid west so I more than expected. I think I’m going to have a second opinion soon. As for now I have a positive camber and a bit of a left pull. The text said that it was perfectly safe to drive it would just wear the passenger side tire out quicker on the outer edge. Does this also seem like valid information? I sure appreciate everyone’s input.
  11. Mar 5, 2021 at 5:31 AM
    timsp8
    NY
    LCAs aren’t that expensive if you end up having to replace them. Dont get oem. Look at moog. Same as oem but a lot cheaper.
  12. Mar 5, 2021 at 5:51 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    I also went with the Moog LCAs for my old truck and wife’s old car. Around $90 per side and the quick install was worth it for me. New bushings and lower ball joints, no rust. Easy decision.
    Old truck was a 2005 Nissan Frontier with siezed LCA cam bolts.
  13. Mar 5, 2021 at 5:59 AM
    BobsYourUncle
    Probably going up in price due to the booming catalytic converter “recycling” industry as mentioned in several other threads here... heh!
  14. Mar 5, 2021 at 6:10 AM
    I just looked online, the cheapest I see is like $8.99, so it’s not too bad.
    BobsYourUncle[QUOTED] likes this.
  15. Mar 5, 2021 at 7:32 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    This happened to me, but I was rebuilding the front end and the stupid lower control arm bushing and adjustment part was stuck. I ended up having to cut everything out. It sucked. I went to toyota and got new bolts and stuff. I'm glad I found it before I took it to the shop. But yes it does happen and it does not matter where you live. I'm in New Mexico and have no rust under my truck and it still did it. It's the one on the front of the control arm that gets stuck, or for me it was.
  16. Mar 5, 2021 at 1:52 PM
    Cogx5dad
    Well good news!
    Felt
    Like that was a janky deal yesterday with the alignment place. Soaked it in PB Blaster and took it to Big O tires for a second opinion. 20 min later... aligned.
    Looks good, drives straight, no pull. Not sure what to say. Looks like the other place was out for an upsell. I hate that it’s so hard to find honest people. Well, big props to the Big O tech.
  17. Mar 5, 2021 at 6:11 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    20 minutes? Toe and go baby! Don't speak too soon on finding an honest shop. Did you get a print out of the specs?
    Seized suspension bolts that go through bushings is not uncommon, even without road salt. All the adjustment is done with the LCA bolts on the tundra. If they're seized, you need new cam bolts and LCA bushings. Most shops will opt to just change the entire LCA. Most times it's faster, easier to get locally, the lower balljoint is shot anyway, and the price difference is negligible.
  18. Mar 5, 2021 at 6:57 PM
    Cogx5dad
    Ya I got a print out. It’s just within spec but it was soooo far out to begin with I’m just glad it’s where it is. The camber was VISABLY off. I mean it looked like an Icecream cone lol. Squared away now though. Drives straight no pull to speak of and didn’t cost $800. (Way more than I could do in my garage.)
    Sunnier likes this.
  19. Mar 12, 2021 at 7:19 AM
    texascolt45
    texascolt45 New Member
    mike
    future
    none
    PB Blaster is your friend or Kroil.i started spraying mine when I knew I was leveling it and realignment
    Cogx5dad[OP] likes this.
