Installing front shocks question
Discussion in 'Suspension' started by SpooledReel, Mar 11, 2021.
  1. Mar 11, 2021 at 2:12 PM
    SpooledReel
    SpooledReel [OP] Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    I have a set of the TRD red shocks assemblies that I am in the process of installing. Are right and left front the same length? I thought I had read somewhere that they are different lengths. I cannot tell by looking at them but they do have different color paint dots on the springs.
  2. Mar 11, 2021 at 2:41 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    IIRC the driver side is longer to compensate for Tundra lean.
    BravoDeltaRomeo and Zebruaj like this.
  3. Mar 11, 2021 at 3:29 PM
    NoRcptn
    NorCal
    2017 Platinum
    Do you have a picture? On the older Tacomas, driver side was green passenger side blue.
  4. Mar 11, 2021 at 3:33 PM
    NoRcptn
    NorCal
    2017 Platinum
  5. Mar 11, 2021 at 3:37 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Are these the Pro Bilstein or the newer Fox? The Bilstein assemblies have part numbers specifying right and left hand sides, not sure about Fox. But they are definitely side-specific.
    Edit: I just realized you probably mean the red TRD Sport shocks. The link @NoRcptn posted should give you the info.
  6. Mar 11, 2021 at 6:21 PM
    SpooledReel
    RickyP
    Spanish Fort, AL
    Yeah, they must be wrong. It’s the TRD red sport shocks. Passenger height from ground to wheel arch is 40.25” and driver is 39.5”. The shocks on the passenger side have blue and orange dots. The driver side has yellow and grey dots. I guess I will reverse them tomorrow.
    F656BDA4-785A-4023-B713-80625ED8EA55.jpg 21331193-4E82-4338-9F8E-7C20E7B88F51.jpg
  7. Mar 11, 2021 at 6:31 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I think I remember @Jim LE 1301 knowing the answer to this...
  8. Mar 11, 2021 at 6:35 PM
    NoRcptn
    NorCal
    2017 Platinum
    Hol' up!
    I've been digging around. I haven't found it yet but just as a reference I have the fox pro's which are Left / Right specific and still i'm a little low on the DS. Maybe heavier battery. Anyways, found some stuff from 2003 -2006 tundras and blue is on Passenger side. It looks likes it has changed frequently depending on model and spring rates used. I'd try to do some more research before swapping them over.
    BravoDeltaRomeo likes this.
  9. Mar 11, 2021 at 6:46 PM
    NoRcptn
    NorCal
    2017 Platinum
    SpooledReel[OP] and TRDFerguson like this.
  10. Mar 11, 2021 at 6:51 PM
    SpooledReel
    RickyP
    Spanish Fort, AL
    These shocks are off a 2020 if that makes a difference
  11. Mar 11, 2021 at 6:51 PM
    NoRcptn
    NorCal
    2017 Platinum
    Oh crap, then the dealer should know the color codes if you have a chance to hit them up.
  12. Mar 11, 2021 at 6:54 PM
    SpooledReel
    RickyP
    Spanish Fort, AL
  13. Mar 12, 2021 at 4:14 AM
    Black
    2014 Tundra Limited CrewMax
    The driver’s side spring in a hair longer but off course you can’t tell that when it is installed on the strut.
    For the Tundras the blue dot should be drivers side.
    Also the bottom pigtail should point to the drivers side for both springs.
    SpooledReel[OP] and NoRcptn like this.
  14. Mar 12, 2021 at 4:16 AM
    TRD Sport shocks, red/blue dot goes on driver's side.
  15. Mar 12, 2021 at 4:49 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    The coils have a paint code, I replaced the shocks on my '02 a few days ago and used this chart.
    BenAZ likes this.
  16. Mar 12, 2021 at 5:02 AM
    SpooledReel
    RickyP
    Spanish Fort, AL
    What is the pigtail?
  17. Mar 12, 2021 at 5:03 AM
    SpooledReel
    RickyP
    Spanish Fort, AL
    Oh the coil spring bottom I assume?
  18. Mar 12, 2021 at 5:04 AM
    NoRcptn
    NorCal
    2017 Platinum
    The end of the spring on the bottom.
  19. Mar 12, 2021 at 11:13 AM
    SpooledReel
    RickyP
    Spanish Fort, AL
    Switched them over and the front is equal at 39.75. Getting alignment now. Thanks for the help guys!
    TRDFerguson likes this.
  20. Mar 12, 2021 at 12:30 PM
    AL_TUNDY
    AL_TUNDY New Member
    The Land of Nye
    2005 Tundra
    You have my luck. 50/50 chance of getting it right on the first try, and you got it wrong. Like putting on a tag-less t-shirts in the dark. It's always on backwards the first try:/
    SpooledReel[OP] likes this.
  21. Mar 12, 2021 at 12:47 PM
    NoRcptn
    NorCal
    2017 Platinum
    Awesome!
